586,036 active members*
3,790 visitors online*
IndustryArena Forum > CAD Software > Solidworks > saving part with balloons added
    Feb 2015
    11
    Imported solid model .x_t from design X into Solidworks, added balloons for part ID to a tabulation. Went to save part as ,sldprt and it said it could not, went to export as .x_t and also as IGES and it saved it but the balloons are missing when I load it back in. Also I wanted to just add in the tabulation to the model and make it all one file but when I choose table and start trying to fill it in that fails also. Baffled on how to do something that should be painfully simple.
    Jun 2008
    562
    Re: saving part with balloons added
    I don't know what version of SWX you are using, but you can save tables and balloons in 2014. When you export the model they do disappear as you stated.
    Depending on their orientation the balloons become skewed. Make sure you have all annotations viewable.
    Mike
    Attached Thumbnails Attached Thumbnails Table.pdf
  1. Huazhong HNC 21M saving and importing part programs
    By 123CNC in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2014, 02:54 AM
  2. Grip for Oval Inspection balloons
    By camtd in forum UG NX
    Last Post: 12-04-2013, 04:11 PM
  3. balloons
    By camtd in forum Autodesk
    Last Post: 02-03-2011, 09:34 AM
  4. Saving Copy of Part
    By Alex Westling in forum Solidworks
    Last Post: 02-06-2008, 01:31 PM
