586,361 active members*
3,413 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Can not drip feeding fanuc OM (128 ps alarm )
    Hi
    I have just bought a milling machine with fanuc om control.My control has a tap mode switch and when i choose the tap mode the control shows AUTO ,when i press cycle start the control flashes LSK ,and from the computer I started to send the nc file .
    the result was 128 PS ALARM .
    I made a lot of rs232 cables for fanuc om control and I changed the parameters for dnc but it show always 128 PS ALARM.
    Someone told me to use another post processor but it also fails.
    P.S. G127.5 IS 1 WHEN I SWITH TO TAPE MODE!
    Could anyone help me to start drip feeding ?:bs:
    Feb 2015
    161
    Re: Can not drip feeding fanuc OM (128 ps alarm )
    Are you calling a subprogram in your program?
    No I am not calling a subprogram in the program that I want to drip feed with the control.
    when I try to drip feed with the control (tape mode) I got 128 ps alarm
    when I try to upload a program to the control I got 85 ps alarm.
    Iam using cimco edit and easydnc
    I just used a lot of rs232 cable and changed 002 , 552 paramteres .
    please help
    Sep 2007
    66
    Fanuc alarm: PS128 - SEQUENCE NO. OUT OF RANGE
    Machine Alarm Error & Message:
    Fanuc's Alarm Description: Sequence number is other than 1 - 9999.
    Additional Suggestions & Alarm Clarification:
    CNC Programming problem
    Fanuc alarm: 85 - COMMUNICATION ERROR
    Fanuc's Alarm Description: When entering data in the memory by using Reader / Puncher interface, an overrun, parity or framing error was generated. The number of bits of input data or setting of baud rate or specification No. of I/O unit is in correct.
    Nov 2012
    Quote Originally Posted by bertus.nl View Post
    hello friend, i have this same problem in my fanuc control O-M
  1. Drip feeding DNC to Fanuc 6M
    By Camfather in forum Fanuc
    Last Post: 04-21-2017, 03:50 PM
  2. Drip feeding to Fanuc OM
    By maxvic in forum Fanuc
    Last Post: 10-15-2011, 05:47 PM
  3. Drip-feeding a Fanuc 21M
    By Ed_R in forum Fanuc
    Last Post: 09-28-2010, 09:02 PM
  4. alarm 087 when drip feeding
    By samu in forum Fanuc
    Last Post: 05-25-2010, 01:05 PM
