586,068 active members*
3,693 visitors online*
Page 3 of 4 1234
Results 41 to 60 of 67
  1. #41
    Jun 2015
    4154
    Re: load monitor stuff
    this means updating the base monitoring limits as needed . point
    what if this would not be required ?
    solution would be :
    Code:
        safe position
        M110 + turret index + coolant
        approach + M rpm
        CALL O****
        load monitor on for M axis
        cut
        load monitor off
        check wife :)
    O****
    N1  record effort when M is rotating free and consider it as a reference, thus base value
    N2  limit 1 = base + 1
    N3  limit 2 = base + 2
    RTS
    any ideas for N1 ?
    if this would work, than tool wear charts may be generated, thus lowering costs with tools
    also this may help the guy posting this thread : http://www.cnczone.com/forums/okuma/201080-cnc.html
  2. #42
    Jun 2015
    4154
  3. #43
    Jun 2008
    113
    Excellent information and examples, thanks! This is just what I'm currently planning to incorporate into my Okuma postprocessor: add a maximum spindle load miscellaneous value to monitor for tool breakage.
  4. #44
    Jun 2015
    4154
    thx you are great !
    ps : if somehow you have a spare Lamborghini, or something, please, i will be honored
  5. #45
    Jun 2015
    4154
    hello again folowing posts will be about messing with LM values : clear / save / load
    "clear" is simple > all these variables will be initialized with 0 VLM*B [ arg ] , VLM*1 [ arg ] , VLM*2 [ arg ], where
    ... * = axis = ( X Z C ... )
    ... arg = argument = ( 1 .. 64 ) = load monitor variable adress / fied
    why clearing the variables ? i don't know ... i erasing contacts from phone agenda ? something like this ...
    "save" simple, of course : load monitor variables content saved inside a file
    why saving the variables ? so to avoid losing time, by seting (again) load monitor values, next time an existing setup is started
    "load" : initialize load monitor variables content with values that proved ok
    why loading the variables content ? so to avoid losing time by reading the output content delivered by a "save" procedure, and input it manually
    ps : folowing codes are for lb3oooEX2 osp3oo
  6. #46
    Jun 2015
    4154
    "clear" code variants; all variants take as initial data the LM adress/field to begin with, and the one where to stop
    variant 1
    ... code is looped
    variant 2
    ... code is linear, thus no loops; it performs faster
    ... it is a bit diagonal, so to say design issues, nothing else
    variant 3
    ... variant 2 without the "diagonal" effect
    variants as 2 & 3 :
    ... take much more time to write compared to variant 1, but they perform faster; linear code is always faster than looped code
    ... i generate using excel
    ... i find them boring a lot ...
    Code:
        V1 =  1
        V2 = 64
      ( * ) ( reset between V1 and V2 )
        NHERE
          VLMXB [ V1 ] = 0
          VLMX1 [ V1 ] = 0
          VLMX2 [ V1 ] = 0
          VLMZB [ V1 ] = 0
          VLMZ1 [ V1 ] = 0
          VLMZ2 [ V1 ] = 0
          VLMSB [ V1 ] = 0
          VLMS1 [ V1 ] = 0
          VLMS2 [ V1 ] = 0
          VLMCB [ V1 ] = 0
          VLMC1 [ V1 ] = 0
          VLMC2 [ V1 ] = 0
          VLMMB [ V1 ] = 0
          VLMM1 [ V1 ] = 0
          VLMM2 [ V1 ] = 0
          V1 = V1 + 1
        IF [ V1-1 LT V2 ] NHERE
        M02
    Code:
     VLMXB [ 1 ] = 0
      VLMX1 [ 1 ] = 0
       VLMX2 [ 1 ] = 0
     VLMZB [ 1 ] = 0
      VLMZ1 [ 1 ] = 0
        VLMZ2 [ 1 ] = 0
     VLMSB [ 1 ] = 0
      VLMS1 [ 1 ] = 0
       VLMS2 [ 1 ] = 0
     VLMCB [ 1 ] = 0
      VLMC1 [ 1 ] = 0
       VLMC2 [ 1 ] = 0
     VLMMB [ 1 ] = 0
      VLMM1 [ 1 ] = 0
       VLMM2 [ 1 ] = 0
     VLMXB [ 2 ] = 0
      VLMX1 [ 2 ] = 0
       VLMX2 [ 2 ] = 0
     VLMZB [ 2 ] = 0
      VLMZ1 [ 2 ] = 0
        VLMZ2 [ 2 ] = 0
     VLMSB [ 2 ] = 0
      VLMS1 [ 2 ] = 0
       VLMS2 [ 2 ] = 0
     VLMCB [ 2 ] = 0
      VLMC1 [ 2 ] = 0
       VLMC2 [ 2 ] = 0
     VLMMB [ 2 ] = 0
      VLMM1 [ 2 ] = 0
       VLMM2 [ 2 ] = 0
     VLMXB [ 3 ] = 0
      VLMX1 [ 3 ] = 0
       VLMX2 [ 3 ] = 0
     VLMZB [ 3 ] = 0
      VLMZ1 [ 3 ] = 0
        VLMZ2 [ 3 ] = 0
     VLMSB [ 3 ] = 0
      VLMS1 [ 3 ] = 0
       VLMS2 [ 3 ] = 0
     VLMCB [ 3 ] = 0
      VLMC1 [ 3 ] = 0
       VLMC2 [ 3 ] = 0
     VLMMB [ 3 ] = 0
      VLMM1 [ 3 ] = 0
       VLMM2 [ 3 ] = 0
     VLMXB [ 4 ] = 0
      VLMX1 [ 4 ] = 0
       VLMX2 [ 4 ] = 0
     VLMZB [ 4 ] = 0
      VLMZ1 [ 4 ] = 0
        VLMZ2 [ 4 ] = 0
     VLMSB [ 4 ] = 0
      VLMS1 [ 4 ] = 0
       VLMS2 [ 4 ] = 0
     VLMCB [ 4 ] = 0
      VLMC1 [ 4 ] = 0
       VLMC2 [ 4 ] = 0
     VLMMB [ 4 ] = 0
      VLMM1 [ 4 ] = 0
       VLMM2 [ 4 ] = 0
     VLMXB [ 5 ] = 0
      VLMX1 [ 5 ] = 0
       VLMX2 [ 5 ] = 0
     VLMZB [ 5 ] = 0
      VLMZ1 [ 5 ] = 0
        VLMZ2 [ 5 ] = 0
     VLMSB [ 5 ] = 0
      VLMS1 [ 5 ] = 0
       VLMS2 [ 5 ] = 0
     VLMCB [ 5 ] = 0
      VLMC1 [ 5 ] = 0
       VLMC2 [ 5 ] = 0
     VLMMB [ 5 ] = 0
      VLMM1 [ 5 ] = 0
       VLMM2 [ 5 ] = 0
     VLMXB [ 6 ] = 0
      VLMX1 [ 6 ] = 0
       VLMX2 [ 6 ] = 0
     VLMZB [ 6 ] = 0
      VLMZ1 [ 6 ] = 0
        VLMZ2 [ 6 ] = 0
     VLMSB [ 6 ] = 0
      VLMS1 [ 6 ] = 0
       VLMS2 [ 6 ] = 0
     VLMCB [ 6 ] = 0
      VLMC1 [ 6 ] = 0
       VLMC2 [ 6 ] = 0
     VLMMB [ 6 ] = 0
      VLMM1 [ 6 ] = 0
       VLMM2 [ 6 ] = 0
     VLMXB [ 7 ] = 0
      VLMX1 [ 7 ] = 0
       VLMX2 [ 7 ] = 0
     VLMZB [ 7 ] = 0
      VLMZ1 [ 7 ] = 0
        VLMZ2 [ 7 ] = 0
     VLMSB [ 7 ] = 0
      VLMS1 [ 7 ] = 0
       VLMS2 [ 7 ] = 0
     VLMCB [ 7 ] = 0
      VLMC1 [ 7 ] = 0
       VLMC2 [ 7 ] = 0
     VLMMB [ 7 ] = 0
      VLMM1 [ 7 ] = 0
       VLMM2 [ 7 ] = 0
     VLMXB [ 8 ] = 0
      VLMX1 [ 8 ] = 0
       VLMX2 [ 8 ] = 0
     VLMZB [ 8 ] = 0
      VLMZ1 [ 8 ] = 0
        VLMZ2 [ 8 ] = 0
     VLMSB [ 8 ] = 0
      VLMS1 [ 8 ] = 0
       VLMS2 [ 8 ] = 0
     VLMCB [ 8 ] = 0
      VLMC1 [ 8 ] = 0
       VLMC2 [ 8 ] = 0
     VLMMB [ 8 ] = 0
      VLMM1 [ 8 ] = 0
       VLMM2 [ 8 ] = 0
     VLMXB [ 9 ] = 0
      VLMX1 [ 9 ] = 0
       VLMX2 [ 9 ] = 0
     VLMZB [ 9 ] = 0
      VLMZ1 [ 9 ] = 0
        VLMZ2 [ 9 ] = 0
     VLMSB [ 9 ] = 0
      VLMS1 [ 9 ] = 0
       VLMS2 [ 9 ] = 0
     VLMCB [ 9 ] = 0
      VLMC1 [ 9 ] = 0
       VLMC2 [ 9 ] = 0
     VLMMB [ 9 ] = 0
      VLMM1 [ 9 ] = 0
       VLMM2 [ 9 ] = 0
     VLMXB [ 10 ] = 0
      VLMX1 [ 10 ] = 0
       VLMX2 [ 10 ] = 0
     VLMZB [ 10 ] = 0
      VLMZ1 [ 10 ] = 0
        VLMZ2 [ 10 ] = 0
     VLMSB [ 10 ] = 0
      VLMS1 [ 10 ] = 0
       VLMS2 [ 10 ] = 0
     VLMCB [ 10 ] = 0
      VLMC1 [ 10 ] = 0
       VLMC2 [ 10 ] = 0
     VLMMB [ 10 ] = 0
      VLMM1 [ 10 ] = 0
       VLMM2 [ 10 ] = 0
     VLMXB [ 11 ] = 0
      VLMX1 [ 11 ] = 0
       VLMX2 [ 11 ] = 0
     VLMZB [ 11 ] = 0
      VLMZ1 [ 11 ] = 0
        VLMZ2 [ 11 ] = 0
     VLMSB [ 11 ] = 0
      VLMS1 [ 11 ] = 0
       VLMS2 [ 11 ] = 0
     VLMCB [ 11 ] = 0
      VLMC1 [ 11 ] = 0
       VLMC2 [ 11 ] = 0
     VLMMB [ 11 ] = 0
      VLMM1 [ 11 ] = 0
       VLMM2 [ 11 ] = 0
     VLMXB [ 12 ] = 0
      VLMX1 [ 12 ] = 0
       VLMX2 [ 12 ] = 0
     VLMZB [ 12 ] = 0
      VLMZ1 [ 12 ] = 0
        VLMZ2 [ 12 ] = 0
     VLMSB [ 12 ] = 0
      VLMS1 [ 12 ] = 0
       VLMS2 [ 12 ] = 0
     VLMCB [ 12 ] = 0
      VLMC1 [ 12 ] = 0
       VLMC2 [ 12 ] = 0
