586,055 active members*
4,376 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Cutting sheet aluminum to get a round piece
    Mar 2014
    1131
    Say I have a stock of 500x500x20mm sheet metal. I need to mill to get a 100mm dia round piece (and have the rest of the sheet). What operation would the best for the job?
    Feb 2016
    381
    Re: Cutting sheet aluminum to get a round piece
    I am new to this using fusion360 I did similar with 3mm aluminium in mini mill setting up a 200mm circle and using 2d contour cut from stock extended over all sides.
    Oct 2013
    64
    Mill it on aluminum plate. Just mill a down helix spiral at slow feed rate.
    Sent from my Nexus 5 using Tapatalk
  1. Aluminum sheet cutting on router
    By Funkyjunk in forum MetalWork Discussion
    Last Post: 09-18-2010, 08:00 AM
  2. Cutting aluminum sheet
    By Smokingman in forum MetalWork Discussion
    Last Post: 06-16-2010, 05:28 PM
  3. 4X8 CNC router cutting 3/16 aluminum sheet
    By scorpionracing in forum Uncategorised MetalWorking Machines
    Last Post: 02-22-2010, 10:47 PM
  4. Cutting .020 Sheet Aluminum on a CNC Router
    By Mini-MillX2 in forum MetalWork Discussion
    Last Post: 05-02-2007, 12:21 AM
  5. Cutting 1/4" aluminum sheet
    By energyforce in forum MetalWork Discussion
    Last Post: 12-01-2005, 08:12 AM
