I hope I'm in the right forum for this.
I have an IronMan from blurry customs. To make things as simple as possible, my situation is that every aspect of the machine orthogonality is simply bad to practically useless, I could list all of them here if necessary.
My problem though is more about fixing it and unfortunately, the only adjustment the machine provide, is the play between the bolts and the hole they go through. In addition to that and or because of that it is practically impossible to adjust anything on the CNC a single direction at a time or in other words, a single degree of freedom at a time. The design doesn't seems to allow much shimming either.
On the positive side, I have ballscrews on all axis, dual on X, I have solid rails something like this.
Attachment 312508
I also have a few other things I wouldn't throw away, Geko 540, Smoothstepper, etc. I don't want to throw good money after bad like they say but I'm already in for close to $7K and can't even cut a stupid little veneered box 7" x 7" x 11" using the miter fold technique.
My work table is not planar and not parallel to the true YX plane, I've faced my spoilboard at minimum 0.080" and I'm not there yet, I'm doing this with a small 1/4 inch bit and it is clearly visible by the marks that the Z axis is not perpendicular to the board just machined. One last little thing, I check using a precision square if my gantry (Y) was square with the X axis and on a length of only 10 inch, I'm off close to 0.085". I double checked just in case...
I don't even know where to start. I'm sure you'll need more then what I said here. Lets say it's just a first step.
Thanks in advance,
Yves
