586,070 active members*
3,409 visitors online*
    Dec 2009
    30
    Profile cuts starting at the wrong point
    My profile cuts are starting in the wrong spot. It only happens on the initial pass, the other passes follow right with the program.
    Anyone else have this issue? Any one know what is causing this. The toolpath looks fine in vectric aspire.
    Sent from my Z958 using Tapatalk
    Re: Profile cuts starting at the wrong point
    Mach3 will always cut exactly where the g-code tells it to start.
    You'll need to provide a lot more info.
    Can you post the Aspire file, and the g-code, and where you think it should start cutting?
  1. 4th Axis Profile Cuts
    By echesak in forum Tormach Personal CNC Mill
    Last Post: 01-26-2016, 06:48 PM
  2. Need help starting point and ending point wont contact
    By miketola in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2014, 08:04 AM
  3. Smooth Profile Cuts
    By ecope in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-09-2012, 07:40 PM
  4. Use a point for the start point of a profile.
    By dcskid in forum BobCad-Cam
    Last Post: 03-18-2009, 04:31 PM
