586,103 active members*
3,222 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > shaft coupler servo motor cincinnati milacron
    Mar 2013
    59
    Hi All
    Does anyone know where I can buy (tube couple) shaft coupler servo motor cincinnati milacron.
    see attach pic
    thanks
    24221
    Re: shaft coupler servo motor cincinnati milacron
    Don't ever remember seeing such an apparently crude coupler as that?
    I would think there are many other better options out there.
    Al..
    Albert E.
    Mar 2013
    59
    Al..
    I might suggest that I can use couple type or someone else who can tell me what would be the best option or which it has already had to replace this couple??
    greetings and thanks for your help
    Dec 2006
    584
    Get the part number from the parts book and order them from FIVES machine 800-934-0735 in the USA. This coupling is designed to shear when the axis is crashed, do not use anything else unless you want to replace a bent ball screw next time.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Mar 2013
    59
    Quote Originally Posted by meckardt55 View Post
    thanks Mike
    let me check parts book.
    regards
  1. very small diameter shaft coupler
    By daniel_dlds in forum Stepper Motors / Drives
    Last Post: 04-04-2016, 10:15 PM
  2. A better flexible shaft coupler
    By gregtx6789 in forum Benchtop Machines
    Last Post: 06-20-2013, 05:12 AM
  3. New shaft coupler from CNCRouterParts
    By msimpson99 in forum Uncategorised WoodWorking Machines
    Last Post: 04-26-2013, 12:57 AM
  4. Broken Aluminum shaft coupler
    By nateman_doo in forum Benchtop Machines
    Last Post: 02-11-2011, 02:54 PM
  5. RFQ-Simple shaft coupler
    By hoju1301 in forum Employment Opportunity
    Last Post: 05-16-2009, 07:12 AM
