586,076 active members*
3,799 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > SCM 220 RECORD TOOL CHANGER NOT IN POSITION
    Jan 2016
    5
    Hello does any on know how to reset a tool changer position? I accidentally loaded a tool chuck into the empty one so it has collided while emptying the current tool. Now I cannot reference the machine at start up. It stats error 80 tool changer 1 not in position. I have emptied the holders and unplugging the airline relaxes the machine but when i plug it back in it moves the same position under the chuck. I don't know anything about the limit switches or where to find them but I can usually figure things out if I'm given step by step instructions. Any help would be appreciated. Thank you.
    Scott
    Dec 2020
    Re: SCM 220 RECORD TOOL CHANGER NOT IN POSITION
    Hello Scott,
    How did you solved this problem? I have the same problem and I have not found solution.
    Thank you.
    Dimitris
    Apr 2020
    Hi have you still got 220 record Cnc if so text me on 07769295318
  1. Tool changer out of position scm record 220
    By Benaiah in forum Commercial CNC Wood Routers
    Last Post: 01-28-2024, 01:55 PM
  2. FA630 tool changer out of position
    By ATSATHENS in forum Toyoda
    Last Post: 02-08-2022, 03:21 PM
  3. Replies: 72
    Last Post: 03-31-2016, 05:29 PM
  4. Tool changer no basic position - DMU 50V
    By hiatec in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-04-2014, 04:18 AM
