Good point Pres,
I'll check it out to see what's acceptable with this table
before I spend any money.
Hoss
Have the Z axis getting 9.8 inches of travel.
Found that the ballscrew was binding near the top because the mount was bolted
to an apparently unsquare casting, go figure.
Added a shim on one side and now it goes all the way up to the bearings.
I suppose if i added a thicker spacer under my z axis mount, i could get another inch. maybe later.
And I suppose if i removed the z axis stop i could get another inch of lower travel, that would be about 12 inches total. maybe later. Besides, the endmill is already touching the table so what's the point.
One more thing, here's a kick in the old fun bags. The new Xylotex board and power supply gives the old z motor enough power that i didn't need to make the counter balance afterall.
i saw that the chain went slack and checked the speed of the motor without any help from the weight, no difference. i 'll leave it be, imagine it at least makes life easier for the motor.Should have done the xylotex first but oh well, this is all a learning experience.
How does 12 inches of y travel and 16-20 inches of X travel sound.
I've done some research and measuring and will get it rolling in a couple of weeks. Have stuff to order but this paycheck is already spent, freakin mortgage.
Later Hoss
http://www.hossmachine.com
Did a couple of deflection tests with the X Axis extended beyond the end of the Saddle.
I can get 11.5 inches of travel now if i push it.
At the point below the tool, the deflection is only .002 with a 30lb 5c collet fixture placed at the far end. Don't think I'd mill anything in a situation like this anyhow.
The deflection at the far end with it fully extended as far as I dare is .004
with me pulling down as hard as I could.
Not too shabby for this little mill I think. Good enough for me.
It's not as solid as a full size bridgeport of course, but the X2 is only 150 lbs. not 2500.
Like my fancy power drawbar? HAHA
Copying this version somewhat.
http://home.insightbb.com/~joevicar3/cheap_drawbar.htm
This is the next hurdle to making an automatic tool changer I've been noodling on.
The extra x travel was the first hurdle.
Onward.
Do you have have a wiring diagram for your control box?
dropride,
I have a diagram on my site here.
http://www.hossmachine.com/projects_...ircuit%20board
the wiring diagram for the replacement board was pretty simple.
I have a pic here. hope it helps.
Hoss
P.S.
got an early birthday present.
the parts are ordered (except Nook ballscrew) for my
12in. Y and 20in. X Axis' travel upgrades.
that will get the job done.
yeehaw
Sorry meant the control panel. Can't wait to see the travel upgrade.Had to cancel my cncbridges table to fix the tranny in my truck and am going to convert my machine soon with the pile of aluminum i've been collecting.
oh, I never made made a wiring diagram for the control panel.
I just soldered the panel switches to patch into or replace the joystick switches.
I made some notes as I went as to where the joystick switch wires were attached to the circuit boards, then soldered the new switches to those points.
They don't have to be in any particular order as Keygrabber in Mach 3 will program the button to whatever you decide to have it replace on the keyboard.
O.k. thanks
Hey Hoss -
I too love that control panel. And, I get the joystick/key grabber mods, but can you explain how you switched the 110v circuits? Did you go through Mach3 or did you wire that all internally to the panel?
nomodoh, the 110 ac switches are just manual.
I have 110 coming in and (4) 110 going out.
Could have used a couple more switches.
use them for the vac, controller, engraver, lathe etc.
If you get the ac outlets, look for new ones that have a little tab on the side that can be broken off to give you 2 separate circuits in one unit.
Looking good Hoss!
I'd quite like to add a bracket for a high-speed spindle to my X-2 mill-head - do you think the 3 bolts that hold the bearing covers on the bottom of the head would be suitable, and if so, do you know their PCD?
Othewise, do you have any tips for mounting a second spindle an accurately known distance away from the axis of the first?
Cheers.
digits,
I don't know the bolt circle of the bearing mount.
It looks like it would be strong enough though I don't know how long the screws are. Could always drill and tap deeper.
This guy has free prints for mounting a second high speed spindle.
Little Machine Shop has a kit for installing one too that appears to mount to the bearing holes.
Per my mill bolt circle dia. is 2.764"
Pat
Hi Digits,
Yup you're probably right. The dimension I gave worked for my adapter but I'd guess that a bit of +/- slop would work as well too.
Pat
