586,112 active members*
3,173 visitors online*
    Aug 2007
    81
    G-Code weird thing.
    So i'm working on a camprocessor that i'm converting from Siemens 810D to the old Siemens 810M for fusion360
    And i got this line out of the process:
    N3077 G3 X72.117 Y-76.782 Z-24.6 I1=72.127 J1=-76.666 K1=-24.883
    And when run thru NCPlit i get illegal characters warning on that one.
    Im not sure if you can write radii like that..
    Kind regards // Andreas
    Mar 2016
    325
    Re: G-Code weird thing.
    You cannot define arc with three coordinates.
    First You have to define workplane (G17 or 18 or 19) an then You define arc with two coordinates.
    Apr 2015
    327
    Quote Originally Posted by steryd View Post
    That is not true. You CAN define circular interpolation with XZYIJK (for eample helix machining is define with 3 point, because machine go down with 3 axis). Problem is with anything else.
    Marek
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. weird code when using predator
    By NIS3R in forum BobCad-Cam
    Last Post: 10-01-2011, 10:39 PM
  2. what is this thing?
    By agnisflugen in forum Want To Buy...Need help!
    Last Post: 05-09-2011, 05:17 PM
  3. Weird thing happened with my Viper 200
    By Danno in forum Viper Servo drives
    Last Post: 01-21-2010, 09:47 AM
  4. What is this thing? And what 'exactly' does it do?
    By DAB_Design in forum Benchtop Machines
    Last Post: 09-17-2004, 09:42 PM
