586,728 active members*
3,308 visitors online*
    Oct 2006
    24
    Mach3 0-5V to 12-24V ??
    I want to change 0-5V from printer port to 12-24V to use for my servo drive. Anybody have idea how to do it? Thank in advance for your helps.
    Nov 2004
    118
    Take a look here http://www.cncbuildingblocks.com/ele...interface.html
    He has a board that can do it and he also has a board that can home to an index pulse...
    Hope that helps
    Brian
    Jan 2007
    18
    5v>>>hi Volt Drive
    Quote Originally Posted by jimmychand View Post
    Hello . Everybody.
    I am driving by the AC servo motor and the driver.
    Easily, open collector's transistor array is used.
    It is this easy easily and it is possible to use it.
    Differential motion output 26LS31 that uses the line driver is used to keep rich.
    For the reference though the link is Japanese
    http://sec-suzuki.com/newpage205.htm
    Though it is an automatic translation
    http://nifty.amikai.com/AmiWeb?ami_u...583&ami_nojava
    I hope this is paved then.
