586,471 active members*
4,205 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Converting Catia Solid to MC X8 HLE
    Mar 2016
    6
    I have a Catia Solid that I am trying to import into X8 for an HSM class project.
    I have saved the Catia file to multiple files extentions (step, igs, dfx, dwg, 3dm) trying to get something I can use in X8. When I open the various files in X8, I get the solid most times but I cannot get any line that I can manipulate or select for chains.
    I am at a loss.
    Any help?
    Thanks in advance, Rick
    Dec 2008
    3110
    Re: Converting Catia Solid to MC X8 HLE
    I am at a loss.
    Any help?
    Rick, Your choice of color is sh$t, leave it as default
    When importing, there is an "Options" button (on the file select page ),
    - allows you to bring in a solid ( or surfaces ).....and ALSO to create wireframe geometry
    or
    - if the item are already imported....try <<create>>, <<curves>>, << All surfaces (& select solid entity mask icon - blue icon on user toolbar [edge / face / solid) >>, select solid and then accept
    You'll notice the 1st option is much easier
    Mar 2016
    6
    Superman,
    Your right, the color sucks but I was not aware that I had changed anything.
    The Create curves option works at this time. I will report any problems
    Thanks, Rick
    Apr 2003
    3578
    Why not cut from the solid model that came in. you can use the edges of the model to cut from. now is it a solid for sure and not surfaces that look like a soild model?
    Cadcam
  1. Converting STL file to 3D solid
    By dantm in forum Uncategorised CAM Discussion
    Last Post: 12-15-2018, 07:06 PM
  2. negative of a solid in solid works
    By ringanator in forum Solidworks
    Last Post: 02-09-2015, 03:58 PM
  3. Problem Subtracting Solid from solid Ver25
    By Kencor1 in forum BobCad-Cam
    Last Post: 02-21-2014, 04:15 AM
  4. Converting Catia v4,v5 to MastercamX2
    By nikk_tran in forum Mastercam
    Last Post: 12-17-2007, 04:40 PM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
