586,070 active members*
3,556 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Rolled Ball Screw Source Suggestion
    Mar 2016
    7
    I have started a CNC router build and would appreciate advice on sources of rolled ball screws for the X and Y. Both about 4 feet long. Want to use rolled screws to keep cost down.
    Any and all advice appreciated,
    Matty
    Feb 2009
    192
    Re: Rolled Ball Screw Source Suggestion
    Quote Originally Posted by Matt-y View Post
    Matty
    Matty, check on EBAY
    1943
    Mcmaster carr sells rolled ball screws and nuts too
    Mar 2004
    1806
    When I converted my mill/drill back around 2000, I used Roton screws. Back then, got what I thought was a good price and service, A few years ago, somehow I messed up a ballnut and called to see if I could get a replacement and not only did I get the replacement, but talked to the SAME person on the phone!
    The accuracy is good enough for the stuff I do.
    By the way, each time I have used them, the packaging was excellent and I never received a bent screw which is something I have seen complaints about from overseas shipments.
    Roton Products, Inc. Quality Lead Screws and Nuts for Power Transmission
    Art
    AKA Country Bubba (Older Than Dirt)
    Jul 2009
    85
    I have found that if you want an all around axis package, (screw, nut, blocks, etc.) then aliexpress has the best deals. Otherwise, even on Ebay, you will be nickel and dimed over the little pieces.
  1. Is this a ground or rolled ball screw
    By bmklawt in forum Linear and Rotary Motion
    Last Post: 11-06-2011, 01:17 AM
  2. Excellent source for NEW rolled ball screws?
    By gearsoup in forum Linear and Rotary Motion
    Last Post: 09-19-2010, 03:05 AM
  3. Ground ball screw source?
    By jhncaj in forum Linear and Rotary Motion
    Last Post: 08-12-2010, 10:57 PM
  4. rolled 5/8 ball screw.200 pl
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-02-2008, 03:09 AM
  5. Ball Screw Source for Conversion
    By RTP_Burnsville in forum Linear and Rotary Motion
    Last Post: 12-30-2006, 11:39 PM