     VLMMB [ 12 ] = 0
      VLMM1 [ 12 ] = 0
       VLMM2 [ 12 ] = 0
     VLMXB [ 13 ] = 0
      VLMX1 [ 13 ] = 0
       VLMX2 [ 13 ] = 0
     VLMZB [ 13 ] = 0
      VLMZ1 [ 13 ] = 0
        VLMZ2 [ 13 ] = 0
     VLMSB [ 13 ] = 0
      VLMS1 [ 13 ] = 0
       VLMS2 [ 13 ] = 0
     VLMCB [ 13 ] = 0
      VLMC1 [ 13 ] = 0
       VLMC2 [ 13 ] = 0
     VLMMB [ 13 ] = 0
      VLMM1 [ 13 ] = 0
       VLMM2 [ 13 ] = 0
     VLMXB [ 14 ] = 0
      VLMX1 [ 14 ] = 0
       VLMX2 [ 14 ] = 0
     VLMZB [ 14 ] = 0
      VLMZ1 [ 14 ] = 0
        VLMZ2 [ 14 ] = 0
     VLMSB [ 14 ] = 0
      VLMS1 [ 14 ] = 0
       VLMS2 [ 14 ] = 0
     VLMCB [ 14 ] = 0
      VLMC1 [ 14 ] = 0
       VLMC2 [ 14 ] = 0
     VLMMB [ 14 ] = 0
      VLMM1 [ 14 ] = 0
       VLMM2 [ 14 ] = 0
     VLMXB [ 15 ] = 0
      VLMX1 [ 15 ] = 0
       VLMX2 [ 15 ] = 0
     VLMZB [ 15 ] = 0
      VLMZ1 [ 15 ] = 0
        VLMZ2 [ 15 ] = 0
     VLMSB [ 15 ] = 0
      VLMS1 [ 15 ] = 0
       VLMS2 [ 15 ] = 0
     VLMCB [ 15 ] = 0
      VLMC1 [ 15 ] = 0
       VLMC2 [ 15 ] = 0
     VLMMB [ 15 ] = 0
      VLMM1 [ 15 ] = 0
       VLMM2 [ 15 ] = 0
     VLMXB [ 16 ] = 0
      VLMX1 [ 16 ] = 0
       VLMX2 [ 16 ] = 0
     VLMZB [ 16 ] = 0
      VLMZ1 [ 16 ] = 0
        VLMZ2 [ 16 ] = 0
     VLMSB [ 16 ] = 0
      VLMS1 [ 16 ] = 0
       VLMS2 [ 16 ] = 0
     VLMCB [ 16 ] = 0
      VLMC1 [ 16 ] = 0
       VLMC2 [ 16 ] = 0
     VLMMB [ 16 ] = 0
      VLMM1 [ 16 ] = 0
       VLMM2 [ 16 ] = 0
     VLMXB [ 17 ] = 0
      VLMX1 [ 17 ] = 0
       VLMX2 [ 17 ] = 0
     VLMZB [ 17 ] = 0
      VLMZ1 [ 17 ] = 0
        VLMZ2 [ 17 ] = 0
     VLMSB [ 17 ] = 0
      VLMS1 [ 17 ] = 0
       VLMS2 [ 17 ] = 0
     VLMCB [ 17 ] = 0
      VLMC1 [ 17 ] = 0
       VLMC2 [ 17 ] = 0
     VLMMB [ 17 ] = 0
      VLMM1 [ 17 ] = 0
       VLMM2 [ 17 ] = 0
     VLMXB [ 18 ] = 0
      VLMX1 [ 18 ] = 0
       VLMX2 [ 18 ] = 0
     VLMZB [ 18 ] = 0
      VLMZ1 [ 18 ] = 0
        VLMZ2 [ 18 ] = 0
     VLMSB [ 18 ] = 0
      VLMS1 [ 18 ] = 0
       VLMS2 [ 18 ] = 0
     VLMCB [ 18 ] = 0
      VLMC1 [ 18 ] = 0
       VLMC2 [ 18 ] = 0
     VLMMB [ 18 ] = 0
      VLMM1 [ 18 ] = 0
       VLMM2 [ 18 ] = 0
     VLMXB [ 19 ] = 0
      VLMX1 [ 19 ] = 0
       VLMX2 [ 19 ] = 0
     VLMZB [ 19 ] = 0
      VLMZ1 [ 19 ] = 0
        VLMZ2 [ 19 ] = 0
     VLMSB [ 19 ] = 0
      VLMS1 [ 19 ] = 0
       VLMS2 [ 19 ] = 0
     VLMCB [ 19 ] = 0
      VLMC1 [ 19 ] = 0
       VLMC2 [ 19 ] = 0
     VLMMB [ 19 ] = 0
      VLMM1 [ 19 ] = 0
       VLMM2 [ 19 ] = 0
     VLMXB [ 20 ] = 0
      VLMX1 [ 20 ] = 0
       VLMX2 [ 20 ] = 0
     VLMZB [ 20 ] = 0
      VLMZ1 [ 20 ] = 0
        VLMZ2 [ 20 ] = 0
     VLMSB [ 20 ] = 0
      VLMS1 [ 20 ] = 0
       VLMS2 [ 20 ] = 0
     VLMCB [ 20 ] = 0
      VLMC1 [ 20 ] = 0
       VLMC2 [ 20 ] = 0
     VLMMB [ 20 ] = 0
      VLMM1 [ 20 ] = 0
       VLMM2 [ 20 ] = 0
     VLMXB [ 21 ] = 0
      VLMX1 [ 21 ] = 0
       VLMX2 [ 21 ] = 0
     VLMZB [ 21 ] = 0
      VLMZ1 [ 21 ] = 0
        VLMZ2 [ 21 ] = 0
     VLMSB [ 21 ] = 0
      VLMS1 [ 21 ] = 0
       VLMS2 [ 21 ] = 0
     VLMCB [ 21 ] = 0
      VLMC1 [ 21 ] = 0
       VLMC2 [ 21 ] = 0
     VLMMB [ 21 ] = 0
      VLMM1 [ 21 ] = 0
       VLMM2 [ 21 ] = 0
     VLMXB [ 22 ] = 0
      VLMX1 [ 22 ] = 0
       VLMX2 [ 22 ] = 0
     VLMZB [ 22 ] = 0
      VLMZ1 [ 22 ] = 0
        VLMZ2 [ 22 ] = 0
     VLMSB [ 22 ] = 0
      VLMS1 [ 22 ] = 0
       VLMS2 [ 22 ] = 0
     VLMCB [ 22 ] = 0
      VLMC1 [ 22 ] = 0
       VLMC2 [ 22 ] = 0
     VLMMB [ 22 ] = 0
      VLMM1 [ 22 ] = 0
       VLMM2 [ 22 ] = 0
     VLMXB [ 23 ] = 0
      VLMX1 [ 23 ] = 0
       VLMX2 [ 23 ] = 0
     VLMZB [ 23 ] = 0
      VLMZ1 [ 23 ] = 0
        VLMZ2 [ 23 ] = 0
     VLMSB [ 23 ] = 0
      VLMS1 [ 23 ] = 0
       VLMS2 [ 23 ] = 0
     VLMCB [ 23 ] = 0
      VLMC1 [ 23 ] = 0
       VLMC2 [ 23 ] = 0
     VLMMB [ 23 ] = 0
      VLMM1 [ 23 ] = 0
       VLMM2 [ 23 ] = 0
     VLMXB [ 24 ] = 0
      VLMX1 [ 24 ] = 0
       VLMX2 [ 24 ] = 0
     VLMZB [ 24 ] = 0
      VLMZ1 [ 24 ] = 0
        VLMZ2 [ 24 ] = 0
     VLMSB [ 24 ] = 0
      VLMS1 [ 24 ] = 0
       VLMS2 [ 24 ] = 0
     VLMCB [ 24 ] = 0
      VLMC1 [ 24 ] = 0
       VLMC2 [ 24 ] = 0
     VLMMB [ 24 ] = 0
      VLMM1 [ 24 ] = 0
       VLMM2 [ 24 ] = 0
     VLMXB [ 25 ] = 0
      VLMX1 [ 25 ] = 0
       VLMX2 [ 25 ] = 0
     VLMZB [ 25 ] = 0
      VLMZ1 [ 25 ] = 0
        VLMZ2 [ 25 ] = 0
     VLMSB [ 25 ] = 0
      VLMS1 [ 25 ] = 0
       VLMS2 [ 25 ] = 0
     VLMCB [ 25 ] = 0
      VLMC1 [ 25 ] = 0
       VLMC2 [ 25 ] = 0
     VLMMB [ 25 ] = 0
      VLMM1 [ 25 ] = 0
       VLMM2 [ 25 ] = 0
     VLMXB [ 26 ] = 0
      VLMX1 [ 26 ] = 0
       VLMX2 [ 26 ] = 0
     VLMZB [ 26 ] = 0
      VLMZ1 [ 26 ] = 0
        VLMZ2 [ 26 ] = 0
     VLMSB [ 26 ] = 0
      VLMS1 [ 26 ] = 0
       VLMS2 [ 26 ] = 0
     VLMCB [ 26 ] = 0
      VLMC1 [ 26 ] = 0
       VLMC2 [ 26 ] = 0
     VLMMB [ 26 ] = 0
      VLMM1 [ 26 ] = 0
       VLMM2 [ 26 ] = 0
     VLMXB [ 27 ] = 0
      VLMX1 [ 27 ] = 0
       VLMX2 [ 27 ] = 0
     VLMZB [ 27 ] = 0
      VLMZ1 [ 27 ] = 0
        VLMZ2 [ 27 ] = 0
     VLMSB [ 27 ] = 0
      VLMS1 [ 27 ] = 0
       VLMS2 [ 27 ] = 0
     VLMCB [ 27 ] = 0
      VLMC1 [ 27 ] = 0
       VLMC2 [ 27 ] = 0
     VLMMB [ 27 ] = 0
      VLMM1 [ 27 ] = 0
       VLMM2 [ 27 ] = 0
     VLMXB [ 28 ] = 0
      VLMX1 [ 28 ] = 0
       VLMX2 [ 28 ] = 0
     VLMZB [ 28 ] = 0
      VLMZ1 [ 28 ] = 0
        VLMZ2 [ 28 ] = 0
     VLMSB [ 28 ] = 0
      VLMS1 [ 28 ] = 0
       VLMS2 [ 28 ] = 0
     VLMCB [ 28 ] = 0
      VLMC1 [ 28 ] = 0
       VLMC2 [ 28 ] = 0
     VLMMB [ 28 ] = 0
      VLMM1 [ 28 ] = 0
       VLMM2 [ 28 ] = 0
     VLMXB [ 29 ] = 0
      VLMX1 [ 29 ] = 0
       VLMX2 [ 29 ] = 0
     VLMZB [ 29 ] = 0
      VLMZ1 [ 29 ] = 0
        VLMZ2 [ 29 ] = 0
     VLMSB [ 29 ] = 0
      VLMS1 [ 29 ] = 0
       VLMS2 [ 29 ] = 0
     VLMCB [ 29 ] = 0
      VLMC1 [ 29 ] = 0
       VLMC2 [ 29 ] = 0
     VLMMB [ 29 ] = 0
      VLMM1 [ 29 ] = 0
       VLMM2 [ 29 ] = 0
     VLMXB [ 30 ] = 0
      VLMX1 [ 30 ] = 0
       VLMX2 [ 30 ] = 0
     VLMZB [ 30 ] = 0
      VLMZ1 [ 30 ] = 0
        VLMZ2 [ 30 ] = 0
     VLMSB [ 30 ] = 0
      VLMS1 [ 30 ] = 0
       VLMS2 [ 30 ] = 0
     VLMCB [ 30 ] = 0
      VLMC1 [ 30 ] = 0
       VLMC2 [ 30 ] = 0
     VLMMB [ 30 ] = 0
      VLMM1 [ 30 ] = 0
       VLMM2 [ 30 ] = 0
     VLMXB [ 31 ] = 0
      VLMX1 [ 31 ] = 0
       VLMX2 [ 31 ] = 0
     VLMZB [ 31 ] = 0
      VLMZ1 [ 31 ] = 0
        VLMZ2 [ 31 ] = 0
     VLMSB [ 31 ] = 0
      VLMS1 [ 31 ] = 0
       VLMS2 [ 31 ] = 0
     VLMCB [ 31 ] = 0
      VLMC1 [ 31 ] = 0
       VLMC2 [ 31 ] = 0
     VLMMB [ 31 ] = 0
      VLMM1 [ 31 ] = 0
       VLMM2 [ 31 ] = 0
     VLMXB [ 32 ] = 0
      VLMX1 [ 32 ] = 0
       VLMX2 [ 32 ] = 0
     VLMZB [ 32 ] = 0
      VLMZ1 [ 32 ] = 0
        VLMZ2 [ 32 ] = 0
     VLMSB [ 32 ] = 0
      VLMS1 [ 32 ] = 0
       VLMS2 [ 32 ] = 0
     VLMCB [ 32 ] = 0
      VLMC1 [ 32 ] = 0
       VLMC2 [ 32 ] = 0
     VLMMB [ 32 ] = 0
      VLMM1 [ 32 ] = 0
       VLMM2 [ 32 ] = 0
     VLMXB [ 33 ] = 0
      VLMX1 [ 33 ] = 0
       VLMX2 [ 33 ] = 0
     VLMZB [ 33 ] = 0
      VLMZ1 [ 33 ] = 0
        VLMZ2 [ 33 ] = 0
     VLMSB [ 33 ] = 0
      VLMS1 [ 33 ] = 0
       VLMS2 [ 33 ] = 0
     VLMCB [ 33 ] = 0
      VLMC1 [ 33 ] = 0
       VLMC2 [ 33 ] = 0
     VLMMB [ 33 ] = 0
      VLMM1 [ 33 ] = 0
       VLMM2 [ 33 ] = 0
     VLMXB [ 34 ] = 0
      VLMX1 [ 34 ] = 0
