586,121 active members*
3,485 visitors online*
    Jan 2014
    7
    Laser 50w (chinese) 50x30cm problem / laser
    Hello
    we have since 2 month a 50x30cm 50w laser chinese machine.
    It was working very nicely... for 2 months in our fablab in marseille.
    But last week when we were cutting some plywood, the laser stopped to cut . (no problem with motor)
    We suspected the laser tube was broken and we bought a new lasertube : but it didnt work... (but maybe the new lasertube have a problem ..? badluck..)
    We tried to plug a fluorescent tube instead of laser to test the power of laser... and the neon tube is powered and light on.
    So what do you think ?? :
    we suspect :
    > the two laser co2 tube we have are broken ... badluck
    > the power is not generating enough power ? (but work enough to light on a neon...)
    something else ?
    Any help would be very nice !
    Jun 2011
    6
    Re: Laser 50w (chinese) 50x30cm problem / laser
    It will most likely be either the lasers high voltage power supply (most likely) or a tube problem (less likely having tried 2 tubes).
    If your power supply has a test button - try flashing the tube with that.Or put an ammeter on the low voltage side of the tube and see if you nare getting any output- should typically be 18-25milliamps range.
    Bill Carruthers Rarotonga, Cook Islands
    Shenhui G350 300x500 60W Coreldraw 12, Photograv3
    Aug 2009
    655
    Good suggestion, as that is likely the cause, though I also once had a cheap estop melt and got the same issue so do a quick check of things obvious like that. I switched my power supply (from another working machine) before I realized the real issue.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Jan 2014
    7
    Hi it was the powersupply of the laser tube.
    We order a new one and it works now...
    The question is now, why did it break so fast (just one month of use) ... we have stable electricty, and ground...
    weird...
  1. Chinese laser 50W, 50x30cm - bad/good stuff, mods, problems etc.
    By iuliusdobre in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-18-2018, 03:16 AM
  2. Yet another Chinese Laser Problem
    By brind0g in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-23-2017, 01:22 PM
  3. chinese laser X Y problem
    By toons666 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2016, 11:13 AM
  4. Problem in Chinese laser CNC machine really need help
    By mramlawi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-03-2015, 09:48 AM
  5. Laser problem, chinese, again
    By kurbulis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-05-2014, 05:28 PM
