586,036 active members*
3,711 visitors online*
    Apr 2016
    Lasercut 5.3 adding cut lines
    Hi all! I'm really hoping you can help me. I'm new to laser cutting and having some issues with Laser5.3.
    I use Inkscape to create a vector, export to DXF, however when I import it into Lasercut5.3 it creates an additional cut line.
    I am trying to create an outline of a heart with an arrow through it (coming out either side), but it creates a extra cut line through one of the arrow ends!
    How do I stop this from happening? The original file seems fine... I couldn't see a way to delete the cut line in the Laser5.3 programme, unless I am being very silly.
    Any advice would be very, very much appreciated!
    Sarah
    Jan 2013
    5
    Re: Lasercut 5.3 adding cut lines
    Quote Originally Posted by Sazcutter View Post
    Sarah
    First go to ouline view in inkscape and see if your design still has these lines
    If there are lines, then you have to play in boolean operation to get the exact shape you need
  1. Adding empty lines between tool operations
    By Jake E. in forum Post Processors for MC
    Last Post: 10-05-2020, 02:24 PM
  2. adding three lines of code before a tool
    By lockpickingfool in forum Fanuc
    Last Post: 04-09-2016, 09:37 AM
  3. Question about dashed lines in LaserCut
    By CB2015 in forum LaserCut
    Last Post: 03-03-2015, 01:34 AM
  4. Adding laser lines
    By gene8522 in forum WoodWorking Topics
    Last Post: 11-19-2012, 04:04 AM
  5. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
