Immediate need for a full time CNC Machinist
The candidate shall have the ability to setup and operate CNC mills, you are not required to program complex geometries, but you must be able to write your own programs for drilling a couple holes, facing, and the like. Perform in-process quality inspections of own work and make adjustments as needed.
Technical requirements:
*Experience with Haas CNC vertical mills and/or Haas CNC lathe experience.
*Ability to read and interpret blueprints, some with GD&T.
*Must have your own tools and common hand gages.
*Must be able to read and edit G Code programs.
*Must be able to use all standard inspection gages.
*Manual machining experience with mills and lathes, for complementary support.
Professional requirements:
*Minimum 5 years experience setting up and operation of CNC mills.
*Self-starter and require little or no supervision.
*Must be able to produce quality parts efficiently.
*Must be physically able to perform all aspects of the job, including but not limited to standing all day and lifting of fixtures, vices, and such up to 75lbs.
*Must be a team player and be comfortable working with other people with setups and production.
*Must be available to work overtime as needed.
We are a job shop and contract manufacturer. All CNC machines are Haas. The majority of parts we produce are from aluminum, 300 series stainless, steel and plastic, very occasionally an exotic plastic or tool steel. Our new facility is climate controlled and all CNCs are less than 12 years old. Production runs are generally less than 200 pieces, so the ability to transition from job to job in a timely manner is essential.
We are located in Plant City, Florida within 4 miles of I-4.
Salary is dependent on experience and benefits will be discussed during the interview.
Apply in person Catamount Machine Works, 2804 Sydney Rd, Plant City FL 33566 or call 813-659-0505 to make arrangements for completing an application.
