I have a project to cut 60 crosses out of hardwood. This is a little out of my comfort zone. I normally machine plastics for signs primarily but I figured why not take a shot at it.
I tried cutting the design out of 3 hardwoods: poplar, cherry, and hard maple. I used the same feed/speed for all three of 120ipm and 16000 rpm. DOC: .25" and climb direction. I'll admit, the 1/4" upcut bit I used has been around the block so I ordered a 1/4" Whiteside downcut which should come in tomorrow.
My issue is the edge quality I'm getting needs sanding. A good bit of sanding. The straight sections need minimal sanding but around the curves and contours, it needs quite a bit of sanding. It either shows the machining lines or has minor tear. There isn't a huge difference in quality of cut between the three woods. Hard maple machined the best with Cherry and Polar essentially tied for 2nd.
When I get the new bit tomorrow I plan on doing the following: Oversize the part cutting in the climb direction. Then do a cleanup pass, full depth conventional pass.
I also have new rack gears coming in this week as I noticed the machine had a bit more backlash than it should. Hopefully that will help get a better product as well.
Any other recommendations?
