586,108 active members*
3,173 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > C12-100mm ER11M chuck holder with 12mm pillow block
Results 1 to 6 of 6
    Sep 2009
    10
    I bought
    CNC Milling Lathe Straight Shank Collet Chuck C12 ER11M 100L + Wrench
    from
    CNC Milling Lathe Straight Shank Collet Chuck C12 ER11M 100L Wrench | eBay
    and pillow block from here
    12mm Bore Dia Pillow Block Cast Housing Mounted Ball Bearings Vertical Bearing | eBay
    to make a router, but the shank dont enter into the pillow block, both says 12mm but it doesnt go into, what may be the problem?
    Nov 2007
    479
    Re: C12-100mm ER11M chuck holder with 12mm pillow block
    Brand new straight shank C12-100mm ER11M collet milling chuck holder.
    Shank diameter: approx. 12mm <--------------------------------------------------------------------This could be your problem.
    Shank length: 100mm
    Wrench length: 95mm
    Sep 2009
    10
    15362
    Quote Originally Posted by varunalau View Post
    Yes the first one was a C10=10mm Diameter C12= 12mm
    Mactec54
    Sep 2009
    10
    Both C12,
    I confirmed with seller that its also approximately 12mm, that also will be useless
    any other way to use the shank chuck adapter? using any other pillow block which has adjustable?
    15362
    Both C12,
    They are 12mm I have used them, try a different supplier if you can't get 12mm, I have used them all different sizes, and they are usually the size it states, Here is a post where one was used with precision Bearings
    http://www.cnczone.com/forums/cnc-wo...dle-build.html
    Mactec54
