586,432 active members*
4,087 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam Help 2d Contour toolpath
    Apr 2016
    Hi , im study mastercam on my education
    can anybody help me , how to set the toolpath bit set to tangent to edge?
    tq
    Dec 2008
    3111
    Re: Mastercam Help 2d Contour toolpath
    There is a "Documentation" , as well as "Samples" folder that is installed with Mastercam. They would be of assistance to you
    - your problem is a basically a lack of familiarity with any CAD-CAD system ( generally speaking )
    You have selected the operation, the profile, & the tool you wish to use,
    - now you need to set that operation's parameters on how the tool is to follow the geometry
    - you need to set the compensation type ( currently it is set to OFF, it need to be either Computer, Wear or Control.... I suggest Computer ( due to your actual NC Knowledge.... I hope no offense is taken ))
    - you also need to set the Lead in/out ( so the tool does not plunge or retract while against the profile )... I suggest (Lead in side) Start at Midpoint check OFF, Tangent check ON, Line 50% of cutter size, Arc radius ZERO & then hit the centre arrow to carry the values to the Lead out side
    accept & regenerate the operation
    A bit of advice
    - make the part origin be a feature of your actual part, ie at the corner where your tool currently is shown
    it would be difficult to find the work zero after the stock has been removed
    Jan 2016
    8
    Hi All
    AEL-Technology creates good quality tutorials of various CAD/CAM/CAE tutorials . Please visit our youtube channel .
    If you like those videos please subscribe
    https://www.youtube.com/watch?v=ej2FXHXUgaU
    For www.aeltechnology.com
    Sumith Karun
    Oct 2006
    259
    Some have to stop & tks SUPERMAN....as he quite frequently come to MANY rescues !....Tks guy !!
  1. Need to get from SolidEdge V20 contour to toolpath G-code
    By jrolands in forum Uncategorised CAD Discussion
    Last Post: 04-22-2014, 07:43 AM
  2. Need to get from SolidEdge V20 contour to toolpath G-code
    By jrolands in forum Uncategorised CAM Discussion
    Last Post: 09-17-2013, 09:15 PM
  3. Need help with Lathe Contour toolpath, please.
    By awolfoutwest in forum GibbsCAM
    Last Post: 11-23-2011, 05:23 AM
  4. contour toolpath containment
    By fjbart70 in forum Mastercam
    Last Post: 02-11-2011, 01:28 AM
  5. Surface contour toolpath (odd)
    By jnc in forum Mastercam
    Last Post: 04-23-2007, 01:16 AM
