586,190 active members*
4,040 visitors online*
Thread: Slave axis
    Nov 2006
    5
    Slave axis
    Why when one works with an enslaved axis that each one has a sensor of home and home is executed from the program, one of the axes always makes two detections and two positionings.
    Many Thanks
    Carles
    COuld be noise on the home switch. Have you tried increasing the switch debounce setting?
    Nov 2004
    118
    When you home with a slaved axis be sure that the Home Vel % is the same That will make for an odd home move...
