586,655 active members*
3,639 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Accepted Bearing stack for Ballscrew
Results 1 to 11 of 11
    Mar 2012
    109
    Hey folks,
    Firstly, I read the stickies in this subforum and it did answer a few questions, but I'm still questioning some of my ideas at the moment.
    Here's the situation: I was getting around .0035" backlash in my X axis on my G0704 with C4 ballscrews. After adjusting gibs, and checking everything external, I decided to tear it apart and give it a clean and lap while I was at it.
    In the midst of doing this, through my own error, I bent my X axis ballscrew (dont ask). So, I'm looking for a replacement as we speak.
    In the meantime, I determined that the stock bearing support setup for the ballscrew was where my backlash was coming from, as such, I have ordered some new bearings for it. Specifically:
    3x 5200-2RS Bearing Angular Contact Sealed 10x30x14.3
    3x 51200 Thrust Bearing 10x26x11
    I'm trying to decide on what the correct arrangement is for both the fixed end and the floating end of my ballscrew. Here's what I'm thinking at the moment for the fixed end
    Attachment 313324
    This way the axial forces are loaded onto the thrust washer, and the radial forces are supported by the double row bearing.
    Is this overkill? Should I only have one double row bearing and call it a day?
    As for the floating end, I was thinking just a double row bearing on its own and a nut for preload. Any other advice there?
    Thank you!
    Apr 2009
    5516
    Re: Accepted Bearing stack for Ballscrew
    There are a few different configurations, the most common I know of is with two AC bearings, with the "open" ends facing each other, so that they take both thrust and axial load. No thrust bearing is needed. You may need spacers to adjust the preload.
    On the free end a single row bearing should be fine, usually held with a circlip, and the bearing allowed to "float" in its housing to allow for expansion of the screw.
    Mar 2012
    109
    Open ends facing eachother, sandwiched together kinda like (nut) > (endplate) < /-/-/-/-/-/-/-/-/ Ballscrew
    Where the > and < are the direction of the angular contact bearings.
    When you say float in the housing, do you mean in the axial direction (so the screw would expand and slide on the inner race). Or in the radial direction, so overbore the pocket and let the screw slide around on the outer race. That doesnt make much sense to me but I have to ask.
    Thanks for your view!
    15362
    Quote Originally Posted by inthebay View Post
    This Bearing arrangement can work, though it is not ideal, They should be Back to Back for the best loading, you can also use just (1 ) Bearing which is a double row Ac bearing, these are non adjustable, and usually have no more the .0005 Backlash
    You also need to have the bearing in a housing that has the the correct depth for the bearing to do it's job, Photo is a ( 1 ) piece 2 Row Ac Bearing
    Mactec54
    Apr 2009
    5516
    Yes it's that contact pressure angle of the ball races that take up both axial and radial play, and determines the load rating of the assembly. Imagine an "X" formed by the opposite angled outer races. The wider the "X", the higher the load rating (this would require spacers to get the proper angle as specd by the bearing set). For light duty work, the open ends re sometimes faced away from each other, which narrows said "X" decreasing it's axial load capacity. In the fixed end bearing housing, a thin spacer may be needed between the two inner races to obtain the preload necessary.
    On the "free" end, radial ball bearing inner race is seated against the shoulder of the journal of the ballscrew and kept in place with a circlip (hence the groove at the free end.) The fit in the free end bearing block is more of a slip fit, as to not allow play in the radial direction. This is because the "fixed" end takes all the axial load.
    On very light axial loads, sometimes two radial BBs are used, very lightly preloaded/
    Apr 2009
    5516
    15362
    Quote Originally Posted by louieatienza View Post
    Take a look here at THKs website:
    Not much point looking at those Ac Thrust Bearings, unless he has a spare $800 Plus per set, most hobby users spend from $6 to $40 for the Bearing sets they need, and they are not matched pairs or precision Like what you have posted in the THK catalog
    It's a whole different thing to use cheap Bearings, and how to use them effectively, to get the most out of them, everything that is the right way to do it, get's thrown out the window, when they can only use cheap Bearings
    Most that have these machines are using a 2 Row sealed Ac Bearing, a $35 Bearing for the fixed end
    Mactec54
    Apr 2009
    5516
    For God's sake, I posted these to show the orientation of the bearings, not for purchase. Why is it different for less expensive bearings?
    15362
    Because the Bearings are not anywhere near the same that are being used in those illustrations/drawings, these Bearing also so have much higher angle of contact, they just don't compare, to standard Ac Bearing, so you have to be creative to use the cheap Bearings, to make them work, to be of any use, the cheaper Bearings have to be orientated Back to Back, not as they are in the Drawings you posted, the best for these guys is the ( 1 ) piece 2 Row AC Bearing, these are a Back to Back configuration, and they work very well for a machine like this
    Mactec54
    15362
    inthebay
    We did not answer your question
    Yes you can use a ( 2 ) 2 Row Ac Bearing one on each end of your screw, you can then add a slight Preload ( 4lbs to10 lbs ) with a Nut and spacer on each end of the screw
    The Bearings 10x30 Part # 5200-2NSL,Nachi is one of the better quality Bearings in this type, this is if your shaft is 10mm at each end
    Mactec54
    Mar 2012
    109
    Excellent, thank you all for your comments. I'm glad to see that the double row bearings will not need to be shimmed in order to function correctly. This should make installation a breeze.
  1. Ballscrew Bearing/Thrust Bearing Arrangement (G0704)
    By inthebay in forum Benchtop Machines
    Last Post: 02-16-2022, 10:22 PM
  2. Need ballscrew loose bearing supplier
    By MrWild in forum Benchtop Machines
    Last Post: 07-04-2010, 02:06 AM
  3. help for mount bearing ballscrew
    By p_rabid in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 09:11 AM
  4. Ballscrew bearing question
    By pstockley in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2006, 10:21 PM
  5. bearing mounts - ballscrew
    By cadman in forum Fadal
    Last Post: 05-25-2005, 11:11 PM
