586,080 active members*
3,539 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > ProTuner communications error
    Apr 2013
    21
    I am trying to use ProTuner with my DM556 stepper drive.
    When I try the DM556 V2.0 profile I can open the com-port without error. I then select Operation/Parameters, but when i then push "Read" I get "Communication Error. Please check the RS232 cable connection and restart ProTuner." The cable is OK and no amount of restarts help.
    If I try the DM556 V1.0 profile I can also open the com-port, but when I select Tuning/config I get "Receive Device Num failed!" a number of times, then "CRC failed!" repeatedly.
    After looking at http://www.leadshine.com/UploadFile/...s_20131207.pdf and comparing with the label/serialnumber on my drive Attachment 315644 I now beleive I've bought a fake.
    So, my questions are:
    1) Can anyone confirm that this is a fake (or not).
    2) If a fake, have anyone bought similar and had any luck using Protuner with it?
    3) Any other help anyone can give me on methods to SW-set the microstepping.
    Thanks in advance!!
    Apr 2013
    21
    Re: ProTuner communications error
    Well, turned out to be a cableproblem :withstupi
    Still suspect it to be a fake driver, but working in every aspect!
    Jun 2016
    4
    Hi, I have the same problem, too. When I try connect the servodrive HBS2206 of Leadshine with a servomotor, I get a communication error windows: "Unknown device. Check wiring and connections." I am using a firewire to usb adaptor and also I tried with a RS232 cable. So, I can not configure my servodrive.
    Can you tell me what kind of cable you have used and where you get it ?
    Thanks a lot.
  1. DNC Communications
    By jschmid in forum DNC Problems and Solutions
    Last Post: 07-18-2016, 04:03 PM
  2. Roland MDX 15 Communications Error?
    By uzma.durrani in forum News Announcements
    Last Post: 09-30-2013, 04:13 PM
  3. KL-8056D and the ProTuner software
    By dsnaith in forum Automation Technology Products
    Last Post: 12-11-2012, 10:59 PM
  4. Communications from PC to CNC
    By cncamo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-14-2009, 06:32 PM
