586,121 active members*
3,643 visitors online*
Page 1 of 14 12311
Results 1 to 20 of 299
    Dec 2014
    640
    Starting my build...
    I've been studying for a while now and I'm taking the plunge. I've got my rail and Z axis. SBR16 1,150mm Y and 800mm X. I'm going to build a torsion box gantry...hopefully very stiff. Here's an overview of what I want to do...
    The 800mm gantry torsion box was just a little to large to cut out on my current CNC machine, a Shapeoko2, so a friend cut the pieces out on his very large machine..
    Torsion box under construction...
    I'm going to cut the torsion box ribs out on my machine and finish the structure. I was tempted to go without the ribs as the box is very rigid like it is, but I'll go ahead. The box is made out of 3/4" MDF and it might be on the heavy side. I have two NEMA23 270oz motors to move the Y Axis.
    I'm not an engineer so I don't have a rigidity analysis on the structure, but a lot of the advice I saw here was to go for it, learn a lot, then modify if necessary. That's my plan. The box is alreay more rigid than the Shapeoko2 X axis and my hope was to built a rigid machine capable of aiding me in building electric guitars.
    Dec 2014
    640
    Re: Starting my build...
    A few other tidbits. I plan on using 1/2-10 5 start acme screws. Not sure of the drivers yet...I bought the motors from us.stepperonline.com and Bo told me they have a brand new professional (not hobby grade) version of the TB6560. The driver isn't listed yet on their website. I just might give that a try.
    Ahead of the drivers will be Windows 10 to an Arduino Uno running GRBL. This setup has served me well with the Shapeoko2.
    Apr 2013
    1899
    6560 = big mistake...
    Dec 2014
    640
    I do hear you and know that I may be taking some risk. The gshield I'm using now could run the motors, but the motors are rated at the top of the boards current capacity.
    Quote Originally Posted by A_Camera View Post
    Feb 2016
    381
    Biggest problem with the TB6560 is magic smoke that magically appears from the TB6560AHQ chips when the motors are connected incorrectly and the fact that if you do this the board is useless unless you can se solder and solder in a new one that costs about $2.
    I have used many of these boards without any problem but have repaired a few for people that plug steppers in and power on with incorrect wiring, they always deny it to begin wth and admit doing so when I tell them I have to double their bills in case more work is needed on a faulty board, so check and double check and you will have no problems.
    Dec 2014
    640
    Oh yea...I can solder on new chips. I've built my own ham radios and tube and solid state guitar amps. Bo is offering a discounted price to the first few buyers of the driver, but I'm not yet ready to buy them. The normal price is going to be $49 but he's offering it for $41.64 for now.
    I'm assuming by professional he means thicker boards, heavier traces...overall better construction.
    I saw an earlier post Louis where you said the TB6560 had worked great for you if properly hooked up. That gave me some confidence in ordering.
    Quote Originally Posted by Louis_Cannell View Post
    Feb 2016
    381
    I have seen professional grade boards which were exactly the same as $20 chinese boards just the price professional it can be same boards from same factory someone imported and calls them professional indicating they're better because he imported them and will make a nice mark up.
    Had a job with some professional voltage regulator buck converters recently that were not only cheap imports but IC's had been laser etched to add HV onto chip identification (faked) a company had used these and had several burst into flames they were obtained from a reputable supplier that had been conned himself. A llot of the chinese stuff etc is better quality than it used to be, as I say lots of calling these units because of user error, they do not have polarity protection as default so with a pro unit I would expect that to be standard, not very offen a problem of components or board quality form my experience cheap board and pro all use toshiba drivers hence the board id.
    Dec 2014
    640
    Polarity protection is something I can build. I have been known to get ahead of myself, or get distracted, and hook things up improperly and let the smoke out. I know better, but sometimes I don't do better...LOL.
    Mar 2013
    140
    I'm a fan of torsion boxes. They are an elegant solution in my opinion.
    Dec 2014
    640
    Cool...I've read on here that weight is my friend and I guess I'm going to find that out. With using 3/4" MDF the gantry is going to be weighty.
    Quote Originally Posted by manofmanyhats View Post
    Apr 2009
    5516
    Quote Originally Posted by fretman_2 View Post
    Weight is only your friend if your machine can handle it. But yes, the lower the weight, the lower the resonant frequency generally meaning the more prone to vibration. But there will always be tradeoffs. Building heavier means beefier linear rails, and more powerful motors. Being you're using round linear rail, you have to build an incredibly massive MDF structure to even come near their load capacity.
