Hi guys,
Well I can confirm that just having a go comes with a huge price tag.
I am about 5 cutters down and lost as to what to do next.. And yes I am new at this, but loving it.
I am trying to cut some letters out of 3mm corten steel.
I have a high speed spindle that stops when i set it below 5000 RPM ( First 2 bits..) Stopped spinning while gantry was moving SNAP!!
I am using a 6 mill plunge end mill 2 flute Cutting the full 3mm thickness in one pass.
I tried 12,000 rpm at 1mm - 5mm per second. Worked great for about 2 minutes, then bit glowed bright red, some sparks and it broke off welding itself to the steel. ( 2 More Bits Down. )
So any thoughts please anyone, other than yes I dont know what I am doing.
I have read that maybe I should be running faster up around 18,000 RPM with a feed rate of 20 -30 mm per second..
