586,077 active members*
3,938 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad Post Processors > Post Help with Machine Setup-2
Results 1 to 9 of 9
    vfsi Guest
    Where in the post processor file does the M00 between Machine setup -1 and Machine Setup – 2 originate?
    I turned on Debugging and I could see no difference between a different Job and a 2nd Setup but in the NC file, a M00 is inserted. I would like to add more code with the M00.
    Program snippet Next Job:
    N72 G01 X3.0778 Z-.25 F76.8
    ************* 50 – Rapid moves//Rapid move Z **********
    N73 G00 Z.1
    ************* 71 = Operations//End of operation **********
    ************* 4 – Tool Change//Move to next cut same tool **********
    N74 ;JOB 3 PROFILE
    N75 ;23MM HOLE
    N76 X3.0778 Y-2.975
    ************* 40 – Operations//Start of operation **********
    ************* 51 – Feed moves//Feed move Z **********
    Program snippet Next Machine Setup:
    N83 G01 X3.0778 F76.8
    N84 G00 Z.1
    N85 M00
    N86 ;JOB 4 PROFILE
    N87 ;OUTSIDE PROFILE
    N88 X6.215 Y.2906
    How does the post know to add the M00 on line N85?
    Thanks for your help.
    Nov 2004
    164
    Re: Post Help with Machine Setup-2
    Quote Originally Posted by vfsi View Post
    N85 M00
    If you open your post in a text editor you should be able to look at section 71. and see how the M00 code is generated. If you cannot find it maybe attach your post file so others can look at it.
    vfsi Guest
    Quote Originally Posted by jmullett View Post
    Here is my post at Section 71, not much to see.
    64. Arc move XY.
    n,g_arc_plane,g_arc_move,x_f,y_f,arc_center,feed_r ate
    65. Arc move YZ.
    n,g_arc_plane,g_arc_move,y_f,z_f,arc_center,feed_r ate
    66. Arc move XZ.
    n,g_arc_plane,g_arc_move,x_f,z_f,arc_center,feed_r ate
    71. End of 2axis cutting.
    73. High speed peck drill canned cycle.
    n,canned_feed_rate
    Apr 2008
    1577
    N73 G00 Z.1
    N74 ;JOB 3 PROFILE
    N75 ;23MM HOLE
    N76 X3.0778 Y-2.975
    N84 G00 Z.1
    N85 M00
    N86 ;JOB 4 PROFILE
    N88 X6.215 Y.2906
    You may be missing this block in your post processor:
    16. Machine Setup Change
    "(NEXT SETUP)"
    If block 16 is empty or missing you get an M00. Add any kind of instruction in there and it will replace the M00 with whatever you put there. Have fun with it!
    EDIT: I added the line feed " " and the (NEXT SETUP) in there to get rid of the M00. I can't remember what is there by default but you can look at BC_3x_Mill.Millpst for reference.
    vfsi Guest
    Quote Originally Posted by SBC Cycle View Post
    "(NEXT SETUP)"
    Thanks for the great help...
    Earlier I had searched for the word "Setup" and my editor returned a blank. So I thought something was missing. I will reference BC_3x for insight. I started with the Siemens post supplied from bobcad which is almost functional but unusable without a lot of editing. Now I am trying to refine it for our use. Every week a set closer.
    Apr 2008
    1577
    No problem! My post took a while to get it just right but man is it just right. Good luck and post back with any problems.
    Aug 2008
    93
    My lathe post (Siemens 840C) does not have a block 16. However in my Mill (Fanuc OMC) post I edited block 16 to read:
    n,"M9"
    n,"G0Y4.0Z5.0"
    n,"M5"
    n,"( TURN PART )"
    n,"M00"
    "(TOOL#",list_tool_number," ",tool_label,")"
    n_forced,t,"M6"
    n,"M01"
    n,rapid_move,absolute_coord,work_coord,force_x,xr, force_y,yr,rotar y_xy_angle
    n,rapid_move,length_offset,spindle_on,s
    n, force_no_add_spaces," /"coolant_on
    default_add_spaces
    This is a rather late reply but it might help someone out.
    Aug 2008
    93
    I think this should be referred to as section 16. Blocks are all in the 2000 series for doing calculations.
    Aug 2008
    93
    I learned from BOBcad that you cannot do a setup change in LATHE. They never allowed it in the code. Told me I need to make a new part in a new drawing and start part two there.
  1. Replies: 13
    Last Post: 11-11-2015, 04:41 PM
  2. Machine setup and post for Yasnac LX3
    By John-INTENSE in forum BobCad-Cam
    Last Post: 02-21-2015, 09:46 AM
  3. Replies: 2
    Last Post: 07-30-2014, 01:23 AM
  4. Machine Setup
    By JohnJW in forum Haas Mills
    Last Post: 07-12-2010, 08:32 AM
  5. machine setup
    By bigears in forum MetalWork Discussion
    Last Post: 09-09-2009, 06:46 AM