    A search here in this forum for 6560 should net some horrific results... you have been warned.
    Aug 2011
    388
    The TB6600 or THB6064 are far better than the 6560. And TB6600 drives are $10 - $20 each on ebay, now. Few decisions in CNC design are a no brainer. This is one.
    David Malicky
    Dec 2014
    640
    Cool...TB6600 sounds good...I'll look at them on eBay. Good price too...thanks!!!!
    Quote Originally Posted by dmalicky View Post
    Apr 2009
    5516
    Does TB6600 have mid band resonance damping? Current idle circuitry?
    Dec 2014
    640
    Got ribs cut for the gantry torsion box beam.
    Attachment 316918
    Aug 2011
    388
    fretman, there are a number of versions of it. Don't get those labeled HY-DIV268N or Rattm (red circuit board) -- those have many issues.
    The best implementation appears to be this one (used to be on ebay, but I didn't see it now): TB6600 1 axis Stepper Motor 2-phase Driver Board for CNC Router [HY-TB6600-Module] - US $16.00 : HAOYU Electronics : Make Engineers Job Easier
    I tested it among some others a few years ago -- Haoyu was the best of them, and it works quite well.
    I just bought these 2 versions, but have not tested them yet:
    Single Axis TB6600 DC12 45V Two Phase Hybrid Stepper Motor Driver Controller Lo | eBay
    4A CNC Single Axis 4A TB6600 2 4 Phase Hybrid Stepper Motor Drivers Controller | eBay
    This THB6064 is also very good, probably better than the Haoyu: New THB6064AH JP 6445A Single Axis Stepper Motor Driver | eBay
    Louie, to clarify, I didn't mean TB6600 over any other drive. Just compared to other low-end drives like TB6560. It does have idle current reduction, and I have heard it has some mid band damping, but I'm sure it is not as good as Gecko or a digital drive.
    David Malicky
    Apr 2009
    5516
    Have to check these out... Thanks for the head's up, and thanks for your contributions here, been very helpful to me and others!
    May 2005
    3920
    Quote Originally Posted by louieatienza View Post
    Why not use a Gecko or other proven brand? Some things are worth exploring, too build a better machine, but I'm not sure I would waste time on stepper drivers these days. I'd be more concerned about getting the best controller to drive them, be it a PC via the parallel porter one of the quickly improving single board computers.
    Apr 2009
    5516
    Quote Originally Posted by wizard View Post
    I agree with you 100%. I use Leadshine drives on one machine, G540 on another, and Parker high voltage stepper drives on my mill. And I've recommended as such to many here. The problem is, not every job or project demands it. And I have a couple projects, one a 3D printer, where I don't want to go the Arduino/Raspberry Pi route. But I'm not spending $300 on drives for it.
    Dec 2014
    640
    I don't have a computer with a parallel port nor do I want one. I've looked at the Raspberry PI but I don't see much of an improvement there over my current setup...which is a Stream 11 laptop to an Arduino UNO via USB. I'm going to provide control for the drives of the new machine from the Arduino Uno/Stream 11 setup. I will give myself room to change my mind about that later on, but for now that's what I know and it's working for me on my NEMA17 Shapeoko 2. I ran a 3.5 hour job with that setup yesterday with no problems.
    I do understand from what I've read that the Gecko and Leadshine drives are very good quality. But for now price is an issue with getting this new machine up and running. I'll likely do lots of upgrades on the new machine over time including electronics.
Page 1 of 14 12311
  1. New 2.1 build starting
    By Bigdog_1002 in forum Momus Design CNC plans
    Last Post: 06-15-2013, 06:07 AM
  2. Starting 2nd build
    By fastpcuser in forum Momus Design CNC plans
    Last Post: 01-31-2013, 09:07 AM
  3. Starting to think about my next build
    By gully in forum Australia, New Zealand Club House
    Last Post: 05-03-2012, 12:51 AM
  4. Starting up 2nd New CNC Build
    By JTK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-04-2010, 03:36 AM
  5. New build starting soon.
    By Kammo1 in forum DIY CNC Router Table Machines
    Last Post: 03-23-2006, 09:25 PM