       VLMX2 [ 34 ] = 0
     VLMZB [ 34 ] = 0
      VLMZ1 [ 34 ] = 0
        VLMZ2 [ 34 ] = 0
     VLMSB [ 34 ] = 0
      VLMS1 [ 34 ] = 0
       VLMS2 [ 34 ] = 0
     VLMCB [ 34 ] = 0
      VLMC1 [ 34 ] = 0
       VLMC2 [ 34 ] = 0
     VLMMB [ 34 ] = 0
      VLMM1 [ 34 ] = 0
       VLMM2 [ 34 ] = 0
     VLMXB [ 35 ] = 0
      VLMX1 [ 35 ] = 0
       VLMX2 [ 35 ] = 0
     VLMZB [ 35 ] = 0
      VLMZ1 [ 35 ] = 0
        VLMZ2 [ 35 ] = 0
     VLMSB [ 35 ] = 0
      VLMS1 [ 35 ] = 0
       VLMS2 [ 35 ] = 0
     VLMCB [ 35 ] = 0
      VLMC1 [ 35 ] = 0
       VLMC2 [ 35 ] = 0
     VLMMB [ 35 ] = 0
      VLMM1 [ 35 ] = 0
       VLMM2 [ 35 ] = 0
     VLMXB [ 36 ] = 0
      VLMX1 [ 36 ] = 0
       VLMX2 [ 36 ] = 0
     VLMZB [ 36 ] = 0
      VLMZ1 [ 36 ] = 0
        VLMZ2 [ 36 ] = 0
     VLMSB [ 36 ] = 0
      VLMS1 [ 36 ] = 0
       VLMS2 [ 36 ] = 0
     VLMCB [ 36 ] = 0
      VLMC1 [ 36 ] = 0
       VLMC2 [ 36 ] = 0
     VLMMB [ 36 ] = 0
      VLMM1 [ 36 ] = 0
       VLMM2 [ 36 ] = 0
     VLMXB [ 37 ] = 0
      VLMX1 [ 37 ] = 0
       VLMX2 [ 37 ] = 0
     VLMZB [ 37 ] = 0
      VLMZ1 [ 37 ] = 0
        VLMZ2 [ 37 ] = 0
     VLMSB [ 37 ] = 0
      VLMS1 [ 37 ] = 0
       VLMS2 [ 37 ] = 0
     VLMCB [ 37 ] = 0
      VLMC1 [ 37 ] = 0
       VLMC2 [ 37 ] = 0
     VLMMB [ 37 ] = 0
      VLMM1 [ 37 ] = 0
       VLMM2 [ 37 ] = 0
     VLMXB [ 38 ] = 0
      VLMX1 [ 38 ] = 0
       VLMX2 [ 38 ] = 0
     VLMZB [ 38 ] = 0
      VLMZ1 [ 38 ] = 0
        VLMZ2 [ 38 ] = 0
     VLMSB [ 38 ] = 0
      VLMS1 [ 38 ] = 0
       VLMS2 [ 38 ] = 0
     VLMCB [ 38 ] = 0
      VLMC1 [ 38 ] = 0
       VLMC2 [ 38 ] = 0
     VLMMB [ 38 ] = 0
      VLMM1 [ 38 ] = 0
       VLMM2 [ 38 ] = 0
     VLMXB [ 39 ] = 0
      VLMX1 [ 39 ] = 0
       VLMX2 [ 39 ] = 0
     VLMZB [ 39 ] = 0
      VLMZ1 [ 39 ] = 0
        VLMZ2 [ 39 ] = 0
     VLMSB [ 39 ] = 0
      VLMS1 [ 39 ] = 0
       VLMS2 [ 39 ] = 0
     VLMCB [ 39 ] = 0
      VLMC1 [ 39 ] = 0
       VLMC2 [ 39 ] = 0
     VLMMB [ 39 ] = 0
      VLMM1 [ 39 ] = 0
       VLMM2 [ 39 ] = 0
     VLMXB [ 40 ] = 0
      VLMX1 [ 40 ] = 0
       VLMX2 [ 40 ] = 0
     VLMZB [ 40 ] = 0
      VLMZ1 [ 40 ] = 0
        VLMZ2 [ 40 ] = 0
     VLMSB [ 40 ] = 0
      VLMS1 [ 40 ] = 0
       VLMS2 [ 40 ] = 0
     VLMCB [ 40 ] = 0
      VLMC1 [ 40 ] = 0
       VLMC2 [ 40 ] = 0
     VLMMB [ 40 ] = 0
      VLMM1 [ 40 ] = 0
       VLMM2 [ 40 ] = 0
     VLMXB [ 41 ] = 0
      VLMX1 [ 41 ] = 0
       VLMX2 [ 41 ] = 0
     VLMZB [ 41 ] = 0
      VLMZ1 [ 41 ] = 0
        VLMZ2 [ 41 ] = 0
     VLMSB [ 41 ] = 0
      VLMS1 [ 41 ] = 0
       VLMS2 [ 41 ] = 0
     VLMCB [ 41 ] = 0
      VLMC1 [ 41 ] = 0
       VLMC2 [ 41 ] = 0
     VLMMB [ 41 ] = 0
      VLMM1 [ 41 ] = 0
       VLMM2 [ 41 ] = 0
     VLMXB [ 42 ] = 0
      VLMX1 [ 42 ] = 0
       VLMX2 [ 42 ] = 0
     VLMZB [ 42 ] = 0
      VLMZ1 [ 42 ] = 0
        VLMZ2 [ 42 ] = 0
     VLMSB [ 42 ] = 0
      VLMS1 [ 42 ] = 0
       VLMS2 [ 42 ] = 0
     VLMCB [ 42 ] = 0
      VLMC1 [ 42 ] = 0
       VLMC2 [ 42 ] = 0
     VLMMB [ 42 ] = 0
      VLMM1 [ 42 ] = 0
       VLMM2 [ 42 ] = 0
     VLMXB [ 43 ] = 0
      VLMX1 [ 43 ] = 0
       VLMX2 [ 43 ] = 0
     VLMZB [ 43 ] = 0
      VLMZ1 [ 43 ] = 0
        VLMZ2 [ 43 ] = 0
     VLMSB [ 43 ] = 0
      VLMS1 [ 43 ] = 0
       VLMS2 [ 43 ] = 0
     VLMCB [ 43 ] = 0
      VLMC1 [ 43 ] = 0
       VLMC2 [ 43 ] = 0
     VLMMB [ 43 ] = 0
      VLMM1 [ 43 ] = 0
       VLMM2 [ 43 ] = 0
     VLMXB [ 44 ] = 0
      VLMX1 [ 44 ] = 0
       VLMX2 [ 44 ] = 0
     VLMZB [ 44 ] = 0
      VLMZ1 [ 44 ] = 0
        VLMZ2 [ 44 ] = 0
     VLMSB [ 44 ] = 0
      VLMS1 [ 44 ] = 0
       VLMS2 [ 44 ] = 0
     VLMCB [ 44 ] = 0
      VLMC1 [ 44 ] = 0
       VLMC2 [ 44 ] = 0
     VLMMB [ 44 ] = 0
      VLMM1 [ 44 ] = 0
       VLMM2 [ 44 ] = 0
     VLMXB [ 45 ] = 0
      VLMX1 [ 45 ] = 0
       VLMX2 [ 45 ] = 0
     VLMZB [ 45 ] = 0
      VLMZ1 [ 45 ] = 0
        VLMZ2 [ 45 ] = 0
     VLMSB [ 45 ] = 0
      VLMS1 [ 45 ] = 0
       VLMS2 [ 45 ] = 0
     VLMCB [ 45 ] = 0
      VLMC1 [ 45 ] = 0
       VLMC2 [ 45 ] = 0
     VLMMB [ 45 ] = 0
      VLMM1 [ 45 ] = 0
       VLMM2 [ 45 ] = 0
     VLMXB [ 46 ] = 0
      VLMX1 [ 46 ] = 0
       VLMX2 [ 46 ] = 0
     VLMZB [ 46 ] = 0
      VLMZ1 [ 46 ] = 0
        VLMZ2 [ 46 ] = 0
     VLMSB [ 46 ] = 0
      VLMS1 [ 46 ] = 0
       VLMS2 [ 46 ] = 0
     VLMCB [ 46 ] = 0
      VLMC1 [ 46 ] = 0
       VLMC2 [ 46 ] = 0
     VLMMB [ 46 ] = 0
      VLMM1 [ 46 ] = 0
       VLMM2 [ 46 ] = 0
     VLMXB [ 47 ] = 0
      VLMX1 [ 47 ] = 0
       VLMX2 [ 47 ] = 0
     VLMZB [ 47 ] = 0
      VLMZ1 [ 47 ] = 0
        VLMZ2 [ 47 ] = 0
     VLMSB [ 47 ] = 0
      VLMS1 [ 47 ] = 0
       VLMS2 [ 47 ] = 0
     VLMCB [ 47 ] = 0
      VLMC1 [ 47 ] = 0
       VLMC2 [ 47 ] = 0
     VLMMB [ 47 ] = 0
      VLMM1 [ 47 ] = 0
       VLMM2 [ 47 ] = 0
     VLMXB [ 48 ] = 0
      VLMX1 [ 48 ] = 0
       VLMX2 [ 48 ] = 0
     VLMZB [ 48 ] = 0
      VLMZ1 [ 48 ] = 0
        VLMZ2 [ 48 ] = 0
     VLMSB [ 48 ] = 0
      VLMS1 [ 48 ] = 0
       VLMS2 [ 48 ] = 0
     VLMCB [ 48 ] = 0
      VLMC1 [ 48 ] = 0
       VLMC2 [ 48 ] = 0
     VLMMB [ 48 ] = 0
      VLMM1 [ 48 ] = 0
       VLMM2 [ 48 ] = 0
     VLMXB [ 49 ] = 0
      VLMX1 [ 49 ] = 0
       VLMX2 [ 49 ] = 0
     VLMZB [ 49 ] = 0
      VLMZ1 [ 49 ] = 0
        VLMZ2 [ 49 ] = 0
     VLMSB [ 49 ] = 0
      VLMS1 [ 49 ] = 0
       VLMS2 [ 49 ] = 0
     VLMCB [ 49 ] = 0
      VLMC1 [ 49 ] = 0
       VLMC2 [ 49 ] = 0
     VLMMB [ 49 ] = 0
      VLMM1 [ 49 ] = 0
       VLMM2 [ 49 ] = 0
     VLMXB [ 50 ] = 0
      VLMX1 [ 50 ] = 0
       VLMX2 [ 50 ] = 0
     VLMZB [ 50 ] = 0
      VLMZ1 [ 50 ] = 0
        VLMZ2 [ 50 ] = 0
     VLMSB [ 50 ] = 0
      VLMS1 [ 50 ] = 0
       VLMS2 [ 50 ] = 0
     VLMCB [ 50 ] = 0
      VLMC1 [ 50 ] = 0
       VLMC2 [ 50 ] = 0
     VLMMB [ 50 ] = 0
      VLMM1 [ 50 ] = 0
       VLMM2 [ 50 ] = 0
     VLMXB [ 51 ] = 0
      VLMX1 [ 51 ] = 0
       VLMX2 [ 51 ] = 0
     VLMZB [ 51 ] = 0
      VLMZ1 [ 51 ] = 0
        VLMZ2 [ 51 ] = 0
     VLMSB [ 51 ] = 0
      VLMS1 [ 51 ] = 0
       VLMS2 [ 51 ] = 0
     VLMCB [ 51 ] = 0
      VLMC1 [ 51 ] = 0
       VLMC2 [ 51 ] = 0
     VLMMB [ 51 ] = 0
      VLMM1 [ 51 ] = 0
       VLMM2 [ 51 ] = 0
     VLMXB [ 52 ] = 0
      VLMX1 [ 52 ] = 0
       VLMX2 [ 52 ] = 0
     VLMZB [ 52 ] = 0
      VLMZ1 [ 52 ] = 0
        VLMZ2 [ 52 ] = 0
     VLMSB [ 52 ] = 0
      VLMS1 [ 52 ] = 0
       VLMS2 [ 52 ] = 0
     VLMCB [ 52 ] = 0
      VLMC1 [ 52 ] = 0
       VLMC2 [ 52 ] = 0
     VLMMB [ 52 ] = 0
      VLMM1 [ 52 ] = 0
       VLMM2 [ 52 ] = 0
     VLMXB [ 53 ] = 0
      VLMX1 [ 53 ] = 0
       VLMX2 [ 53 ] = 0
     VLMZB [ 53 ] = 0
      VLMZ1 [ 53 ] = 0
        VLMZ2 [ 53 ] = 0
     VLMSB [ 53 ] = 0
      VLMS1 [ 53 ] = 0
       VLMS2 [ 53 ] = 0
     VLMCB [ 53 ] = 0
      VLMC1 [ 53 ] = 0
       VLMC2 [ 53 ] = 0
     VLMMB [ 53 ] = 0
      VLMM1 [ 53 ] = 0
       VLMM2 [ 53 ] = 0
     VLMXB [ 54 ] = 0
      VLMX1 [ 54 ] = 0
       VLMX2 [ 54 ] = 0
     VLMZB [ 54 ] = 0
      VLMZ1 [ 54 ] = 0
        VLMZ2 [ 54 ] = 0
     VLMSB [ 54 ] = 0
      VLMS1 [ 54 ] = 0
       VLMS2 [ 54 ] = 0
     VLMCB [ 54 ] = 0
      VLMC1 [ 54 ] = 0
       VLMC2 [ 54 ] = 0
     VLMMB [ 54 ] = 0
      VLMM1 [ 54 ] = 0
       VLMM2 [ 54 ] = 0
     VLMXB [ 55 ] = 0
      VLMX1 [ 55 ] = 0
       VLMX2 [ 55 ] = 0
     VLMZB [ 55 ] = 0
      VLMZ1 [ 55 ] = 0
        VLMZ2 [ 55 ] = 0
     VLMSB [ 55 ] = 0
      VLMS1 [ 55 ] = 0
