586,069 active members*
3,302 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > How do I power spindle F1 that is missing its power supply
    Feb 2016
    6
    Hello all,
    I recently picked up a F1 mill. I acquired it for what I think was a good price because it did not come with the original, old control boards and power supplies. I believe that the spindle is a 550w DC spindle. This may be a very novice question, but can I power it using a 550-600w AC to DC power supply or is my thinking way off? I think that I may need something in between to make it variable speed (to be controlled by mach3 hopefully) but I have no idea. I had an extra controller board to use on what I think are upgraded steppers in the mill so I think I may have that part covered, but I am lost on powering the spindle. Aside from the spindle itself, there is a small bit of hardware that is wired to the spindle but I am not exactly sure what it is. I have attached a pic of it. Any help or comments would be greatly appreciated.
    Apr 2016
    10
    Re: How do I power spindle F1 that is missing its power supply
    You can as long as it provides 95volts. I have an OMRON S8VS power supply on mine to get the necessary voltage. Alternatively, you can purchase a PolySpede OC1 or OC2 board and power the spindle that way. It has the added benefit of a 10kohm pot for speed adjustment.
    The components you took pictures of is a terminal strip and is an original factory part. It's found on PG 9/3 of the F1 service manual.
  1. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  2. Seperate Power Supply for Spindle?
    By shane94 in forum Spindles / VFD
    Last Post: 02-26-2015, 04:57 AM
  3. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  4. Spindle Power Supply
    By jaysteel in forum Taig Mills / Lathes
    Last Post: 07-08-2012, 04:11 AM
  5. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
