Hello Fretman, Wow, that turned out very well for a fist cut on the machine.
Congrats, you must be feeling very proud with that machine.
Cheers,
Luc
Cheers,
Luc
The switch to aluminum is something I'm contemplating too. My cousin is getting a water jet and I could probably use that. The only issue I have so far is some flex in the X direction. I noticed this on the dial indicator when setting the X travel in GRBL. I should have doubled up the gantry sides with two pieces of .75" MDF. I cut that corner thinking that the sides would be stiff enough with just one per side. The sides are just tall enough to add some moment arm to what ever side forces are applied. I'll have to add a metal stiffener to the sides of the gantry support to help with that.
But my overall goal was to build a machine that's much more rigid than the Shapeoko2 and I've surely done that!
Im looking to do something like this but with a proprer linear system, rack and pinion and thicker plates
https://youtu.be/TJBtkC5rrfQ
I got the hiwins one pretty expensive with the canadian dollar value but i guess it will worth it
Redid the gcode and recut the parts...perfect fit for the bearings. Will have some video up soon.
...cutting parts. Spindle mount is temporary.
...propertly cut parts.
Some video of the machine in action. I will be cutting new spindle mounts. You'll probably notice that my tool paths aren't very efficient. I realized what I did in generating the gcode. Will do better next time.
Installed bearing block...
Started a fun project on my machine...still have a few things to do to completely finish it. But I couldn't resist cutting something on it. These will be teak wooden bracelets for Christmas presents. I'm trying to teach myself the 3D software now so I don't have to profile the bracelets on my table router.
...being cut
...got six of them
...here are some braclets I cut last year for my wife...
Awesome on the drawing Luc...I love seeing my machine move whether it's cutting or drawing!
The cutter I used on the HDPE was a 2 flute 1/8" spiral upcut bit. I think my feeds were a conservative 40ipm cutting and 20ipm plunge. I will push it a little harder next time. Plunge depth was 0.05".
I wanted to try my hand at using the free F-engrave software to do some engraving. I had some teak rounds left over from making wooden bracelets and engraved an H into one of them. The bit was a 30 degree 1/8" v-bit. Not sure of the RPM.. Both cutting and plunge speeds were 10ipm. I posted pics on FB and it looks like I'll be making a few Christmas presents!
Attachment 335256
Cut some bracelets out of a teak cutting board for Christmas gifts on my CNC. Got the cutting board at a salvage place for cheap. The lighter color bracelet on the bottom is a test cut in pine.
So have you done any guitar parts on your CNC yet?
What was your result on this last driver? (4A CNC Single Axis 4A TB6600 2 4 Phase Hybrid Stepper Motor Drivers Controller | eBay)
I purchased one a few months ago but have not had a chance to work with it yet.. any recommendations or things to watch out for? Opinions on it ???
No...actually I purchased the M542T drivers from stepperonline and so far so good ( 2/4 phase Nema 23 Stepper Motor Driver 24-50VDC 1.5A-4.5A 256 Microstep M542T|US054|Stepper Motor Drivers ).
Hopefully you'll have nothing but good service out of your driver.