       VLMS2 [ 55 ] = 0
     VLMCB [ 55 ] = 0
      VLMC1 [ 55 ] = 0
       VLMC2 [ 55 ] = 0
     VLMMB [ 55 ] = 0
      VLMM1 [ 55 ] = 0
       VLMM2 [ 55 ] = 0
     VLMXB [ 56 ] = 0
      VLMX1 [ 56 ] = 0
       VLMX2 [ 56 ] = 0
     VLMZB [ 56 ] = 0
      VLMZ1 [ 56 ] = 0
        VLMZ2 [ 56 ] = 0
     VLMSB [ 56 ] = 0
      VLMS1 [ 56 ] = 0
       VLMS2 [ 56 ] = 0
     VLMCB [ 56 ] = 0
      VLMC1 [ 56 ] = 0
       VLMC2 [ 56 ] = 0
     VLMMB [ 56 ] = 0
      VLMM1 [ 56 ] = 0
       VLMM2 [ 56 ] = 0
     VLMXB [ 57 ] = 0
      VLMX1 [ 57 ] = 0
       VLMX2 [ 57 ] = 0
     VLMZB [ 57 ] = 0
      VLMZ1 [ 57 ] = 0
        VLMZ2 [ 57 ] = 0
     VLMSB [ 57 ] = 0
      VLMS1 [ 57 ] = 0
       VLMS2 [ 57 ] = 0
     VLMCB [ 57 ] = 0
      VLMC1 [ 57 ] = 0
       VLMC2 [ 57 ] = 0
     VLMMB [ 57 ] = 0
      VLMM1 [ 57 ] = 0
       VLMM2 [ 57 ] = 0
     VLMXB [ 58 ] = 0
      VLMX1 [ 58 ] = 0
       VLMX2 [ 58 ] = 0
     VLMZB [ 58 ] = 0
      VLMZ1 [ 58 ] = 0
        VLMZ2 [ 58 ] = 0
     VLMSB [ 58 ] = 0
      VLMS1 [ 58 ] = 0
       VLMS2 [ 58 ] = 0
     VLMCB [ 58 ] = 0
      VLMC1 [ 58 ] = 0
       VLMC2 [ 58 ] = 0
     VLMMB [ 58 ] = 0
      VLMM1 [ 58 ] = 0
       VLMM2 [ 58 ] = 0
     VLMXB [ 59 ] = 0
      VLMX1 [ 59 ] = 0
       VLMX2 [ 59 ] = 0
     VLMZB [ 59 ] = 0
      VLMZ1 [ 59 ] = 0
        VLMZ2 [ 59 ] = 0
     VLMSB [ 59 ] = 0
      VLMS1 [ 59 ] = 0
       VLMS2 [ 59 ] = 0
     VLMCB [ 59 ] = 0
      VLMC1 [ 59 ] = 0
       VLMC2 [ 59 ] = 0
     VLMMB [ 59 ] = 0
      VLMM1 [ 59 ] = 0
       VLMM2 [ 59 ] = 0
     VLMXB [ 60 ] = 0
      VLMX1 [ 60 ] = 0
       VLMX2 [ 60 ] = 0
     VLMZB [ 60 ] = 0
      VLMZ1 [ 60 ] = 0
        VLMZ2 [ 60 ] = 0
     VLMSB [ 60 ] = 0
      VLMS1 [ 60 ] = 0
       VLMS2 [ 60 ] = 0
     VLMCB [ 60 ] = 0
      VLMC1 [ 60 ] = 0
       VLMC2 [ 60 ] = 0
     VLMMB [ 60 ] = 0
      VLMM1 [ 60 ] = 0
       VLMM2 [ 60 ] = 0
     VLMXB [ 61 ] = 0
      VLMX1 [ 61 ] = 0
       VLMX2 [ 61 ] = 0
     VLMZB [ 61 ] = 0
      VLMZ1 [ 61 ] = 0
        VLMZ2 [ 61 ] = 0
     VLMSB [ 61 ] = 0
      VLMS1 [ 61 ] = 0
       VLMS2 [ 61 ] = 0
     VLMCB [ 61 ] = 0
      VLMC1 [ 61 ] = 0
       VLMC2 [ 61 ] = 0
     VLMMB [ 61 ] = 0
      VLMM1 [ 61 ] = 0
       VLMM2 [ 61 ] = 0
     VLMXB [ 62 ] = 0
      VLMX1 [ 62 ] = 0
       VLMX2 [ 62 ] = 0
     VLMZB [ 62 ] = 0
      VLMZ1 [ 62 ] = 0
        VLMZ2 [ 62 ] = 0
     VLMSB [ 62 ] = 0
      VLMS1 [ 62 ] = 0
       VLMS2 [ 62 ] = 0
     VLMCB [ 62 ] = 0
      VLMC1 [ 62 ] = 0
       VLMC2 [ 62 ] = 0
     VLMMB [ 62 ] = 0
      VLMM1 [ 62 ] = 0
       VLMM2 [ 62 ] = 0
     VLMXB [ 63 ] = 0
      VLMX1 [ 63 ] = 0
       VLMX2 [ 63 ] = 0
     VLMZB [ 63 ] = 0
      VLMZ1 [ 63 ] = 0
        VLMZ2 [ 63 ] = 0
     VLMSB [ 63 ] = 0
      VLMS1 [ 63 ] = 0
       VLMS2 [ 63 ] = 0
     VLMCB [ 63 ] = 0
      VLMC1 [ 63 ] = 0
       VLMC2 [ 63 ] = 0
     VLMMB [ 63 ] = 0
      VLMM1 [ 63 ] = 0
       VLMM2 [ 63 ] = 0
     VLMXB [ 64 ] = 0
      VLMX1 [ 64 ] = 0
       VLMX2 [ 64 ] = 0
     VLMZB [ 64 ] = 0
      VLMZ1 [ 64 ] = 0
        VLMZ2 [ 64 ] = 0
     VLMSB [ 64 ] = 0
      VLMS1 [ 64 ] = 0
       VLMS2 [ 64 ] = 0
     VLMCB [ 64 ] = 0
      VLMC1 [ 64 ] = 0
       VLMC2 [ 64 ] = 0
     VLMMB [ 64 ] = 0
      VLMM1 [ 64 ] = 0
       VLMM2 [ 64 ] = 0
     M02
    Code:
     VLMXB [ 1 ] = 0
     VLMX1 [ 1 ] = 0
     VLMX2 [ 1 ] = 0
     VLMZB [ 1 ] = 0
     VLMZ1 [ 1 ] = 0
     VLMZ2 [ 1 ] = 0
     VLMSB [ 1 ] = 0
     VLMS1 [ 1 ] = 0
     VLMS2 [ 1 ] = 0
     VLMCB [ 1 ] = 0
     VLMC1 [ 1 ] = 0
     VLMC2 [ 1 ] = 0
     VLMMB [ 1 ] = 0
     VLMM1 [ 1 ] = 0
     VLMM2 [ 1 ] = 0
     VLMXB [ 2 ] = 0
     VLMX1 [ 2 ] = 0
     VLMX2 [ 2 ] = 0
     VLMZB [ 2 ] = 0
     VLMZ1 [ 2 ] = 0
     VLMZ2 [ 2 ] = 0
     VLMSB [ 2 ] = 0
     VLMS1 [ 2 ] = 0
     VLMS2 [ 2 ] = 0
     VLMCB [ 2 ] = 0
     VLMC1 [ 2 ] = 0
     VLMC2 [ 2 ] = 0
     VLMMB [ 2 ] = 0
     VLMM1 [ 2 ] = 0
     VLMM2 [ 2 ] = 0
     VLMXB [ 3 ] = 0
     VLMX1 [ 3 ] = 0
     VLMX2 [ 3 ] = 0
     VLMZB [ 3 ] = 0
     VLMZ1 [ 3 ] = 0
     VLMZ2 [ 3 ] = 0
     VLMSB [ 3 ] = 0
     VLMS1 [ 3 ] = 0
     VLMS2 [ 3 ] = 0
     VLMCB [ 3 ] = 0
     VLMC1 [ 3 ] = 0
     VLMC2 [ 3 ] = 0
     VLMMB [ 3 ] = 0
     VLMM1 [ 3 ] = 0
     VLMM2 [ 3 ] = 0
     VLMXB [ 4 ] = 0
     VLMX1 [ 4 ] = 0
     VLMX2 [ 4 ] = 0
     VLMZB [ 4 ] = 0
     VLMZ1 [ 4 ] = 0
     VLMZ2 [ 4 ] = 0
     VLMSB [ 4 ] = 0
     VLMS1 [ 4 ] = 0
     VLMS2 [ 4 ] = 0
     VLMCB [ 4 ] = 0
     VLMC1 [ 4 ] = 0
     VLMC2 [ 4 ] = 0
     VLMMB [ 4 ] = 0
     VLMM1 [ 4 ] = 0
     VLMM2 [ 4 ] = 0
     VLMXB [ 5 ] = 0
     VLMX1 [ 5 ] = 0
     VLMX2 [ 5 ] = 0
     VLMZB [ 5 ] = 0
     VLMZ1 [ 5 ] = 0
     VLMZ2 [ 5 ] = 0
     VLMSB [ 5 ] = 0
     VLMS1 [ 5 ] = 0
     VLMS2 [ 5 ] = 0
     VLMCB [ 5 ] = 0
     VLMC1 [ 5 ] = 0
     VLMC2 [ 5 ] = 0
     VLMMB [ 5 ] = 0
     VLMM1 [ 5 ] = 0
     VLMM2 [ 5 ] = 0
     VLMXB [ 6 ] = 0
     VLMX1 [ 6 ] = 0
     VLMX2 [ 6 ] = 0
     VLMZB [ 6 ] = 0
     VLMZ1 [ 6 ] = 0
     VLMZ2 [ 6 ] = 0
     VLMSB [ 6 ] = 0
     VLMS1 [ 6 ] = 0
     VLMS2 [ 6 ] = 0
     VLMCB [ 6 ] = 0
     VLMC1 [ 6 ] = 0
     VLMC2 [ 6 ] = 0
     VLMMB [ 6 ] = 0
     VLMM1 [ 6 ] = 0
     VLMM2 [ 6 ] = 0
     VLMXB [ 7 ] = 0
     VLMX1 [ 7 ] = 0
     VLMX2 [ 7 ] = 0
     VLMZB [ 7 ] = 0
     VLMZ1 [ 7 ] = 0
     VLMZ2 [ 7 ] = 0
     VLMSB [ 7 ] = 0
     VLMS1 [ 7 ] = 0
     VLMS2 [ 7 ] = 0
     VLMCB [ 7 ] = 0
     VLMC1 [ 7 ] = 0
     VLMC2 [ 7 ] = 0
     VLMMB [ 7 ] = 0
     VLMM1 [ 7 ] = 0
     VLMM2 [ 7 ] = 0
     VLMXB [ 8 ] = 0
     VLMX1 [ 8 ] = 0
     VLMX2 [ 8 ] = 0
     VLMZB [ 8 ] = 0
     VLMZ1 [ 8 ] = 0
     VLMZ2 [ 8 ] = 0
     VLMSB [ 8 ] = 0
     VLMS1 [ 8 ] = 0
     VLMS2 [ 8 ] = 0
     VLMCB [ 8 ] = 0
     VLMC1 [ 8 ] = 0
     VLMC2 [ 8 ] = 0
     VLMMB [ 8 ] = 0
     VLMM1 [ 8 ] = 0
     VLMM2 [ 8 ] = 0
     VLMXB [ 9 ] = 0
     VLMX1 [ 9 ] = 0
     VLMX2 [ 9 ] = 0
     VLMZB [ 9 ] = 0
     VLMZ1 [ 9 ] = 0
     VLMZ2 [ 9 ] = 0
     VLMSB [ 9 ] = 0
     VLMS1 [ 9 ] = 0
     VLMS2 [ 9 ] = 0
     VLMCB [ 9 ] = 0
     VLMC1 [ 9 ] = 0
     VLMC2 [ 9 ] = 0
     VLMMB [ 9 ] = 0
     VLMM1 [ 9 ] = 0
     VLMM2 [ 9 ] = 0
     VLMXB [ 10 ] = 0
     VLMX1 [ 10 ] = 0
     VLMX2 [ 10 ] = 0
     VLMZB [ 10 ] = 0
     VLMZ1 [ 10 ] = 0
     VLMZ2 [ 10 ] = 0
     VLMSB [ 10 ] = 0
     VLMS1 [ 10 ] = 0
     VLMS2 [ 10 ] = 0
     VLMCB [ 10 ] = 0
     VLMC1 [ 10 ] = 0
     VLMC2 [ 10 ] = 0
     VLMMB [ 10 ] = 0
     VLMM1 [ 10 ] = 0
     VLMM2 [ 10 ] = 0
     VLMXB [ 11 ] = 0
     VLMX1 [ 11 ] = 0
     VLMX2 [ 11 ] = 0
     VLMZB [ 11 ] = 0
     VLMZ1 [ 11 ] = 0
     VLMZ2 [ 11 ] = 0
     VLMSB [ 11 ] = 0
     VLMS1 [ 11 ] = 0
     VLMS2 [ 11 ] = 0
     VLMCB [ 11 ] = 0
     VLMC1 [ 11 ] = 0
     VLMC2 [ 11 ] = 0
     VLMMB [ 11 ] = 0
     VLMM1 [ 11 ] = 0
     VLMM2 [ 11 ] = 0
     VLMXB [ 12 ] = 0
     VLMX1 [ 12 ] = 0
     VLMX2 [ 12 ] = 0
     VLMZB [ 12 ] = 0
     VLMZ1 [ 12 ] = 0
     VLMZ2 [ 12 ] = 0
     VLMSB [ 12 ] = 0
     VLMS1 [ 12 ] = 0
     VLMS2 [ 12 ] = 0
     VLMCB [ 12 ] = 0
     VLMC1 [ 12 ] = 0
     VLMC2 [ 12 ] = 0
     VLMMB [ 12 ] = 0
     VLMM1 [ 12 ] = 0
     VLMM2 [ 12 ] = 0
     VLMXB [ 13 ] = 0
     VLMX1 [ 13 ] = 0
     VLMX2 [ 13 ] = 0
     VLMZB [ 13 ] = 0
     VLMZ1 [ 13 ] = 0
     VLMZ2 [ 13 ] = 0
     VLMSB [ 13 ] = 0
     VLMS1 [ 13 ] = 0
     VLMS2 [ 13 ] = 0
     VLMCB [ 13 ] = 0
     VLMC1 [ 13 ] = 0
     VLMC2 [ 13 ] = 0
