Hi all! I'm pleased to bring a new range of BLDC motors to market. Adlee Powertonic produce some very fine motors - certainly reaches above mainland China's offerings! I've personally been using them for a couple of years now, and found them to be Industrially reliable. They're general purpose prime-movers and not specific machine tool motors, but none the less work very well on metal work machinery.
Generally, Adlee greatly under-rates their motors. They're tested in 40c ambient temps, so an average temp of 20c should see higher achievable ratings.
All motors have these features in common:
- Mach 3 compatible - works with most speed control boards (tested with CNC4PC C6)
- Fully programmable settings (Accel, Decel, P gain, I gain, plus many others)
- Built-in overheat protection (100c cut out).
- Stall/Overload Protection
- MODBUS Compatible (haven't tested this feature).
I've evaluated some motors and found 3 models that should be of interest to the hobby / light production crowd:
AM370-H, 370watt rated, 1100watt MAX, 6000RPM. Available in 110v or 220v options (not dual voltage, +/- 10%). It's a likely drop-in replacement for the Seig SX3 machine (except the control panel). It should give you slightly more power and the ability to interface with MACH3 (via speed control board). It'd be a good match for the Sieg X2 or Optimum BF16/WMD20 mills and small-medium sized hobby lathes (100-200kg, 220-440lbs). Weight approx 4kg (9lbs). Tapping Video, Stall Test.
AM1000-H, 1000watt rated, 2300watt MAX, 6000rpm. Available in 220v ONLY (+/- 10%). A good match for Seig X3 machines, Weiss WMD20/25, Grizzly G0704 machines with power to spare. 130mm X 130mm frame. Weight approx 9kg (20lbs).
AM2200-H, 2200watt rated, 4000watt MAX, 6000rpm. Available in 220v ONLY (+/- 10%). This is the largest BLDC motor Adlee produce. This motor would be a good choice for those with heavier mills - RF45 style, Knee Mills & the like. I've noticed some people have had issues with Novakon and Makini spindle motors - these should be more than adequate for these machines. 130mm X 130mm frame. Weight approx 11kg (24lbs).
Pricing:
Currency in NEW ZEALAND dollars (click link for conversion)
AM370-H Set - $649.00 NZD +$150 intl shipping (GBP, Euro, USD, AUD)
AM1000-H - $899.00 +$275 intl Shipping (GBP, Euro, USD, AUD)
AM2200-H - $1149.00 +$275 intl Shipping (GBP, Euro, USD, AUD)
Australian customers receive 50% shipping reduction (due to their proximity).
More info on my homepage:
www.homemachineshop.co.nz
AM370-H / D305 manual
BL2-AM1000/2200 manual
Also to come are some CNC Kits for the Weiss WMD20/25, Grizzly G0704 machine and other BF20 clones, plus other accessories.
