I figured that it would not hurt to ask for some hands on assistance on a machine I picked up through Craigslist. (willing to negotiate a cost for the help assisted with)
The Chinese machine I picked up is identical to :
the machine also came with a PC with Mach3 already installed.
Apparently the one who owned it never used it and also didn't know how to use it.
For $1300.00 US I gave it a risk to do some small aluminum engraving projects I wanted to do.
- For starters the "cooling water" pump doesn't seem to pump water into the spindle. I assume the pump is no good although it does seem to turn on.
- Did not come with a parallel cable. Picked one up for $10.00 so no big deal.
- Now After powering it up just to test out AXIS movements with the arrow keys on the keyboard, I GET NO MOVEMENT. As if no signal is being transferred having the Mach3 software open up.
I did hit the search button, but it is too much to take in, especially when my experience is very limited.
The controller does turn on the spindle and I can control the RPM with the knob.
Other than that, I honestly don't know where to check / look into or go from here.
Any advise would be helpful.
Thanx
Dave -
