586,071 active members*
4,073 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > YCM NT-2000 SY Lathe Y-Axis Servo Motor makes "Howling" sound noise - help
    Apr 2016
    The lathe makes a "Howling" sound noise that I have originally thought had come from the way covers as the noise reverberates thru out the machine. The problem is that the noise continues when the machine is in the stopped state. I now believe the sound noise is emanating from the Y-Axis motor as I can feel it is warm and the coupling is vibrating.
    The Y motor works with the X motor to produce the true Y movement so I hesitate messing with the gains and losing precision. The control is the Fanuc 32i. The machine is just over 1 year old. Any suggestions? Mechanical link? Has anyone tried "pulse suppression?
    Apr 2012
    84
    Re: YCM NT-2000 SY Lathe Y-Axis Servo Motor makes "Howling" sound noise - help
    Oarsman,
    Are those two motors (the x and y axis) the same? If so, I would suggest switching them and running the machine. If there is an issue with the motor, it will be clear after that. If your motor is the problem, we do motor repair all the time over here. Shoot me an email with your specs and problem and I'll forward them to my techs. They might have other opinions. [email protected]
    We fix it all! Give us a call at 855-437-3497.
    Apr 2016
    Quote Originally Posted by ies fixs View Post
    Oarsman,
    Hi Tyler,
    The X & Y are different motors.
    Apr 2012
    84
    Quote Originally Posted by Oarsman View Post
    Hi Tyler,
    Ahh. Okay. Could you email me a picture of the plate on the motor? A bad encoder or bearings could be the cause of your motor problem.
    [email protected]
  1. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. TM-1 Harmonic noise on "Y" Axis
    By smittys800 in forum Haas Mills
    Last Post: 11-26-2007, 04:42 PM
  4. Replies: 2
    Last Post: 06-03-2007, 02:21 PM
  5. TAIG "head" makes alot of noise
    By Smertrios in forum Taig Mills / Lathes
    Last Post: 02-25-2006, 11:25 PM