     VLMMB [ 13 ] = 0
     VLMM1 [ 13 ] = 0
     VLMM2 [ 13 ] = 0
     VLMXB [ 14 ] = 0
     VLMX1 [ 14 ] = 0
     VLMX2 [ 14 ] = 0
     VLMZB [ 14 ] = 0
     VLMZ1 [ 14 ] = 0
     VLMZ2 [ 14 ] = 0
     VLMSB [ 14 ] = 0
     VLMS1 [ 14 ] = 0
     VLMS2 [ 14 ] = 0
     VLMCB [ 14 ] = 0
     VLMC1 [ 14 ] = 0
     VLMC2 [ 14 ] = 0
     VLMMB [ 14 ] = 0
     VLMM1 [ 14 ] = 0
     VLMM2 [ 14 ] = 0
     VLMXB [ 15 ] = 0
     VLMX1 [ 15 ] = 0
     VLMX2 [ 15 ] = 0
     VLMZB [ 15 ] = 0
     VLMZ1 [ 15 ] = 0
     VLMZ2 [ 15 ] = 0
     VLMSB [ 15 ] = 0
     VLMS1 [ 15 ] = 0
     VLMS2 [ 15 ] = 0
     VLMCB [ 15 ] = 0
     VLMC1 [ 15 ] = 0
     VLMC2 [ 15 ] = 0
     VLMMB [ 15 ] = 0
     VLMM1 [ 15 ] = 0
     VLMM2 [ 15 ] = 0
     VLMXB [ 16 ] = 0
     VLMX1 [ 16 ] = 0
     VLMX2 [ 16 ] = 0
     VLMZB [ 16 ] = 0
     VLMZ1 [ 16 ] = 0
     VLMZ2 [ 16 ] = 0
     VLMSB [ 16 ] = 0
     VLMS1 [ 16 ] = 0
     VLMS2 [ 16 ] = 0
     VLMCB [ 16 ] = 0
     VLMC1 [ 16 ] = 0
     VLMC2 [ 16 ] = 0
     VLMMB [ 16 ] = 0
     VLMM1 [ 16 ] = 0
     VLMM2 [ 16 ] = 0
     VLMXB [ 17 ] = 0
     VLMX1 [ 17 ] = 0
     VLMX2 [ 17 ] = 0
     VLMZB [ 17 ] = 0
     VLMZ1 [ 17 ] = 0
     VLMZ2 [ 17 ] = 0
     VLMSB [ 17 ] = 0
     VLMS1 [ 17 ] = 0
     VLMS2 [ 17 ] = 0
     VLMCB [ 17 ] = 0
     VLMC1 [ 17 ] = 0
     VLMC2 [ 17 ] = 0
     VLMMB [ 17 ] = 0
     VLMM1 [ 17 ] = 0
     VLMM2 [ 17 ] = 0
     VLMXB [ 18 ] = 0
     VLMX1 [ 18 ] = 0
     VLMX2 [ 18 ] = 0
     VLMZB [ 18 ] = 0
     VLMZ1 [ 18 ] = 0
     VLMZ2 [ 18 ] = 0
     VLMSB [ 18 ] = 0
     VLMS1 [ 18 ] = 0
     VLMS2 [ 18 ] = 0
     VLMCB [ 18 ] = 0
     VLMC1 [ 18 ] = 0
     VLMC2 [ 18 ] = 0
     VLMMB [ 18 ] = 0
     VLMM1 [ 18 ] = 0
     VLMM2 [ 18 ] = 0
     VLMXB [ 19 ] = 0
     VLMX1 [ 19 ] = 0
     VLMX2 [ 19 ] = 0
     VLMZB [ 19 ] = 0
     VLMZ1 [ 19 ] = 0
     VLMZ2 [ 19 ] = 0
     VLMSB [ 19 ] = 0
     VLMS1 [ 19 ] = 0
     VLMS2 [ 19 ] = 0
     VLMCB [ 19 ] = 0
     VLMC1 [ 19 ] = 0
     VLMC2 [ 19 ] = 0
     VLMMB [ 19 ] = 0
     VLMM1 [ 19 ] = 0
     VLMM2 [ 19 ] = 0
     VLMXB [ 20 ] = 0
     VLMX1 [ 20 ] = 0
     VLMX2 [ 20 ] = 0
     VLMZB [ 20 ] = 0
     VLMZ1 [ 20 ] = 0
     VLMZ2 [ 20 ] = 0
     VLMSB [ 20 ] = 0
     VLMS1 [ 20 ] = 0
     VLMS2 [ 20 ] = 0
     VLMCB [ 20 ] = 0
     VLMC1 [ 20 ] = 0
     VLMC2 [ 20 ] = 0
     VLMMB [ 20 ] = 0
     VLMM1 [ 20 ] = 0
     VLMM2 [ 20 ] = 0
     VLMXB [ 21 ] = 0
     VLMX1 [ 21 ] = 0
     VLMX2 [ 21 ] = 0
     VLMZB [ 21 ] = 0
     VLMZ1 [ 21 ] = 0
     VLMZ2 [ 21 ] = 0
     VLMSB [ 21 ] = 0
     VLMS1 [ 21 ] = 0
     VLMS2 [ 21 ] = 0
     VLMCB [ 21 ] = 0
     VLMC1 [ 21 ] = 0
     VLMC2 [ 21 ] = 0
     VLMMB [ 21 ] = 0
     VLMM1 [ 21 ] = 0
     VLMM2 [ 21 ] = 0
     VLMXB [ 22 ] = 0
     VLMX1 [ 22 ] = 0
     VLMX2 [ 22 ] = 0
     VLMZB [ 22 ] = 0
     VLMZ1 [ 22 ] = 0
     VLMZ2 [ 22 ] = 0
     VLMSB [ 22 ] = 0
     VLMS1 [ 22 ] = 0
     VLMS2 [ 22 ] = 0
     VLMCB [ 22 ] = 0
     VLMC1 [ 22 ] = 0
     VLMC2 [ 22 ] = 0
     VLMMB [ 22 ] = 0
     VLMM1 [ 22 ] = 0
     VLMM2 [ 22 ] = 0
     VLMXB [ 23 ] = 0
     VLMX1 [ 23 ] = 0
     VLMX2 [ 23 ] = 0
     VLMZB [ 23 ] = 0
     VLMZ1 [ 23 ] = 0
     VLMZ2 [ 23 ] = 0
     VLMSB [ 23 ] = 0
     VLMS1 [ 23 ] = 0
     VLMS2 [ 23 ] = 0
     VLMCB [ 23 ] = 0
     VLMC1 [ 23 ] = 0
     VLMC2 [ 23 ] = 0
     VLMMB [ 23 ] = 0
     VLMM1 [ 23 ] = 0
     VLMM2 [ 23 ] = 0
     VLMXB [ 24 ] = 0
     VLMX1 [ 24 ] = 0
     VLMX2 [ 24 ] = 0
     VLMZB [ 24 ] = 0
     VLMZ1 [ 24 ] = 0
     VLMZ2 [ 24 ] = 0
     VLMSB [ 24 ] = 0
     VLMS1 [ 24 ] = 0
     VLMS2 [ 24 ] = 0
     VLMCB [ 24 ] = 0
     VLMC1 [ 24 ] = 0
     VLMC2 [ 24 ] = 0
     VLMMB [ 24 ] = 0
     VLMM1 [ 24 ] = 0
     VLMM2 [ 24 ] = 0
     VLMXB [ 25 ] = 0
     VLMX1 [ 25 ] = 0
     VLMX2 [ 25 ] = 0
     VLMZB [ 25 ] = 0
     VLMZ1 [ 25 ] = 0
     VLMZ2 [ 25 ] = 0
     VLMSB [ 25 ] = 0
     VLMS1 [ 25 ] = 0
     VLMS2 [ 25 ] = 0
     VLMCB [ 25 ] = 0
     VLMC1 [ 25 ] = 0
     VLMC2 [ 25 ] = 0
     VLMMB [ 25 ] = 0
     VLMM1 [ 25 ] = 0
     VLMM2 [ 25 ] = 0
     VLMXB [ 26 ] = 0
     VLMX1 [ 26 ] = 0
     VLMX2 [ 26 ] = 0
     VLMZB [ 26 ] = 0
     VLMZ1 [ 26 ] = 0
     VLMZ2 [ 26 ] = 0
     VLMSB [ 26 ] = 0
     VLMS1 [ 26 ] = 0
     VLMS2 [ 26 ] = 0
     VLMCB [ 26 ] = 0
     VLMC1 [ 26 ] = 0
     VLMC2 [ 26 ] = 0
     VLMMB [ 26 ] = 0
     VLMM1 [ 26 ] = 0
     VLMM2 [ 26 ] = 0
     VLMXB [ 27 ] = 0
     VLMX1 [ 27 ] = 0
     VLMX2 [ 27 ] = 0
     VLMZB [ 27 ] = 0
     VLMZ1 [ 27 ] = 0
     VLMZ2 [ 27 ] = 0
     VLMSB [ 27 ] = 0
     VLMS1 [ 27 ] = 0
     VLMS2 [ 27 ] = 0
     VLMCB [ 27 ] = 0
     VLMC1 [ 27 ] = 0
     VLMC2 [ 27 ] = 0
     VLMMB [ 27 ] = 0
     VLMM1 [ 27 ] = 0
     VLMM2 [ 27 ] = 0
     VLMXB [ 28 ] = 0
     VLMX1 [ 28 ] = 0
     VLMX2 [ 28 ] = 0
     VLMZB [ 28 ] = 0
     VLMZ1 [ 28 ] = 0
     VLMZ2 [ 28 ] = 0
     VLMSB [ 28 ] = 0
     VLMS1 [ 28 ] = 0
     VLMS2 [ 28 ] = 0
     VLMCB [ 28 ] = 0
     VLMC1 [ 28 ] = 0
     VLMC2 [ 28 ] = 0
     VLMMB [ 28 ] = 0
     VLMM1 [ 28 ] = 0
     VLMM2 [ 28 ] = 0
     VLMXB [ 29 ] = 0
     VLMX1 [ 29 ] = 0
     VLMX2 [ 29 ] = 0
     VLMZB [ 29 ] = 0
     VLMZ1 [ 29 ] = 0
     VLMZ2 [ 29 ] = 0
     VLMSB [ 29 ] = 0
     VLMS1 [ 29 ] = 0
     VLMS2 [ 29 ] = 0
     VLMCB [ 29 ] = 0
     VLMC1 [ 29 ] = 0
     VLMC2 [ 29 ] = 0
     VLMMB [ 29 ] = 0
     VLMM1 [ 29 ] = 0
     VLMM2 [ 29 ] = 0
     VLMXB [ 30 ] = 0
     VLMX1 [ 30 ] = 0
     VLMX2 [ 30 ] = 0
     VLMZB [ 30 ] = 0
     VLMZ1 [ 30 ] = 0
     VLMZ2 [ 30 ] = 0
     VLMSB [ 30 ] = 0
     VLMS1 [ 30 ] = 0
     VLMS2 [ 30 ] = 0
     VLMCB [ 30 ] = 0
     VLMC1 [ 30 ] = 0
     VLMC2 [ 30 ] = 0
     VLMMB [ 30 ] = 0
     VLMM1 [ 30 ] = 0
     VLMM2 [ 30 ] = 0
     VLMXB [ 31 ] = 0
     VLMX1 [ 31 ] = 0
     VLMX2 [ 31 ] = 0
     VLMZB [ 31 ] = 0
     VLMZ1 [ 31 ] = 0
     VLMZ2 [ 31 ] = 0
     VLMSB [ 31 ] = 0
     VLMS1 [ 31 ] = 0
     VLMS2 [ 31 ] = 0
     VLMCB [ 31 ] = 0
     VLMC1 [ 31 ] = 0
     VLMC2 [ 31 ] = 0
     VLMMB [ 31 ] = 0
     VLMM1 [ 31 ] = 0
     VLMM2 [ 31 ] = 0
     VLMXB [ 32 ] = 0
     VLMX1 [ 32 ] = 0
     VLMX2 [ 32 ] = 0
     VLMZB [ 32 ] = 0
     VLMZ1 [ 32 ] = 0
     VLMZ2 [ 32 ] = 0
     VLMSB [ 32 ] = 0
     VLMS1 [ 32 ] = 0
     VLMS2 [ 32 ] = 0
     VLMCB [ 32 ] = 0
     VLMC1 [ 32 ] = 0
     VLMC2 [ 32 ] = 0
     VLMMB [ 32 ] = 0
     VLMM1 [ 32 ] = 0
     VLMM2 [ 32 ] = 0
     VLMXB [ 33 ] = 0
     VLMX1 [ 33 ] = 0
     VLMX2 [ 33 ] = 0
     VLMZB [ 33 ] = 0
     VLMZ1 [ 33 ] = 0
     VLMZ2 [ 33 ] = 0
     VLMSB [ 33 ] = 0
     VLMS1 [ 33 ] = 0
     VLMS2 [ 33 ] = 0
     VLMCB [ 33 ] = 0
     VLMC1 [ 33 ] = 0
     VLMC2 [ 33 ] = 0
     VLMMB [ 33 ] = 0
     VLMM1 [ 33 ] = 0
     VLMM2 [ 33 ] = 0
     VLMXB [ 34 ] = 0
     VLMX1 [ 34 ] = 0
     VLMX2 [ 34 ] = 0
     VLMZB [ 34 ] = 0
     VLMZ1 [ 34 ] = 0
     VLMZ2 [ 34 ] = 0
     VLMSB [ 34 ] = 0
     VLMS1 [ 34 ] = 0
     VLMS2 [ 34 ] = 0
     VLMCB [ 34 ] = 0
     VLMC1 [ 34 ] = 0
     VLMC2 [ 34 ] = 0
     VLMMB [ 34 ] = 0
     VLMM1 [ 34 ] = 0
     VLMM2 [ 34 ] = 0
     VLMXB [ 35 ] = 0
     VLMX1 [ 35 ] = 0
     VLMX2 [ 35 ] = 0
     VLMZB [ 35 ] = 0
     VLMZ1 [ 35 ] = 0
     VLMZ2 [ 35 ] = 0
     VLMSB [ 35 ] = 0
     VLMS1 [ 35 ] = 0
     VLMS2 [ 35 ] = 0
     VLMCB [ 35 ] = 0
     VLMC1 [ 35 ] = 0
     VLMC2 [ 35 ] = 0
     VLMMB [ 35 ] = 0
     VLMM1 [ 35 ] = 0
     VLMM2 [ 35 ] = 0
     VLMXB [ 36 ] = 0
     VLMX1 [ 36 ] = 0
     VLMX2 [ 36 ] = 0
