586,094 active members*
3,997 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Sprutcam 10 - Lathe - Machine Under Axis Setting
    Feb 2016
    Post Sprutcam 10 - Lathe - Machine Under Axis Setting
    Maybe this is a newbie question, but I havent been able to figure out how to tell SprutCAM to change the side of the part to machine on a lathe. Everything appears to be oriented correctly and I can generate good toolpaths for machining with the tool on the positive-X side of the workpiece. I want to machine with the tool on the negative-X side of the workpiece but cant find the option in SC10.
    Based on some other searches and reading through help files, it looks like in sprutcam 9, there was an option to select "Machine Under Axis". (see attached image)
    My question is, Where is this option in SprutCAM 10?
    Any help would be appreciated
    Thanks!
    Dec 2014
    25
    Re: Sprutcam 10 - Lathe - Machine Under Axis Setting
    Its in there. Not in front of my computer so.... should be under the round icon or the gear looking icon.
    Works ok, it should shift the tool path to the bottom of the part.
    Apr 2016
    44
    Quote Originally Posted by Herbig View Post
    Thanks!
    http://www.cnczone.com/forums/sprutc...der-right.html I answered this in here a few days ago
  1. Setting Up a Drill Bit Model In SprutCam
    By MetalShavings in forum SprutCAM
    Last Post: 09-27-2014, 06:52 PM
  2. 3 Axis Lathe/MillTurn Setting Times
    By atmosports in forum MetalWork Discussion
    Last Post: 02-22-2014, 04:44 PM
  3. Replies: 12
    Last Post: 03-28-2013, 09:27 AM
  4. Setting machine zero on horizontal B-axis
    By Anders6612 in forum Surfcam
    Last Post: 06-18-2012, 01:52 AM
  5. setting up a lathe "A" axis
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 07-20-2009, 10:26 PM
