586,383 active members*
3,697 visitors online*
    Feb 2016
    9
    NEED HELP WITH BUTTON SCRIPT
    Hello,
    i am not good in programing so maybe i have stupid question but i dont know how to do it.
    So i need a button script that put ON Output 4 until INPUT 1 is active ,then stop the power to output 4,
    i tryed this :
    DoOEMButton(233)
    IF IsActive(INPUT1)then
    DoButton(234)
    DoButton(0) // to start cycle
    But this works only if i activate INPUT1 it doesnt wait it.
    this si to control DC Motor with switches . So i dont know how to do it or how to LOOP the "IF" until is active INPUT1.
    And can someone tell me what is commad to WAIT UNTIL "SWITCH IS ON" or somethink like that .
    Sorry for poor English.
    Thanks .
    Re: NEED HELP WITH BUTTON SCRIPT
    I told you on the Machsupport forum. You need to use the macropump.
    Save your code as macropump.m1s, and enable the macropump in General Config, and it will run your code 10 times per second.
  1. How to attach C# script to a screen button ??
    By Beefy in forum UCCNC Control Software
    Last Post: 08-31-2015, 02:37 AM
  2. VB Script
    By Montabelli in forum Mastercam
    Last Post: 08-20-2015, 12:11 AM
  3. Edit button script
    By dukedunham in forum Mach Mill
    Last Post: 01-25-2015, 01:28 AM
  4. Easiest way to make button run VB script
    By adamchapman in forum Mach Software (ArtSoft software)
    Last Post: 08-16-2010, 08:38 PM
  5. VB6,VB.net,VB script,What one???
    By hydrospin01 in forum Visual Basic
    Last Post: 05-25-2008, 02:09 AM
