hello, from where can i download/install "thinc api" ? kindly !
Our Open API Software Development Kit is currently located on Bitbucket.
https://bitbucket.org/okuma/open-api-sdk/downloads
We use StackOverflow to answer programming questions.
http://stackoverflow.com/questions/tagged/okuma
Open API questions can be sent to [email protected]
You can download SCOUT on Okuma App Store and run it on the target machines to verify which version of THINC-API can be installed.
https://www.myokuma.com/scout
Hello, i downloaded everything from that link. I can not open chm files, and those 2 archives contain files that i guess i must copy on the machine, somewhere ...
Can i install THINC-API if i copy those archives content ?
....OkumaOpenAPI_SDKv0.7.zip
....okuma-open-api-sdk-85430fe0cb92.zip
I think it can not detect which THINC-API version i need ...
This is from Scout.log :
[FILE_INFO]
ApiNotifierExist=False
OspLatheSpecialApi=True
OspLatheSpecialApiVersion=2.0.0.49
OspLatheDataApi=True
OspLatheDataApiVersion=1.0.3.9
OspLatheCmdApi=True
OspLatheCmdApiVersion=1.0.2.9
OspMCSpecialApi=False
OspMachineCenterDataApi=False
OspMachineCenterCmdApi=False
[THINC_API]
ApiSpec=False
ThincApiInstalled=False
ApiInstallType=N/A
ThincApiCheckResult=MissingApiFiles
ThincApiVersion=N/A
CustomApiCheckResult=VersionRecognized
CustomApiVersion=003P
ApiStatus=NotReady .................................................. .. kindly !
hy, i give up on API, because i had no reason to install API; why do you need it ?
I need to install MTconnect adapter and agent and for that it is written in installation manual that I need THINC API and THINC startup service. I got the same files but don't know what to do next.
Moreover I can't find the installation manual for THINC API... It is referenced every where but could not find anywhere!
hi, i have no clue how to use api ...
pls, does anybody know how to edit the common variables ? or does anybody know somebody ?
or do you know a guy who knows a guy who knows a guy ..... ? etc kindly
Firstly you must learn to visual basic
"Imagination is more important than knowledge."
hi / delphi 6 is ok ?
This is sample. It shows common variables 1 to 20
import clr
import sys
sys.path.append(r'c:\windows\assembly')
clr.AddReference('Okuma.CMDATAPI')
import Okuma.CMDATAPI.DataAPI as datapi
datapi.CMachine()
_.Init()
vars = datapi.CVariables()
for i in range(1,20):
print("Var {0} = {1}".format(i,vars.GetCommonVariableValue(i)))
vars.SetCommonVariableValue(5,555)
Probably not ok.
I think it needs .NET environment
Hi deadlykitten
thx / at 1st glance, i have no clue about it
THINC API Install Manual is located in the SDK:
https://github.com/OkumaAmerica/Open...n%20Manual.pdf
You cannot download the installer, you must purchase the option or request an update.