     VLMZB [ 36 ] = 0
     VLMZ1 [ 36 ] = 0
     VLMZ2 [ 36 ] = 0
     VLMSB [ 36 ] = 0
     VLMS1 [ 36 ] = 0
     VLMS2 [ 36 ] = 0
     VLMCB [ 36 ] = 0
     VLMC1 [ 36 ] = 0
     VLMC2 [ 36 ] = 0
     VLMMB [ 36 ] = 0
     VLMM1 [ 36 ] = 0
     VLMM2 [ 36 ] = 0
     VLMXB [ 37 ] = 0
     VLMX1 [ 37 ] = 0
     VLMX2 [ 37 ] = 0
     VLMZB [ 37 ] = 0
     VLMZ1 [ 37 ] = 0
     VLMZ2 [ 37 ] = 0
     VLMSB [ 37 ] = 0
     VLMS1 [ 37 ] = 0
     VLMS2 [ 37 ] = 0
     VLMCB [ 37 ] = 0
     VLMC1 [ 37 ] = 0
     VLMC2 [ 37 ] = 0
     VLMMB [ 37 ] = 0
     VLMM1 [ 37 ] = 0
     VLMM2 [ 37 ] = 0
     VLMXB [ 38 ] = 0
     VLMX1 [ 38 ] = 0
     VLMX2 [ 38 ] = 0
     VLMZB [ 38 ] = 0
     VLMZ1 [ 38 ] = 0
     VLMZ2 [ 38 ] = 0
     VLMSB [ 38 ] = 0
     VLMS1 [ 38 ] = 0
     VLMS2 [ 38 ] = 0
     VLMCB [ 38 ] = 0
     VLMC1 [ 38 ] = 0
     VLMC2 [ 38 ] = 0
     VLMMB [ 38 ] = 0
     VLMM1 [ 38 ] = 0
     VLMM2 [ 38 ] = 0
     VLMXB [ 39 ] = 0
     VLMX1 [ 39 ] = 0
     VLMX2 [ 39 ] = 0
     VLMZB [ 39 ] = 0
     VLMZ1 [ 39 ] = 0
     VLMZ2 [ 39 ] = 0
     VLMSB [ 39 ] = 0
     VLMS1 [ 39 ] = 0
     VLMS2 [ 39 ] = 0
     VLMCB [ 39 ] = 0
     VLMC1 [ 39 ] = 0
     VLMC2 [ 39 ] = 0
     VLMMB [ 39 ] = 0
     VLMM1 [ 39 ] = 0
     VLMM2 [ 39 ] = 0
     VLMXB [ 40 ] = 0
     VLMX1 [ 40 ] = 0
     VLMX2 [ 40 ] = 0
     VLMZB [ 40 ] = 0
     VLMZ1 [ 40 ] = 0
     VLMZ2 [ 40 ] = 0
     VLMSB [ 40 ] = 0
     VLMS1 [ 40 ] = 0
     VLMS2 [ 40 ] = 0
     VLMCB [ 40 ] = 0
     VLMC1 [ 40 ] = 0
     VLMC2 [ 40 ] = 0
     VLMMB [ 40 ] = 0
     VLMM1 [ 40 ] = 0
     VLMM2 [ 40 ] = 0
     VLMXB [ 41 ] = 0
     VLMX1 [ 41 ] = 0
     VLMX2 [ 41 ] = 0
     VLMZB [ 41 ] = 0
     VLMZ1 [ 41 ] = 0
     VLMZ2 [ 41 ] = 0
     VLMSB [ 41 ] = 0
     VLMS1 [ 41 ] = 0
     VLMS2 [ 41 ] = 0
     VLMCB [ 41 ] = 0
     VLMC1 [ 41 ] = 0
     VLMC2 [ 41 ] = 0
     VLMMB [ 41 ] = 0
     VLMM1 [ 41 ] = 0
     VLMM2 [ 41 ] = 0
     VLMXB [ 42 ] = 0
     VLMX1 [ 42 ] = 0
     VLMX2 [ 42 ] = 0
     VLMZB [ 42 ] = 0
     VLMZ1 [ 42 ] = 0
     VLMZ2 [ 42 ] = 0
     VLMSB [ 42 ] = 0
     VLMS1 [ 42 ] = 0
     VLMS2 [ 42 ] = 0
     VLMCB [ 42 ] = 0
     VLMC1 [ 42 ] = 0
     VLMC2 [ 42 ] = 0
     VLMMB [ 42 ] = 0
     VLMM1 [ 42 ] = 0
     VLMM2 [ 42 ] = 0
     VLMXB [ 43 ] = 0
     VLMX1 [ 43 ] = 0
     VLMX2 [ 43 ] = 0
     VLMZB [ 43 ] = 0
     VLMZ1 [ 43 ] = 0
     VLMZ2 [ 43 ] = 0
     VLMSB [ 43 ] = 0
     VLMS1 [ 43 ] = 0
     VLMS2 [ 43 ] = 0
     VLMCB [ 43 ] = 0
     VLMC1 [ 43 ] = 0
     VLMC2 [ 43 ] = 0
     VLMMB [ 43 ] = 0
     VLMM1 [ 43 ] = 0
     VLMM2 [ 43 ] = 0
     VLMXB [ 44 ] = 0
     VLMX1 [ 44 ] = 0
     VLMX2 [ 44 ] = 0
     VLMZB [ 44 ] = 0
     VLMZ1 [ 44 ] = 0
     VLMZ2 [ 44 ] = 0
     VLMSB [ 44 ] = 0
     VLMS1 [ 44 ] = 0
     VLMS2 [ 44 ] = 0
     VLMCB [ 44 ] = 0
     VLMC1 [ 44 ] = 0
     VLMC2 [ 44 ] = 0
     VLMMB [ 44 ] = 0
     VLMM1 [ 44 ] = 0
     VLMM2 [ 44 ] = 0
     VLMXB [ 45 ] = 0
     VLMX1 [ 45 ] = 0
     VLMX2 [ 45 ] = 0
     VLMZB [ 45 ] = 0
     VLMZ1 [ 45 ] = 0
     VLMZ2 [ 45 ] = 0
     VLMSB [ 45 ] = 0
     VLMS1 [ 45 ] = 0
     VLMS2 [ 45 ] = 0
     VLMCB [ 45 ] = 0
     VLMC1 [ 45 ] = 0
     VLMC2 [ 45 ] = 0
     VLMMB [ 45 ] = 0
     VLMM1 [ 45 ] = 0
     VLMM2 [ 45 ] = 0
     VLMXB [ 46 ] = 0
     VLMX1 [ 46 ] = 0
     VLMX2 [ 46 ] = 0
     VLMZB [ 46 ] = 0
     VLMZ1 [ 46 ] = 0
     VLMZ2 [ 46 ] = 0
     VLMSB [ 46 ] = 0
     VLMS1 [ 46 ] = 0
     VLMS2 [ 46 ] = 0
     VLMCB [ 46 ] = 0
     VLMC1 [ 46 ] = 0
     VLMC2 [ 46 ] = 0
     VLMMB [ 46 ] = 0
     VLMM1 [ 46 ] = 0
     VLMM2 [ 46 ] = 0
     VLMXB [ 47 ] = 0
     VLMX1 [ 47 ] = 0
     VLMX2 [ 47 ] = 0
     VLMZB [ 47 ] = 0
     VLMZ1 [ 47 ] = 0
     VLMZ2 [ 47 ] = 0
     VLMSB [ 47 ] = 0
     VLMS1 [ 47 ] = 0
     VLMS2 [ 47 ] = 0
     VLMCB [ 47 ] = 0
     VLMC1 [ 47 ] = 0
     VLMC2 [ 47 ] = 0
     VLMMB [ 47 ] = 0
     VLMM1 [ 47 ] = 0
     VLMM2 [ 47 ] = 0
     VLMXB [ 48 ] = 0
     VLMX1 [ 48 ] = 0
     VLMX2 [ 48 ] = 0
     VLMZB [ 48 ] = 0
     VLMZ1 [ 48 ] = 0
     VLMZ2 [ 48 ] = 0
     VLMSB [ 48 ] = 0
     VLMS1 [ 48 ] = 0
     VLMS2 [ 48 ] = 0
     VLMCB [ 48 ] = 0
     VLMC1 [ 48 ] = 0
     VLMC2 [ 48 ] = 0
     VLMMB [ 48 ] = 0
     VLMM1 [ 48 ] = 0
     VLMM2 [ 48 ] = 0
     VLMXB [ 49 ] = 0
     VLMX1 [ 49 ] = 0
     VLMX2 [ 49 ] = 0
     VLMZB [ 49 ] = 0
     VLMZ1 [ 49 ] = 0
     VLMZ2 [ 49 ] = 0
     VLMSB [ 49 ] = 0
     VLMS1 [ 49 ] = 0
     VLMS2 [ 49 ] = 0
     VLMCB [ 49 ] = 0
     VLMC1 [ 49 ] = 0
     VLMC2 [ 49 ] = 0
     VLMMB [ 49 ] = 0
     VLMM1 [ 49 ] = 0
     VLMM2 [ 49 ] = 0
     VLMXB [ 50 ] = 0
     VLMX1 [ 50 ] = 0
     VLMX2 [ 50 ] = 0
     VLMZB [ 50 ] = 0
     VLMZ1 [ 50 ] = 0
     VLMZ2 [ 50 ] = 0
     VLMSB [ 50 ] = 0
     VLMS1 [ 50 ] = 0
     VLMS2 [ 50 ] = 0
     VLMCB [ 50 ] = 0
     VLMC1 [ 50 ] = 0
     VLMC2 [ 50 ] = 0
     VLMMB [ 50 ] = 0
     VLMM1 [ 50 ] = 0
     VLMM2 [ 50 ] = 0
     VLMXB [ 51 ] = 0
     VLMX1 [ 51 ] = 0
     VLMX2 [ 51 ] = 0
     VLMZB [ 51 ] = 0
     VLMZ1 [ 51 ] = 0
     VLMZ2 [ 51 ] = 0
     VLMSB [ 51 ] = 0
     VLMS1 [ 51 ] = 0
     VLMS2 [ 51 ] = 0
     VLMCB [ 51 ] = 0
     VLMC1 [ 51 ] = 0
     VLMC2 [ 51 ] = 0
     VLMMB [ 51 ] = 0
     VLMM1 [ 51 ] = 0
     VLMM2 [ 51 ] = 0
     VLMXB [ 52 ] = 0
     VLMX1 [ 52 ] = 0
     VLMX2 [ 52 ] = 0
     VLMZB [ 52 ] = 0
     VLMZ1 [ 52 ] = 0
     VLMZ2 [ 52 ] = 0
     VLMSB [ 52 ] = 0
     VLMS1 [ 52 ] = 0
     VLMS2 [ 52 ] = 0
     VLMCB [ 52 ] = 0
     VLMC1 [ 52 ] = 0
     VLMC2 [ 52 ] = 0
     VLMMB [ 52 ] = 0
     VLMM1 [ 52 ] = 0
     VLMM2 [ 52 ] = 0
     VLMXB [ 53 ] = 0
     VLMX1 [ 53 ] = 0
     VLMX2 [ 53 ] = 0
     VLMZB [ 53 ] = 0
     VLMZ1 [ 53 ] = 0
     VLMZ2 [ 53 ] = 0
     VLMSB [ 53 ] = 0
     VLMS1 [ 53 ] = 0
     VLMS2 [ 53 ] = 0
     VLMCB [ 53 ] = 0
     VLMC1 [ 53 ] = 0
     VLMC2 [ 53 ] = 0
     VLMMB [ 53 ] = 0
     VLMM1 [ 53 ] = 0
     VLMM2 [ 53 ] = 0
     VLMXB [ 54 ] = 0
     VLMX1 [ 54 ] = 0
     VLMX2 [ 54 ] = 0
     VLMZB [ 54 ] = 0
     VLMZ1 [ 54 ] = 0
     VLMZ2 [ 54 ] = 0
     VLMSB [ 54 ] = 0
     VLMS1 [ 54 ] = 0
     VLMS2 [ 54 ] = 0
     VLMCB [ 54 ] = 0
     VLMC1 [ 54 ] = 0
     VLMC2 [ 54 ] = 0
     VLMMB [ 54 ] = 0
     VLMM1 [ 54 ] = 0
     VLMM2 [ 54 ] = 0
     VLMXB [ 55 ] = 0
     VLMX1 [ 55 ] = 0
     VLMX2 [ 55 ] = 0
     VLMZB [ 55 ] = 0
     VLMZ1 [ 55 ] = 0
     VLMZ2 [ 55 ] = 0
     VLMSB [ 55 ] = 0
     VLMS1 [ 55 ] = 0
     VLMS2 [ 55 ] = 0
     VLMCB [ 55 ] = 0
     VLMC1 [ 55 ] = 0
     VLMC2 [ 55 ] = 0
     VLMMB [ 55 ] = 0
     VLMM1 [ 55 ] = 0
     VLMM2 [ 55 ] = 0
     VLMXB [ 56 ] = 0
     VLMX1 [ 56 ] = 0
     VLMX2 [ 56 ] = 0
     VLMZB [ 56 ] = 0
     VLMZ1 [ 56 ] = 0
     VLMZ2 [ 56 ] = 0
     VLMSB [ 56 ] = 0
     VLMS1 [ 56 ] = 0
     VLMS2 [ 56 ] = 0
     VLMCB [ 56 ] = 0
     VLMC1 [ 56 ] = 0
     VLMC2 [ 56 ] = 0
     VLMMB [ 56 ] = 0
     VLMM1 [ 56 ] = 0
     VLMM2 [ 56 ] = 0
     VLMXB [ 57 ] = 0
     VLMX1 [ 57 ] = 0
     VLMX2 [ 57 ] = 0
     VLMZB [ 57 ] = 0
     VLMZ1 [ 57 ] = 0
     VLMZ2 [ 57 ] = 0
     VLMSB [ 57 ] = 0
     VLMS1 [ 57 ] = 0
     VLMS2 [ 57 ] = 0
     VLMCB [ 57 ] = 0
     VLMC1 [ 57 ] = 0
     VLMC2 [ 57 ] = 0
     VLMMB [ 57 ] = 0
     VLMM1 [ 57 ] = 0
     VLMM2 [ 57 ] = 0
     VLMXB [ 58 ] = 0
     VLMX1 [ 58 ] = 0
     VLMX2 [ 58 ] = 0
     VLMZB [ 58 ] = 0
     VLMZ1 [ 58 ] = 0
     VLMZ2 [ 58 ] = 0
     VLMSB [ 58 ] = 0
     VLMS1 [ 58 ] = 0
     VLMS2 [ 58 ] = 0
