586,069 active members*
3,410 visitors online*
Thread: Thor
Page 4 of 5 2345
Results 61 to 80 of 83
  1. #61
    May 2013
    70
    Re: Thor
    Managed to get access to a bridgeport type machine to do work on the Z Axis. Almost done, need to do a fair bit of tapping and will then assemble.
  2. #62
    May 2013
    70
    Re: Thor
    Ok, cleaned up a bit, removed the reference table, mounted the main table and did a quick test fit of the Z Axis bottom part.
    The naked machine
    Some bits on it
    Z axis, ballscrew is just 'hanging' onto the overhang, not mounted. The Z axis needs some of the holes to be drilled all the way through and I need to find the location of the bottom carts. I did not have the measurement at hand when I machined the holes on the larger mill. As these are not threaded, I have a bit of margin for error.
  3. #63
    Feb 2009
    2143
    Re: Thor
    THANKS for the updates. You're making great progress and it looks quite impressive!!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  4. #64
    May 2013
    70
    Re: Thor
    Quote Originally Posted by mcphill View Post
    Thanks. Wasnt sure if anyone was still interested or following this thread.
  5. #65
    May 2013
    70
    Re: Thor
    Ive not been good at keeping this thread up to date. The UK Mycnc thread has been kept up to date.
    Thor works, busy tweaking etc but some info here:-
    "Suppose this means it works.
    Speeds and Feeds
    24000 rpm - 6mm endmill
    Cutting Rate 4000mm/min
    Lead / Ramp at 1440 mm/min
    This was run at 80% speed. Overall happy with the cut considering there is no finish pass.
    DOC is 5mm, WOC is 1.2mm
    Still got more to do, but happy with the initial results.
  6. #66
    Nov 2012
    29
    Re: Thor
    Are you serious? After all that work you will cut with crapy chinese spindle?
  7. #67
    May 2013
    70
    Re: Thor
    Quote Originally Posted by John1987 View Post
    Yep. Feel free to send me £3000 for something better.
    Ill upgrade the spindle once a)this one dies, b)cannot do what is needed, c)I have the funds available.
  8. #68
    May 2013
    70
    Re: Thor
    A design constraint that you may not be aware of, is that this mill can only be powered by single phase, 32A max. This is the most powerful ****ty spindle (4KW) that fits that requirement.
    Of course Id prefer a fully balanced ATC spindle.
  9. #69
    Nov 2012
    29
    Re: Thor
    Install some kind of BT 30 spindle with timing pulley and servo motor to rotate it. Much, much better choise for reasonable money.
  10. #70
    May 2013
    70
    Re: Thor
    I did look at this. I couldnt find anything I was willing to part money for. The cheapest I could find was around $1500 upwards to around $4K. Servo power, I am limited to around 1.5KW (using Panasonic), however I could look at other makes.
    Ill just make the best use of this spindle until I can afford an upgrade to an all in one unit.
  11. #71
    May 2013
    70
    Re: Thor
    Ive bought a HSD 6.8 KW ISO 30 24K RPM spindle. Better?
  12. #72
    Mar 2014
    1131
    Re: Thor
    Amazing machine.
    What are your final thoughts on concrete with super plasticiser?
    Sent from my MI 5s Plus using Tapatalk
  13. #73
    May 2013
    70
    Re: Thor
    Quote Originally Posted by Azalin View Post
    Amazing machine.
    Thanks. For me, it looks like a viable option. I'm not a mechanical engineer however I'm aware that some very large machines are built using similar technologies. Lafarge and other make their own proprietary UHPC - worth a look.
  14. #74
    Mar 2014
    1131
    Re: Thor
    Thanks.
    Are you able to compare concrete+plasticizer with epoxy granite? On strength, vibration etc. Actually what I want to understand is how much the plasticiser makes the concrete softer and as a result how much the concrete gets flex.
  15. #75
    May 2013
    70
    Re: Thor
    Thanks.
    Nope, sorry, not within my skillset / knowledge.
  16. #76
    May 2013
    70
    Re: Thor
    So Thor has had a bit of an upgrade / make over.
    Spot the difference.
  17. #77
    Aug 2009
    291
    Re: Thor
    Quote Originally Posted by Chazaxl View Post
    You milled a decorative 1/2 moon into your vise?
  18. #78
    Mar 2014
    1131
    Re: Thor
    Quote Originally Posted by rocketflier View Post
    Hehe
  19. #79
    May 2013
    70
    Re: Thor
    That was courtesy of my previous machine (Denford Triac).
    Looking forward to getting the HSD 6.8KW 24K RPM spindle working 100%, hopefully this weekend I can do some test cuts. Ive only got a few toolholders / collets but will sort that out once I am confident that this works OK.
  20. #80
    Jul 2018
    6339
    Re: Thor
    Hi Chaza - How is your mill going? Any long term observations? I'm looking at doing a benchtop concrete mill. Did you use Portland cement? I'm going to use CSA cement. Regards Peter
Page 4 of 5 2345
  1. Free MJOLNIR THOR HAMMER GIVEAWAY
    By silverfoxx03 in forum Machine Created Art
    Last Post: 03-27-2012, 01:44 PM
  2. MAJOR PROBLEMS with Thor 45cc 2 Stk Petrol engine....PLEASE HELP!!!
    By thkoutsidthebox in forum Hobby Discussion
    Last Post: 10-18-2011, 11:12 PM
