Auto feeding co2 laser cutting machine with CCD camera
Auto feeding co2 laser cutting machine with CCD camera adopts CCD camera positioning automatically, high cutting speed, high precision, well cutting effect.
Auto feeding co2 laser cutting machine with CCD camera application:
High-efficiency double-head component design, two laser tubes will coordinate with two laser heads to work, it is suitable for industries engaged in embroidering and cutting clothing tag on a large scale, is mainly used to cut computerized embroidery labels, irregular labels, embroidery craftwork, print fabric, textile, badge, trademark industries and other nonmetal materials ,so the benefit will be increased by on time and the aim of reducing cost and improving output are under control.
Features of auto feeding co2 laser cutting machine with CCD camera :
1. The rolled materials are loaded to table automatically.
2. CO2 glass inner cavity sealing type laser and continuous circular water cooling system are utilized.
3. The imported fast guide rail and high speed stepping motor, as well as integral steel frame structure are used to ensure the high precision and great stability of this laser flat cutting machine.
4. The feature of cutting is smooth with tighten working range without material waste which can save cost.
5. Adopt DSP control system, and moves smoothly. With modularized and unified design and installment, it has the better ability of anti-interference, so it is easy to inspect and replace the spare parts.
6. With CCD scanner, Don't need a second drawing.
7. Easily moving universal wheel.
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
