586,036 active members*
4,285 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > How could I model this?
Page 1 of 2 12
Results 1 to 20 of 24
    Mar 2016
    10
    Question How could I model this?
    I've been scratching my head confused as to how I'd go about creating this effect on a sphere for one of my projects. Has anyone got any ideas as to how I could go about this?
    Mar 2010
    66
    Re: How could I model this?
    Project curves command?
    Mar 2016
    10
    But then once i project curves how do i get that layered effect?
    Jun 2014
    777
    Is that a machined effect? Just looks like the woods grain to me
    Mar 2016
    10
    @ Jon.N.CNC It might be the wood grain effect. But I think I could still recreate something similar on rhino?
    Mar 2016
    10
    Maybe that isn't the best image but what i'm after is something like thisClick image for larger version.
    Jun 2014
    777
    Quote Originally Posted by enesoz View Post
    I see, that would have likely been done with software like artcam or aspire, both have z level layering adjustment.
    Mar 2016
    10
    can i do that on aspire with a sphere not a flat surface?
    Apr 2003
    1357
    Is this for a rendering, or do you want those markings to be part of the model? If you just plan to create an image as opposed to manufacturing the object, (though additive or subtractive means) then it's pretty simple to add a material to the object.
    Dan
    Jun 2014
    777
    ahh no sorry don't think it does.
    Modelling it as a revolve would give you 360 degree even layers. You could model a few of these with layers in different places, cut and splice together and use fillets to smooth the joins.
    Jun 2014
    777
    Quote Originally Posted by Jon.N.CNC View Post
    I'm not sure in rhino but in inventor/360 you can create a 3D sketch and create splines around the sphere for the extruded 3D extruded sketch to follow.
    Mar 2016
    10
    I need the markings to be part of the model, its going to be manufactured so the relief waves need to be physically in the model
    Jan 2007
    1795
    then just use a program like blender, or mudbox....
    or you can use 3dcoat...
    the hobby version I think 100..
    possible maya also can do it..
    meshmixer also capable to lay on surfaces this woodgrain..
    from technical view, you need groves actually
    that's why z brush, or 3d coat can make it effectively.. you define a kind of ""brush"" and draw on the sphere..
    btw, what is your plan to machining it? and of what? steel? aluminum, or plastic?
    Mar 2016
    10
    I like the look of meshmixer, it seems like its got a mild learning curve. Would you be able to guide me to a tutorial or the specific tools and a little method I could use to do it on meshmixer
    Jan 2007
    1795
    heres some tutorial
    first create a ball, and ""bent surfaces""
    these surfaces representing the wood grain
    import as obj format in meshmixer
    in meshmixer they are separated objects..
    set sculpting tool to ""PINCH"" and start to draw a line along the intersection of the auxillary surfaces and the sphere..
    after the first line, turn off the plane visibility so you can go to next
    when you model the planes imagine the rings as closer to the tree core, they are smaller radiuses..
    make little odd them, not exactly radius.. if you know I mean..
    Mar 2016
    10
    thanks a lot i'll give this a go!
    Feb 2007
    11
    Here is a modeled version using "Project" and another using a wood grain texture.
Name:	Wood Texture.jpg
    Ted
    http://www.RhinoCanada.com or http://www.ted-kyte.com
    Feb 2007
    11
    The combine the "Project" with "Offset Surface and "Loft the edges. Here is a quick example.
    Ted
    Mar 2016
    10
    Thats great TedKyte really helpful, if I was to do the opposite and instead of the waves going in, have them as a relief, what command would I use for the last step?
    Feb 2007
    11
    Here is a better way, use 2 spheres, create your wave shapes and extrude them through both spheres.
    Split both the spheres with the surfaces, then split the surfaces with the sphere pieces, then delete the unwanted inside sphere surfaces and the unwanted outside sphere surfaces and it will join up as a closed poly surface that is machinable.
    Attachment 314590
    That makes the relief pieces horizontal. If you want them normal to the original surface then use the first method with "Offset Surface" and make the direction outward instead of inward.
    Ted
Page 1 of 2 12
  1. Replies: 2
    Last Post: 04-24-2018, 09:48 AM
  2. Manuals for Wasino Model LG-71 Turning Center and Mori Seiki Model MV-40B VMC
    By innovativeiron in forum Machinery Manuals / Brochures
    Last Post: 11-07-2013, 02:28 AM
  3. surface model vs Solid model machining
    By Marcutous in forum Daewoo/Doosan
    Last Post: 12-02-2012, 03:45 PM
  4. How To Model Rocks for Site Model
    By limbatus in forum Rhino 3D
    Last Post: 01-17-2012, 08:39 PM