     VLMCB [ 58 ] = 0
     VLMC1 [ 58 ] = 0
     VLMC2 [ 58 ] = 0
     VLMMB [ 58 ] = 0
     VLMM1 [ 58 ] = 0
     VLMM2 [ 58 ] = 0
     VLMXB [ 59 ] = 0
     VLMX1 [ 59 ] = 0
     VLMX2 [ 59 ] = 0
     VLMZB [ 59 ] = 0
     VLMZ1 [ 59 ] = 0
     VLMZ2 [ 59 ] = 0
     VLMSB [ 59 ] = 0
     VLMS1 [ 59 ] = 0
     VLMS2 [ 59 ] = 0
     VLMCB [ 59 ] = 0
     VLMC1 [ 59 ] = 0
     VLMC2 [ 59 ] = 0
     VLMMB [ 59 ] = 0
     VLMM1 [ 59 ] = 0
     VLMM2 [ 59 ] = 0
     VLMXB [ 60 ] = 0
     VLMX1 [ 60 ] = 0
     VLMX2 [ 60 ] = 0
     VLMZB [ 60 ] = 0
     VLMZ1 [ 60 ] = 0
     VLMZ2 [ 60 ] = 0
     VLMSB [ 60 ] = 0
     VLMS1 [ 60 ] = 0
     VLMS2 [ 60 ] = 0
     VLMCB [ 60 ] = 0
     VLMC1 [ 60 ] = 0
     VLMC2 [ 60 ] = 0
     VLMMB [ 60 ] = 0
     VLMM1 [ 60 ] = 0
     VLMM2 [ 60 ] = 0
     VLMXB [ 61 ] = 0
     VLMX1 [ 61 ] = 0
     VLMX2 [ 61 ] = 0
     VLMZB [ 61 ] = 0
     VLMZ1 [ 61 ] = 0
     VLMZ2 [ 61 ] = 0
     VLMSB [ 61 ] = 0
     VLMS1 [ 61 ] = 0
     VLMS2 [ 61 ] = 0
     VLMCB [ 61 ] = 0
     VLMC1 [ 61 ] = 0
     VLMC2 [ 61 ] = 0
     VLMMB [ 61 ] = 0
     VLMM1 [ 61 ] = 0
     VLMM2 [ 61 ] = 0
     VLMXB [ 62 ] = 0
     VLMX1 [ 62 ] = 0
     VLMX2 [ 62 ] = 0
     VLMZB [ 62 ] = 0
     VLMZ1 [ 62 ] = 0
     VLMZ2 [ 62 ] = 0
     VLMSB [ 62 ] = 0
     VLMS1 [ 62 ] = 0
     VLMS2 [ 62 ] = 0
     VLMCB [ 62 ] = 0
     VLMC1 [ 62 ] = 0
     VLMC2 [ 62 ] = 0
     VLMMB [ 62 ] = 0
     VLMM1 [ 62 ] = 0
     VLMM2 [ 62 ] = 0
     VLMXB [ 63 ] = 0
     VLMX1 [ 63 ] = 0
     VLMX2 [ 63 ] = 0
     VLMZB [ 63 ] = 0
     VLMZ1 [ 63 ] = 0
     VLMZ2 [ 63 ] = 0
     VLMSB [ 63 ] = 0
     VLMS1 [ 63 ] = 0
     VLMS2 [ 63 ] = 0
     VLMCB [ 63 ] = 0
     VLMC1 [ 63 ] = 0
     VLMC2 [ 63 ] = 0
     VLMMB [ 63 ] = 0
     VLMM1 [ 63 ] = 0
     VLMM2 [ 63 ] = 0
     VLMXB [ 64 ] = 0
     VLMX1 [ 64 ] = 0
     VLMX2 [ 64 ] = 0
     VLMZB [ 64 ] = 0
     VLMZ1 [ 64 ] = 0
     VLMZ2 [ 64 ] = 0
     VLMSB [ 64 ] = 0
     VLMS1 [ 64 ] = 0
     VLMS2 [ 64 ] = 0
     VLMCB [ 64 ] = 0
     VLMC1 [ 64 ] = 0
     VLMC2 [ 64 ] = 0
     VLMMB [ 64 ] = 0
     VLMM1 [ 64 ] = 0
     VLMM2 [ 64 ] = 0
     M02
  7. #47
    Jun 2015
    4154
    "save" code will output LM values between desired LM adresses / fields
    Code:
        V1 =  1
        V2 = 64
      ( * ) ( save between V1 and V2 )
        FWRITC LM-register1.txt;A
        PUT ' '
        WRITE C
        PUT '	'
        PUT ' -'
        PUT '	'
        PUT '     [ X ]  '
        PUT '	'
        PUT '     [ Z ]  '
        PUT '	'
        PUT '     [ S ]  '
        PUT '	'
        PUT '     [ C ]  '
        PUT '	'
        PUT '     [ M ]  '
        WRITE C
        PUT ' '
        WRITE C
        NHERE
          PUT '	'
          PUT V1 , 2
          PUT '	'
          PUT VLMXB [ V1 ] , 4
          PUT VLMX1 [ V1 ] , 4
          PUT VLMX2 [ V1 ] , 4
          PUT '	'
          PUT VLMZB [ V1 ] , 4
          PUT VLMZ1 [ V1 ] , 4
          PUT VLMZ2 [ V1 ] , 4
          PUT '	'
          PUT VLMSB [ V1 ] , 4
          PUT VLMS1 [ V1 ] , 4
          PUT VLMS2 [ V1 ] , 4
          PUT '	'
          PUT VLMCB [ V1 ] , 4
          PUT VLMC1 [ V1 ] , 4
          PUT VLMC2 [ V1 ] , 4
          PUT '	'
          PUT VLMMB [ V1 ] , 4
          PUT VLMM1 [ V1 ] , 4
          PUT VLMM2 [ V1 ] , 4
          WRITE C
          V1 = V1 + 1
        CLOSE C
        M02
    this is the content of the output file
    Code:
    	 -	     [ X ]  	     [ Z ]  	     [ S ]  	     [ C ]  	     [ M ]
    	 1	  16  17  21	  48  52  57	   0   0   0	   0   0   0	  56  61  67
    	 2	  17  18  20	  48  52  57	   0   0   0	   0   0   0	  31  34  37
    	 3	  16  17  18	  90  99 106	   0   0   0	   0   0   0	   0   0   0
    	 4	   0   0   0	  17  18  20	   0   0   0	   0   0   0	   0   0   0
    	 5	   0   0   0	  12  13  14	   0   0   0	   0   0   0	   0   0   0
    	 6	   0   0   0	  12  13  14	   0   0   0	   0   0   0	   0   0   0
    	 7	   0   0   0	  12  13  14	   0   0   0	   0   0   0	   0   0   0
    	 8	   0   0   0	  20  24  26	   0   0   0	   0   0   0	   0   0   0
    	 9	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	10	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	11	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	12	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	13	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	14	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	15	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	16	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	17	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	18	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	19	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	20	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	21	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	22	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	23	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	24	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	25	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	26	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	27	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	28	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	29	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	30	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	31	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	32	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	33	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	34	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	35	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	36	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	37	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	38	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	39	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	40	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	41	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	42	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	43	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	44	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	45	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	46	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	47	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	48	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	49	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	50	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	51	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	52	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	53	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	54	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	55	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	56	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	57	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	58	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	59	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	60	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	61	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	62	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	63	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
    	64	   0   0   0	   0   0   0	   0   0   0	   0   0   0	   0   0   0
  8. #48
    Jun 2015
    4154
    "load" code : simple and obvious i suppose this code is not general, but specific ...
