Hmm,
Do you see anything abnormal in the electical cabinet? LED's that aren't on, etc?
That early in the bootup, I'd wonder perhaps about the PC type power supply failing.
With the power completely off, pull and reseat all the connectors that you can, and check all screw terminal connections for tightness. Gently pull on the wires first to see if you can find an actual loose culprit.
