I just bought a Haas VF4 with a 17 pin port for 4th axis. If I buy a brushed HRT210 will I be able to contour mill while rotating or just index then mill? I've been told two different things.
I you plug the HRT210 directly into the Haas, you will be able to use full 4th axis. Be sure to adjust your parameters correctly and enable the correct unit in Setting graphics.
Have fun!
Mike
