586,115 active members*
3,428 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Any one running LinuxCNC with the Mesa 5i25 on their Patriot
    Dec 2008
    30
    I've had a problem with doing repetitive parts consistently with Mach3 and USB Smoothstepper. The parts are out of tolerance is some dimension, never the same error twice. I have my mechanical tolerances consistent and am not losing steps. I've been blaming it on the Smoothstepper, but have just found out about various bugs in different versions of Mach3. Apparently I can reinstall an older version of Mach3 in order to fix the Turn problem and then change to a later version to cure a Mill problem. So in an attempt to keep that extra step of changing Mach versions between operations I decided I need to change over to LinuxCNC and eliminate the SmoothStepper. I would like to hear of any tips or gotcha's in making the changeover. I am hoping that this will be a painless and simple changeover. I am not a Linux Guru so I am probably underestimating the effort.
    Any suggestions gratefully accepted.
    Bill Anderson
    Nov 2013
    88
    Re: Any one running LinuxCNC with the Mesa 5i25 on their Patriot
    I am not running the same machine but I do use Linuxcnc.
    Linuxcnc runs in realtime on a PC unlike windows and mach3, you can download and use the setup cd or a memory card to run Linuxcnc without installing it to see if your PC is stable enough to run it.
    It uses a parallel port or network cards (Mesa) but not through a usb port, at least the last time I checked.
    It is very accurate and I found it easy to use and setup, not as bad as you may think.
    Basic machine movement will be easy to get working. If your machine had any specialized code that was written for mach3, that will be lost.
    If you do have any problems not covered in there forums already, the moderators usually can help or point you in the right direction.
  1. Small Machine Conversion - Mesa 5I25/7I77
    By Sparky961 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-31-2015, 06:55 PM
  2. how do i migrate from parallel port to mesa 5i25?
    By MCRIPPPer in forum LinuxCNC (formerly EMC2)
    Last Post: 07-25-2015, 05:29 AM
  3. MESA 5i25-7i76 Spindle Issue
    By johnjsb in forum LinuxCNC (formerly EMC2)
    Last Post: 07-18-2012, 11:14 PM
  4. Mesa 5i25
    By Holzwurm56 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-26-2012, 02:01 PM
  5. Mesa 5I25+7i76 5V I/O
    By dicker in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2012, 10:19 PM
