How can I drill a 2" hole through a window?
Hello everyone,
I am in the process of reusing the waste water from my laundry into the garden.
The problem I have is that my house sits on a concrete slab and all the laundry plumbing is inside the slab with no access to it. The only option is run a pipe directly from inside to outside. The only way I can do that is to drill a hole in the window and run a 2" pipe through it.
Through the window is the only way as the whole laundry wall to the outside is glass (door and window roof to floor) No actual wall is there.
This will be a one off so I am looking for a solution to get through the glass. The pipe is actually 50mm and will want to drill it a bit bigger to fit in a rubber grommet.
I have not yet looked for grommets but lets say I find one that is 60mm for the sake of this exersize. I am thinking that this might work, turn up a section of solid PCV into a 60mm pipe and on the other end 1/2" to fit my drill.
On this tool use valve grinding paste to slowly drill through. I realise that diamond compound will be the best but it is just the one off and as long as I can get through it without busting the window I will be happy.
All comments for and against welcome,
Cheers M
No, Little-Johnny, pomegranate is not a type of English stone.
