586,116 active members*
3,386 visitors online*
    Apr 2013
    1899
    Simple pen holder (one hour of work)
    My CNC upgrade project is progressing quite well. All axes are now up and running, most of the mechanical upgrade works are done, so it is time for a test ride. I didn't immediately wanted to start with milling just to test accuracy, so I decided to use the good old cheap and very clean pen method, which simply means that instead of milling real material place a pen on the Z and use that, not the spindle motor. Basically, this converts the CNC into an old flat bed plotter, except that it can't read HPGL files, which is the most common file type for plotters.
    I created a G-code pattern manually and tried it out with an ordinary permanent marker pen. Of course, the results were not so pleasing. Not because there was anything wrong with my CNC, but it isn't really possible to use a pen instead of a spindle, at least not this way, by simply fixing the pen on the spindle holder.
    The pen holder looks like this when installed on the spindle holder:
    Attachment 314028
    The results after running the G-code are very good.
    Attachment 314030
    I run the same drawing four times on the same sheet and you can't really see that it has been run four times. I am very pleased with the results so far.
    Visit my blog post if you are interested in details and want to see many illustrative images about how I made this pen holder. The link to my blog post is this one:
    Adapting Camera: Making a pen holder for my CNC
    Good luck if you decide to use my idea and make a similar pen holder.
    I made a video also but have no time to process and post it right now. Will get back and post it when I am ready with it.
    Aug 2014
    60
    Re: Simple pen holder (one hour of work)
    That turned out nice Good job
    Apr 2013
    1899
    Thank you. Yes, it works well, better than expected. I think I will use it more than I initially planned.
    Apr 2013
    1899
    I have published a short video showing the pen holder in action. If you are interested, here is the link.
    https://youtu.be/ItUOqsYaRB4
    If you are not already using pen to test your works you should start now. Being an amateur, at least for me, is a great help to detect mistakes. I let it draw before milling and at least in two dimensions, it shows my mistakes, like for example wrong radius compensation. Better to see the mistakes on paper than seeing it after the material is milled and wasted.
  1. Looking for a Tool Holder for Face Work for a Daewoo 8HC
    By Heavy Revy in forum Daewoo/Doosan
    Last Post: 01-13-2021, 04:57 PM
  2. Replies: 2
    Last Post: 12-23-2015, 05:52 PM
  3. PROBLEM laser stops work after an hour
    By enteakbal in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2015, 07:40 PM
  4. Inexpensive vacuum work holder for my cnc router
    By it's a henry in forum Work Fixtures / Hold-Down Solutions
    Last Post: 03-25-2012, 05:40 AM
  5. Work Holder Definition
    By MAX711 in forum SprutCAM
    Last Post: 12-14-2006, 12:38 AM