    thus a bit useles to share; please consider it "theoretical"
    Code:
        VLMZB [ 1 ] = 48
        VLMZ1 [ 1 ] = 52
        VLMZ2 [ 1 ] = 57
        VLMZB [ 2 ] = 48
        VLMZ1 [ 2 ] = 52
        VLMZ2 [ 2 ] = 57
        VLMZB [ 3 ] = 90
        VLMZ1 [ 3 ] = 99
        VLMZ2 [ 3 ] = 106
        VLMZB [ 4 ] = 17
        VLMZ1 [ 4 ] = 18
        VLMZ2 [ 4 ] = 20
        VLMZB [ 5 ] = 12
        VLMZ1 [ 5 ] = 13
        VLMZ2 [ 5 ] = 14
        VLMZB [ 6 ] = 12
        VLMZ1 [ 6 ] = 13
        VLMZ2 [ 6 ] = 14
        VLMZB [ 7 ] = 12
        VLMZ1 [ 7 ] = 13
        VLMZ2 [ 7 ] = 14
        VLMZB [ 8 ] = 20
        VLMZ1 [ 8 ] = 24
        VLMZ2 [ 8 ] = 26
        M02
  9. #49
    Jun 2015
    4154
    tadda, this is all ... or is it ?
    please stand by for next version codes for " clear / save / load "... all shared so far are not so impressive
    i will delay this a bit, because i don't wanna flood this forum with posts all the best !
  10. #50
    Jun 2015
    4154
    tadda, this is all ... or is it ? please stand by for next version codes for " clear / save / load "
    this thread ( and the next one ) is about reducing duration for :
    ... saving LM values for futher usage
    ... loading LM values, when a previous setup is reloaded on the cnc, thus skipping the AutoSet procedure
    not only reducing duration, but simplifying things; how ?
    ... once a setup with LM values is stable, save all LM data by running a program : thus few seconds
    ... time passes ... stuff happens ... etc
    ... after a while, when same setup is prepared once more on the cnc, load all data by runing a program : thus, again, only a few seconds
    so, i can deliver "save / load" in just a few seconds
    "clear", as i said in previous post, is like erasing contacts from phone agenda ... i always felt sorry for those that have a drink in front, cleaning the mobile / smart phone, like those contacts are inside their head .... and such a 300% relief when agenda is finally refreshed ...
    i also did that now i don't care ... actually, there is a dead person / relative in my agenda, but i still go to more weddings than funerals, so is "still" ok
  11. #51
    Jun 2015
    4154
    this code will generate a *.min file, with LM values output file is stable, available for input anytime
    build for osp300L, tested on LB3oooex2
    Code:
        V1 =  1  V2 = 64  ( save between V1 and V2 )
        CALL OSTRT
         CALL OCORE
          CALL OEND
        M02
    OSTRT
        FWRITC LM-register5.min;A
        PUT ' '
        WRITE C
    RTS
    OCORE
        NHERE
          CALL OMAIN  LV01 = VLMXB [ V1 ]  LV02 = VLMX1 [ V1 ]  LV03 = VLMX2 [ V1 ]  LV04 = 1
          CALL OMAIN  LV01 = VLMZB [ V1 ]  LV02 = VLMZ1 [ V1 ]  LV03 = VLMZ2 [ V1 ]  LV04 = 2
          CALL OMAIN  LV01 = VLMSB [ V1 ]  LV02 = VLMS1 [ V1 ]  LV03 = VLMS2 [ V1 ]  LV04 = 3
          CALL OMAIN  LV01 = VLMCB [ V1 ]  LV02 = VLMC1 [ V1 ]  LV03 = VLMC2 [ V1 ]  LV04 = 4
          CALL OMAIN  LV01 = VLMMB [ V1 ]  LV02 = VLMM1 [ V1 ]  LV03 = VLMM2 [ V1 ]  LV04 = 5
          V1 = V1 + 1
    RTS
    OEND
        PUT '    '
        PUT 'M02'
        WRITE C
        CLOSE C
    RTS
    OMAIN
        IF [ LV01 EQ 0 ] NJUMP
        PUT '    '
         PUT 'VLM'
          CALL OHELP
           PUT 'B     [ '
            PUT V1 , 2
             PUT ' ] =     '
              PUT LV01 , 3
                                     WRITE C
        PUT '    '
         PUT ' VLM'
          CALL OHELP
           PUT '1   [ '
            PUT V1 , 2
             PUT ' ]   =   '
              PUT LV02 , 3
                                     WRITE C
        PUT '    '
         PUT '  VLM'
          CALL OHELP
           PUT '2 [ '
            PUT V1 , 2
             PUT ' ]     = '
              PUT LV03 , 3
                                     WRITE C
        PUT ' '
                                     WRITE C
        NJUMP
    RTS
    OHELP
        IF [ LV04 EQ 1 ] N1
        IF [ LV04 EQ 2 ] N2
        IF [ LV04 EQ 3 ] N3
        IF [ LV04 EQ 4 ] N4
        IF [ LV04 EQ 5 ] N5
         N1 PUT $58
            GOTO NEND
         N2 PUT $5A
            GOTO NEND
         N3 PUT $53
            GOTO NEND
         N4 PUT $43
            GOTO NEND
         N5 PUT $4D
            GOTO NEND
        NEND
    RTS
    this is all ... or is it ? kindly !
  12. #52
    Jun 2015
    4154
    please check attached ~2 minutes movie, so to see how this works
    ... main file is loaded at 0:15
    ... output file is inspected at 0:48, and loaded at 0:53
    ... after 1:10 is shown that output file content is the same as the values inside :
    ......... Auto \ Display_change \ Load_monitor \ Limit_levels \ #1
    ps : it took a bit too much, because i had to run between desktop and cnc kindly !
    Attached Files Attached Files
  13. #53
    Jun 2015
    4154
    Quote Originally Posted by deadlykitten View Post
    hello, one operator forgot to remove the part when program finished, and so machine crashed
    i saw that X axis effort stopped at 196% ...
    please, is there a way to edit this values ? like to stop when effort is 100 or 120 ?
    also, where can i find this crash limits ? kindly !
    what about attached stuff ? please, what are those settings for ?
  14. #54
    Jun 2015
    4154
    hello there are some posts in this thread about a ramp behaviour when monitoring X axis
    please check attached image : left is a width=6 groove knife, and right is a width=3
    chart shows less efort required for the w6
    if i put a delay >10 .. 15 seconds before the w3, than i can see a lower efort on the chart
    i can not run the program with such a delay, and to avoid toolholders damaged, i simply switch inserts more often
  15. #55
    Jun 2015
    4154
    hello all i was prety close to reduce crash impacts severity, but i hit a wall and i can not continue
    this involves "torque limiter" : parameters / other function / upper limit of torque limit comand
    that limit can not be > 100, even if efforts during normal machining are greater than that
    reason why this limit is limited, is that it is designed for "torque skip", which operates at values <<< 100
    well, it is possible to input :
    ... max_value=100 for that limit
    ... G29 PX=100 and G29 PZ=100 at program start
    ... G28 at program end
    this will work just fine for feed movements, but it will fail for rapids, because acceleration/deceleration uses more than 100 for this to work, than it is required something like M216, or something like torque_limit_delay_time ( from same parameters page allready mentioned in this post )
    at this moment i could use this to protect the machine during cutting, but i would have to avoid leaving these codes active when rapids occur ( repositioning when roughing / or when threading, etc ... )
    to protect it also during rapids, thus to achieve all time protection, than it is required a solution to ignore rapid peeks
    kindly !
  16. #56
    Jun 2015
    4154
    just imagine : cnc is always monitored at an editable value that may be lower than rapid peeks effort everybody benefits
    ... this is exactly how load monitor operates
  17. #57
    Jun 2015
    4154
    i started using a general vlmon variable, which i turn off only when a tool requires monitoring
    this should protect the cnc from crashes that leads to missalingments, or at least reduce impact severity
    i will share codes for this in a few months, so to be sure that is all ok kindly !
  18. #58
    Jun 2015
    4154
    Your Okuma has 4 methods of monitoring:
    1. NC torque limiter - always ON monitoring for crashes.
    2. Load monitor - for detecting worn or broken tools.
    3. Torque limiter - used to limit load to a maximum value such as during a part transfer.
    4. Torque skip - used to feed to a certain load, and then stop such as when feeding to a part or using a bump stop
    ... as force is applied to an axis, the DIFF becomes greater and the greater the distance, the more the motor will try to reach 0 DIFF. This shows up as motor load or current applied. This can increase until max current is reached at which point the DIFF will continue to grow until about 1mm is reached. That is when the DIFF over alarm will occur
    hello mr Wizard i recently runned some trials, trying to reduce crash impact severitity
    normal feed movements ( cutting ) can be easily monitored with load_monitor, because speeds are normal, and there is plenty of time for load_monitor to react
    as speeds increase, thus rapids or fast G01s, load_monitor reaction time is too slow, and in this moment diff errors ocurr
    at all crashes that i experienced so far, diff error was there : 1181-11 alarm-a mcs diff over
    so this function :
    is the one that triggers the diff error ? kindly !
    ps : only thing i could find about torque limiter is in attached image, and i dont understand what it means/ what it does
  19. #59
    Jun 2015
    4154
    i am not sure : machine moves incremental, thus on a long travel there are a lot of motor impulses / sectors / small segments
    control knows electric power consumption for each segment
    when too much power is required and segment lenght is not achieved, means that a colision occured, and a diff error is issued ?
    perhaps "too much power" means the equivalent power for diff=1 mm ?
    if it is like this, than it makes sense
  20. #60
    Jun 2015
    4154
    i dont think that diff>1 will trigger an alarm
    diff>1 may be a result of trials, where at diff=1 a specific admisible torque limit is reached
    specific admisible torque limit coefficient may be available for user input ( thus editable ) from the parameter desribed in attached image, located in sys. para.
    if things are to be done by the book, than X axis, for example, should have a specific_admisible_torque_limit_for_X+_sense > specific_admisible_torque_limit_for_X-_sense, thus consideration for turret mass
    also that may be nonsense if cynematics can deliver much more momentum than what is needed to move the turret mass
    i am not an encoder cynematic expert, but i would like to know these things ; kindly !
Page 3 of 4 1234
  1. Okuma Load Monitor Codes
    By kurmay in forum Okuma
    Last Post: 05-26-2015, 12:03 PM
  2. Simplified load monitor function.
    By shags72 in forum Okuma
    Last Post: 06-02-2014, 03:27 PM
  3. Load Monitor on (or not)
    By OkumaMori in forum Mori Seiki lathes
    Last Post: 07-27-2013, 03:35 AM
  4. Load Monitor
    By ChattaMan in forum Okuma
    Last Post: 12-19-2011, 08:10 PM
  5. Spindle load monitor on Makino MC-100
    By swarfy in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2010, 08:54 AM
