Does any one know why after I run my router on a project after about an hour or so my x axis seems to lose steps ( the axis will move about -40 mm and I have to zero machine and re start the code again ) it works fine without missing a beat on short jobs , I have checked for tight spots on the slides & screw in case there is a heat expansion issue but it seems all good
there are no loose couplings on the shaft etc . I have tried slowing my motor accell & feed in motor tuning but it doesn't seem to help .The z&y don't give any trouble at all.
any help would be appreciated thanks .
Glenn.
