586,494 active members*
2,629 visitors online*
    Aug 2007
    81
    Sinumerik 810M GA3
    So i bought this old Storebro Combi Mill CNC. and it comes with Siemens Sinumerik 810M GA3.
    But when it boots the fans go on and all that. But no buttons responds, if i press the button corresponding to "PLC Init" it just punches out 1 on the screens lower corner. No character is on a corresponding button.
    You cant make it jog or anything or access menus. The ORD1 saids "Overheated" and a red diod lights up. And that all i can do with that.
    If anyone has something i can try before i scrap this it would be greatly appreciated.
    Aug 2007
    81
    Re: Sinumerik 810M GA3
    So it seems to be a battery issue, not overheating.. its a bad translation.. So the machine had dropped all parameters as well.
    Jan 2018
    substitua a bateria antes de começar a passar pelos parâmetros
    May 2016
    526
    Did you get the back up with the machine
    May 2004
    402
    Yes he did, he described it on the Madmodders forum:
    https://madmodder.net/index.php/topic,11351.0.html
    Andrew Mawson
    East Sussex, UK
  1. Famup FCN 500 Sinumerik 810M parameters
    By guhl in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-11-2018, 02:51 PM
  2. Sinumerik 810M GA 1 - memory expansion
    By RRaly in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 06-17-2015, 12:01 PM
  3. SINUMERIK 810M - 7024 error
    By rliovic in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-23-2011, 04:20 PM
  4. Sinumerik 810M buttons do not respond
    By Alzen in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 06-19-2011, 11:13 AM
  5. SINUMERIK 810M GA1
    By amo in forum CNC Machine Related Electronics
    Last Post: 11-17-2009, 09:58 AM
