586,068 active members*
3,654 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > multicam 1000 series problem in control KDM20 V1.37 SN=7356
Results 1 to 18 of 18
    Apr 2016
    9
    Question multicam 1000 series problem in control KDM20 V1.37 SN=7356
    Hi
    My machine is multicam 1000 series wood cut
    please i need help, this problem happens while am doing warming up for spindle then timer in the control show 5:21 and control forzed, i turned machine off by mail switch and then i turned it again showed this message in the control LCD.
    please how can i fix it :,( :drowning:
    message in the picture and also video form inside the cabinet
    https://youtu.be/bvbBSyi_cLI
    thanks,
    Jun 2010
    463
    Re: multicam 1000 series problem in control KDM20 V1.37 SN=7356
    Give me a call....need more information.....
    678-548-1483
    Maurice
    Apr 2016
    9
    am not in US now, please can i contact you on Skype please, if yes please give me your Skype ID.
    Apr 2016
    9
    i sent you SMS
    Jun 2010
    463
    sorry don have a Skyp account, that a pic and post of your control cabinet. Also when you home out the machine, the inverter comes on with out any fault correct?
    Apr 2016
    9
    yes you are right the inverter comes on with out any fault, i think the problem with setting ,is there any setting or file i must put it inside Motion Control or something like that?
    take a look to the pic in the attchmentClick image for larger version.
    Apr 2016
    9
    Quote Originally Posted by MCPservice View Post
    sorry don have a Skyp account?
    please do you have any way to meet you online , facebook,yahoo messanger etc.....?
    Jun 2010
    463
    Cant be the inverter is programmed internally, and should not change. Plus the spindle warm up is a internal program to the controller not motion control. When you request the spindle warm up, what shows up on the keypad.
    - - - Updated - - -
    yes but I am about to get on a flight.....it will be Monday before I am available after 12 today eastern
    Apr 2016
    9
    its showed timer down 5min
    after u pressed enter to warm up the keypad showed warming up 6000 RPM and timer suddenly freeze at 4min:21sec ,then i shutdown the machine from main switch and turned it again showed that message (KDM20 v1.37) , but when when i pressing the arrow key spindle is moving and the machine get the order from keypad but the information not showed in keypad LCD just (KDM20 v1.37) nothing else.
    ok
    Jun 2010
    463
    What is your incoming power are you single or three phase. Then check to see how your transformer is tapped, if your voltage is lets say 212 then transformer should be tapped for 208, the 1000 series machine were always like to be tapped lower on the transformers.
    Apr 2016
    9
    ok but now how i can get keypad information show in keypad LCD again
    Jun 2010
    463
    ????? did you drop the keypad or is the cable damaged in any way....
    Apr 2016
    9
    NO
    Jun 2010
    463
    So when you turn on the machine, nothing shows up on the keypad correct?
    If you go thru the process of homing the machine, does it still hard home the machine, and if it does that can you use the directional keys and it still moves the machine.
    Apr 2016
    9
    no, but its only showing KDM20 V1.37 SN=7356 on the keypad display
    yes its moving and going to home
    Jun 2010
    463
    Ok, the display is out. Unfortunately until Multicam starts accepting repairs again, your only alternative would be to buy a new or refurbished keypad.
    I have the same problem on my 5000 series . It only shows (KDM20 V1.10SN=814. Can’t even move the machine any solutions
    Jun 2010
    463
    How old is your 5000?
  1. Please help multicam series 1000 boot
    By ianb_bien21 in forum Benchtop Machines
    Last Post: 03-11-2022, 05:07 PM
  2. ask for multicam 1000 series operation manual
    By isam ali in forum Uncategorised MetalWorking Machines
    Last Post: 06-03-2012, 05:21 PM
  3. Control software for multicam m series??
    By IsaacD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-14-2012, 06:34 PM
  4. Multicam CNC Router Series 1000 User Manual
    By cdemarchena in forum Machinery Manuals / Brochures
    Last Post: 01-28-2012, 08:41 PM
