586,077 active members*
3,737 visitors online*
    Jul 2006
    141
    Question V groove bits-specifications
    I am finally set up and getting ready to run my table.
    I want to try to do some experimenting with V groove bits.
    I can't seem to find anything as far as feeds or speeds or even chip loads to figure out what I need to set my machine to.
    I have tried Amana, CMT and other web sites. Nothing. Or i'm looking at the wrong places.
    I have 1/2" 90 degree and 1/2" 60 degree v bits and can't find this information.
    Can anyone show me the right direction to find this information
    TIA
    Gary
    Re: V groove bits-specifications
    I think you need to use trial and error with V-bits.
    You won't find chip load charts, because the chip load varies as you go from tip of the cutter up to the top of the cutting edge.
    Say you have a 3/4" diameter 90° bit.
    At the tip, you have zero diameter, removing almost zero material. At full depth, the top of the bit is 3/4" diameter, removing the same amount of material that a 3/4" straight bit would.
    You'll also find that different woods will require different feedrates and rpms to achieve similar cut quality.
    Jul 2006
    141
    Thanks for the reply Gerry,
    I am just trying to find a starting point for V bits. I understand what you are saying about the style of bit.
    Gary
    Apr 2004
    733
    For pine I usually start at 75ipm and 16k rpm. I sometimes run the program twice but set the Z a few thou lower. This will help clean out the deeper v grooves on pine. Pine tends to tear out a little.
    Hardwood vcarving comes out much cleaner so you can increase feed rate.
  1. 1/4 cns v groove bits or 6mm
    By kevbud in forum WoodWorking Topics
    Last Post: 09-01-2014, 12:43 PM
  2. Replies: 0
    Last Post: 08-31-2014, 06:38 PM
  3. Replies: 0
    Last Post: 08-31-2014, 02:19 AM
  4. Help w/ Amana In-Groove bits for Edge lit sign
    By Silver-Fox in forum Signmaking Topics
    Last Post: 01-20-2013, 05:04 PM
  5. Round Over Groove Router Bits
    By wishgranter in forum CNC Tooling
    Last Post: 01-10-2012, 09:48 AM
