586,299 active members*
3,917 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
Page 1 of 3 123
Results 1 to 20 of 57
    Mar 2013
    26
    Does anybody has any idea why it is not working?
    Here are some videos of my testings..
    DDUM4 V1.0
    DDCM6V5.0
    My PC is windows 7 64bit.
    Thank you.
    Feb 2007
    4553
    Re: DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
    Archsakas,
    Are you applying +5 vdc to pul+ and dir+ on stepper drive?
    Then connect step and dir from DDUM to pul- and dir- on stepper drive.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4553
    Red face Re: DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
    Wire like this:
    Mar 2013
    26
    I connected exactly as in manual, that is common positive wire (+dir and +puls) and separate negatives to -dir and -puls. It says in mamual there is no EN signal.
    On DDCM6V1 Later I have found that then I set "step low active", motors works but not properly.
    ON DDUM4V1 there are separete 4 wires for step and dir +and -. I could not wire them wrong..
    Išsiųsta naudojantis Nexus 7 Tapatalk 4 Lt
    Feb 2007
    4553
    Archsakas,
    Try using version 3.042.040 of Mach3, the newer versions are not compatible with USBmove.dll version 2.01.9
    ftp://machsupport.com/Mach3/
    Jeff...
    Mar 2013
    26
    nop.. doesn't work..
    Still testing DDUM4
    My osciloscope shows some signal when I move axis, but motor does not turn.. I tried nema 17 and nema 23, and a few new M542T drivers. Still does not work.
    I am going to return this card to the seller..
    May 2005
    1397
    Hang on... if your scope is hooked to the step signal coming out of the DDUM4, then the only way it could be the problem is if the step pulse width is too narrow for the M542T driver. I've seen that before, and it's one of the reasons why my THB6064AH driver is popular with Marlin / RAMPS people... other drivers can't manage the narrow step.
    If you zoom in with your scope, can you measure the width of one step pulse?
    What step width does the M542T require?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Feb 2007
    4553
    Post Re: DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
    James,
    The pulse width output of the DDUM board is 2.5us and is not adjustable however the buffer is:
    Jeff...
    Feb 2007
    4553
    James,
    The minimum pulse width requirement for the 542 drive is 1.5us
    Jeff...
    May 2005
    1397
    Huh... so it should be working. Again, if the DDUM is producing steps, and they are wide enough, then IT is not the problem.
    Feb 2007
    4553
    I wonder if the Sherline mode would help.
    Mar 2013
    26
    Unfortunately, I cant measure width of the pulse.
    I tried "sherline" mode, but nothing changed.
    I tried "step low active" in motors tab, nothing changed..
    DDUM should be producing width enough pulse, but I guess it does not..
    Feb 2007
    4553
    Did you try and increase the buffer settings?
    Mar 2013
    26
    I tried to change buffer settings to maximum, but nothing changed.
    he is what I see on my ossiloscope the I try to move axis
    link
    distance between two white vertical lines is 20 ms, so it should be about 5 ms, I guess..
    so maybe the pulse width is OK, dont know any more...
    Feb 2007
    4553
    Try measuring the pul+ and dir+ to make sure +5 volts is there.
    Mar 2013
    26
    pulse signal
    here
    now I can see pulse looks good, 5 volts there (right bottom corner "Vmax")
    dir signal
    here
    5 volts there is..
    Feb 2007
    4553
    Please post detailed good pictures of the wiring.
    Feb 2007
    4553
    Does the motor lock up when the driver is powered?
    Mar 2013
    26
    here is wiring video
    here
    and settings video
    here
    Feb 2007
    4553
    1: Trying to follow the wiring while the camera is in motion sucks, take some time and post good still images!
    2: Does the motor lock up when the driver is powered?
Page 1 of 3 123
  1. DDum4 v1.0 settings for spindle PWM and mist/flood
    By bmwdriftpower in forum Controller Cards
    Last Post: 04-01-2016, 07:03 PM
  2. My first Driver not working
    By ghadden in forum CNC Machine Related Electronics
    Last Post: 03-01-2012, 10:24 AM
  3. HobbyCNC Driver Board Not Working
    By Barefooter in forum Hobbycnc (Products)
    Last Post: 02-12-2012, 09:56 PM
  4. received the driver board, not working?
    By elektroda in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-24-2011, 09:32 PM
  5. Mach3 Driver Test not working
    By Beefy in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2011, 06:21 PM
