586,113 active members*
3,212 visitors online*
Results 1 to 20 of 51
Threaded View
    Feb 2006
    33
    Smile My mill Conversion
    Hello All,
    I have been reading here off and on for the past year. I found this site last year when I traded a guy for an old CNC Knee mill. I gave him a Wells Index 555, 2hp motor (step pulley), 9x42 table, power feed on the x. I got a Tri-onics Handyman CNC Mill. It has a 3hp Motor (variable speed), 10x54 table, ball screws, one shot oilier, and junk electrical control. I moved the mill to my house and have not done much to it over the last 10 months. I am getting caught up and now am getting ready to start.
    I will try to document this the best I can but I am going to have a hard time keeping up with some of the others on the forum. So this is what I am thinking so far. I got an enclosure off of a Bridgeport that was being trashed. So I have mounted this on the rear of the machine and am planning on using this for all my electronics. The power supply is OK on the old Tri-onics control and I will move this into the enclosure and use it. The machine has stepper’s (680oz, 2-1 reduction) with linear scales on each axis. I do not know if Tri-onics used these for position feed back or readout.
    I am looking very hard at Gecko’s 202, Larkin cobra’s. As for the breakout board it may be one of the following: Campbell’s, PMDX, or the Grex100. Mach 3 as the software. I am thinking of using one of the first (2) breakout boards because I am not planning on using encoders for the time being. I want to get this mill running and see what doors it opens and then I will probably get a different machine in the future, but I still want a functional machine. I am willing to spend the money and the control wiring and machining will be no big problem. I have wired and programmed many PLC’s, and may other types of industrial equipment.
    So this is the start of my progress and I will post pictures of the machine in the next few days.
    Thanks all in advance, Brian
    The mill I have looks like the picture attached.
  1. Drillbit test with mill LMS 3960 mill conversion
    By msimpson99 in forum Benchtop Machines
    Last Post: 10-20-2013, 11:20 AM
  2. New Mill Conversion
    By electromech31 in forum Knee Vertical Mills
    Last Post: 12-20-2012, 06:08 PM
  3. Replies: 18
    Last Post: 01-31-2012, 02:55 PM
