586,036 active members*
3,695 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Prolight 3000 lathe retrofit
Results 1 to 17 of 17
    Sep 2006
    45
    I have had this lathe for so time. I been wanting to get it running but life has a way of getting in the way of such things. Looks like I will soon have enough money set a side for this.
    My question is has any of you used Linuxcnc and a Gecko G540 drive system to run this lathe and will it be able to control the auto tool indexer some how.
    Nov 2009
    4415
    Re: Prolight 3000 lathe retrofit
    It shouldnt be an issue getting the hardware to work. The auto tool changer is just a 3rd axis in regards to port and pin assignments etc.
    Do you understand Linux (I dont). I understood Mach to some extent (after using it for a while). LinuxCnc is totally different in its use. I am not saying better or worse. Just entirely different.
    A lazy man does it twice.
    Sep 2006
    45
    I have set up my little spectralight mill using Linuxcnc. Just looking for someone that has setup a prolight lathe so I can see what they did so Idon't have to start from scratch.
    Nov 2009
    4415
    Understood. How many position tool changer? Turret style? I might have a macro that will work or is easy enough to modify to work.
    Sep 2006
    45
    this is what it looks like
    Attachment 316090
    it has 8 positions 4 o.d. tools 4 i.d. tools
    Don't know how it locks in place
    Nov 2009
    4415
    It might have a solenoid controlled pawl. That is the way mine works. However to get around using more I/O's or complicated tool change macros. The method I have used and seen used is to rotate the turret x degrees (in your case 45 degrees per tool) clockwise for example, then it backs up a few degrees against the pawl.
    I have the tool change macro in the Dyna Mechtronics section. You might want to look at it. It is pretty straight forward on the steps required.
    http://www.cnczone.com/forums/dyna-m...o-m6start.html
    You can see where and what variables you might need to change for your application.
    Nov 2009
    4415
    Watching the video of this guys Prolight 3000 would indicate the tool changer is used the same way as I said.
    https://www.youtube.com/watch?v=Gq2zS2-aNjo
    Sep 2006
    45
    thanks for the macro.
    do you know if this works in linuxcnc
    Nov 2009
    4415
    I do not know.
    I am trying to learn enough on LinuxCnc to make my turret rotate. To say it is different than Mach is an understatement. Command line stuff is alien. I have been reading for days if not weeks trying to make sense of it. I was accused of ADD as a kid, reading thru the LinuxCnc forum seems futile. I am determined to learn it though. Just for options.
    Sep 2006
    45
    I also looked thru the linuxcnc forum didn't see a whole lot of info on this.
    It's been awhile since I set up my mill and I don't know how much I remember
    So I'm going to have to dust off some brain cells and see what is still there.
    Jul 2003
    1754
    Nov 2009
    4415
    Quote Originally Posted by samco View Post
    Sam, I have read that over and over trying to make sense of it.
    ATM Andy on the LCNC forum has given me some instructions on how to use that Boxford file. Or should I say get it installed in the proper place and operational. I have gotten as far as to download it and extract it to my config file. So far there is no real indication it is doing anything. I see no change on my screen, buttons or features.
    Today is a new day, maybe I will see the light ;-)
    Sep 2006
    45
    Sam I looked at it and the denford orac lathe atc one looks promising.
    I may have to update my version of linuxcnc. the version I'm running I got back in 2006
    Oct 2010
    1189
    hi kweierbach how is your atc controlled one coil for air out to unlock the turret one coil for direction one coil for turn now right ? and which signals do you get one for any station ans first station has 2nd signal ? if you can confirm that than you can use my umbrella type component right away ( which i will reuse un my lathe as well ) thomas
    Gesendet von iPad mit Tapatalk
    Sep 2006
    45
    I have the same tuurret that Boatlover has that he posted pictures of
    Attachment 316410Attachment 316412Attachment 316414
    looks like a ratchet paw with homeing switch
    Oct 2010
    1189
    this looks more like a worm gear stepper setup and an homing swithch dor zero ,...
    Quote Originally Posted by Tkamsker View Post
    You would be correct.
  1. Just bought a Prolight 3000 lathe
    By boatlover in forum Mini Lathe
    Last Post: 12-19-2021, 09:01 PM
  2. Prolight 3000 lathe 5c collet closer
    By lloydcam in forum Benchtop Machines
    Last Post: 12-11-2019, 01:05 PM
  3. Prolight 3000 turning center (lathe)
    By closetgenious in forum Maintenance DIY Discussion
    Last Post: 02-07-2014, 06:05 PM
  4. CNC proLIGHT 3000 lathe
    By SRTSS in forum Machines running Mach Software
    Last Post: 03-17-2013, 04:40 AM
  5. Retrofit a Dyna 3000 Lathe
    By starlight in forum Open Source CNC Machine Designs
    Last Post: 05-07-2008, 12:45 AM
