586,051 active members*
3,945 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Need help setting up viper 200
Results 1 to 7 of 7
    Sep 2013
    17
    I am setting up my first viper 200 drive using the original servos and renco encoders. Had to trace wires from the encoders to get the right wires to plug into the drive. So , I finally got to the point of being able to turn the shaft and see the encoder reading. The problem I am having is going through the manual. I am doing exactly what it says about increasing the the numbers by 50 , but the motor does not stiffen up. Maybe just a little bit , but not a huge difference.
    Do I need to be connected to Mach3 first?
    Any info on getting the motor to move would be greatly appreciated. I am just at a lost. I can provide whatever info to help get me through this first drive.
    Sep 2013
    17
    Re: Need help setting up viper 200
    By the way. I get 5 red flashed . I know it is an encoder trip. Where should I go from here?
    Feb 2007
    966
    Does the motor hold when you turn the power on ?
    Does it move back and forth when you exercise in viper tune ?
    What is the motor rated voltage and what is your powersupply voltage ?
    what is your P and D settings ?
    Larry
    Sep 2013
    17
    ok , Larry , I kind of jumped the gun. after a few hours of going over your manual and doing some searching , I finally got the x to hold and started tuning the pid . After that the y was easy. Sorry got frustrated for a minute. But now the problem I am having is that the x and y encoders have been updated but the z is still the original heidenhain ero 120. I can not find the pin outs on that encoder anywhere . I have other encoders , but the shaft on the motor is 3/8 and the shaft for my other encoders need to be 1/4 inch. I really dont want to take the z apart and chuck it up in the lathe to turn down the shaft. I was going to just try and run the original encoder , but like I said I absolutely can not find any information on it. Any thoughts?
    Feb 2007
    966
    I would get a USdigital E5 (will go up to a 3/8" shaft) before trying to turn down a shaft.
    US Digital | Products
    Larry
    Sep 2013
    17
    ah ha , forgot that I had 2 complete manuals on this machine. Here is the original encoder wire. I will try this one before I buy a replacement.
    Feb 2007
    966
    Quote Originally Posted by jon1982 View Post
    Does it say how many lines it is ?
  1. How setting tools and setting offset
    By John246 in forum Sharp CNC
    Last Post: 04-09-2016, 08:31 PM
  2. Viper 250 ??????
    By jeep534 in forum Viper Servo drives
    Last Post: 04-08-2012, 07:58 PM
  3. Question about setting up viper drives.
    By Jackal66 in forum Viper Servo drives
    Last Post: 07-18-2010, 02:10 AM
  4. Couple of questions about setting up my Viper drives
    By Danno in forum Viper Servo drives
    Last Post: 09-07-2009, 10:47 PM
