586,119 active members*
3,603 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > how can i disable air on this little one ?
Results 1 to 11 of 11
    Jun 2015
    4154
    hello, please, how can i disable air @ call 0030 ? it is way too noisy for what it does ... kindly !
    Apr 2009
    1262
    Re: how can i disable air on this little one ?
    The air blow is in the sensor routine to clean off chips and coolant. It is not recommended to remove it. An exair air knife addition will quiet it.
    The m code is buried in the gauging MSB file an is in each routine and is protected, so as not to be altered...
    Best regards,
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    what mean "An exair air knife addition will quiet it." ?
    Apr 2009
    1262
    EXAIR's Air Nozzles and Jets reduce noise and compressed air cost for blowoff and drying
    Try to add some different air nozzle to quiet it rather than eliminate the blow.
    Best regards,
    Jun 2015
    4154
    done by msb edit ...
    Jul 2010
    287
    Quote Originally Posted by deadlykitten View Post
    Though technically correct, do not, I repeat, do not, do this. If the goal is simply disable under all conditions the air blow, disconnect the air line for the solenoid or the electrical connector from the solenoid to trigger the air. Simpler. More reversible.
    Jun 2015
    4154
    meow meoooow ...
    Jun 2015
    4154
    disabling air is not so good, because chips sometimes remain on the senzor
    so, i replaced "M155" with "M155*G04 F0.6*M154"
    * is a non alfa-numeric / special char that i can not write in the forum; it means something like "enter" from the keyboard msb files do not fit classical text layout ...
    effect : air is blown enough to clean the senzor ; if there are chips on tool, this requires operator intervention ...
    Apr 2009
    1262
    I see you got experience just after you needed it.... :-)
    Try listening more... kindly!
    Jun 2015
    4154
    Hello mr Wizard good to see you
    maybe it's time to change your signature
    Try listening more ...
    there is a point when whatever i read, or even if i am given a solution, i just don't get it ... it takes time for me to make the " connection "
    also, i don't have always time for such stuff, because of "daily routines" ... i expect a programmer in October, so i can focus more on "my way", and less on what is required ... "what is required" i do, but is not chalenging for me
    ps : somewhere, somehow, we 2, think the same
    Jun 2015
    4154
    during keyboard writing, each time "enter" is pressed, a "new line is inserted", and "cursor jumps to the new line begining" ; text appears as :
    line1
    line2
    this text may be saved as it is, or like this : line1*line2, thus a long line ; however, when text is displayed again, the compiler may break it whenever it meets " * "
    one thing this trick delivers is smaller size for simple files : "enter" uses 2 bytes, one for the "end of line" and another for " new line insert " ; this char uses a single byte for same behaviour it seems that msb files use this last variant
    ... into the attached image, this character can be seen ( "relatively", because it is not displayed the character, but the fact that it is there )
    ... attached txt file contains this caracter; if you open it with " notepad", or a simple text editor, it should display "12" ; if you copy and paste it into a complex text editor, as "word", it should display two lines, one with "1", and 2nd with "2"
    this started since the typewriter machines ; more about this can be found here : https://en.wikipedia.org/wiki/Carriage_return
  1. Enable/disable
    By willheg in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2012, 02:35 PM
  2. G203V disable
    By Drools in forum Gecko Drives
    Last Post: 05-08-2012, 03:05 PM
  3. VSD-A Disable Pin
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 09-01-2011, 11:58 PM
  4. How do you disable SMI?
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 03-04-2009, 10:22 PM
  5. Disable with Mach
    By belli in forum Mach Plasma / Laser
    Last Post: 07-14-2007, 09:53 PM
